Question about Tablets & eReaders
I reset my tablet again and still it didn't fix anything
My RCA tablet wont start up again
By again do you mean it didn't start up before and you fixed it? or you shut it down and now it won't start up?
Try a factory reset:
How to Completely Reset Your RCA Android 4 1 Tablet
Apr 13, 2015 | RCA CA 7" Tablet with 4GB eory 28458515
How can my tablet read the sd card again?
reset it without the sd card installed.
also...if you have a card reader on your computer....put the sd card in it and see if there is anything on the card. You may have deleted everything on the card by reseting your tablet with the card in it.
Mar 02, 2015 | Samsung Galaxy Tab 2 GT-P5113 10.1" 16GB...
My nobis 9inch tablet is stuck on the go screen and won't let me do anything what should I do to fix it?
I did a factory reboot on my CRAIG 9in. tablet Model:CMP756. It has been on the "LOADING" screen for over to hows. How do I fix this.
Aug 23, 2014 | Tablets & eReaders
Android launcher stopped unexpectedly
Disconnect the battery for 10 minutes. Then try again. Are you doing the 3 finger hard reset?
Dec 04, 2013 | Sylvania Synet7lp Mini Tablet 1. ghz Arm...
Can't do anything
try to reset it again and put you information back in if still not working call tech support for there help they can give you more ideas on how to fix the problem you are having.
Nov 11, 2013 | Coby Kyros MID7022
Disgo is frozen on home screen and home icon keep flashing i cant do anything
Search google to do a hard reset, I had the problem and after doing a hard reset it helped me and my tablet is working fine now. I don't really remember which keys it was but there are three keys to keep pressed and after that it will reset your tablet and if everything is ok it should work perfectly after that.
It would be nice if the manufacturer would also put that in the manual, because when I received my tablet I had to calibrate the screen and that didn't really help me. Also the tablet was working really slow and took a lot of time for everything, plus the fact that the keyboard kept pressing all sorts of other keys then that I wanted to press.
I hope this will help you and that your tablet will work fine for you.
Let me know if you had any success.
Sep 08, 2012 | Disgo Tablets & eReaders
Coby kyros factory data reset
It's better to contact the supplier for tech help, because I didn't have this tablet before.
Android 4.0 Tablet PC
Jan 25, 2012 | Coby Kyros 716829701508 Tablet PC
I have forgotten my wireless network password to connect to the internet. How do I recover it or re-set it (on my Coby Kyros Tablet)
Hi!
In order for you to remove the password, you need to reset your wireless router. You didn't mention what brand and model of your router, but anyway all routers have a "reset button" just look for it on your router. It is usually found at the back of the router and it is very small, you need a pin or anything long and thin to insert into it in order to push it for about 10 seconds.
Thanks for using fixya!
May 30, 2011 | Coby Kyros 716829701508 Tablet PC
Tablets & eReaders Logo
27 people viewed this question
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
