Question about Pool & Spa
Pantera hi-rate sand filter swimming pool - Pool & Spa
john224
  • 1378 Answers
SOURCE: Where can I get a seal for the flow valve on a
www.arrowmotor.net and use the contact button. You would likely want the rebuild kit that includes all the gaskets and o-rings.
Be sure to include the model number off the valve, which should have SP at the beginning.
Posted on Jun 21, 2009
  • 22 Answers
SOURCE: swimming pool
check the spider gasket under the valve top to see if it in broken.if it is not the filter has a bad lateral in the bottom of the tank.
Posted on Jul 10, 2009
adamh294
  • 310 Answers
SOURCE: I replaced the sand in
http://www.hayward-pool.com/prd/In-Ground-Pool-Literature_10201_10551_14501_-1___I.htm
Above is the link to all hayward sand filter manuals, with parts diagrams.
The most common cause of sand getting through after a change-out, is a broken lateral. The laterals at the bottom of the filter are very fragile, and prone to breaking. When refilling the filter with sand, it should be 3/4 of the way filled with water first to take weight of of the lateral grid. One other possibility is the air bleeder line has come undone. Regardless of which one it is, you will have to go back in and find out.
Use the above link to the parts diagram to identify and order any parts neccessary. Laterals are cheap, so if your doing one of them, you might as well do all of them.
Posted on Jan 14, 2011
  • 8404 Answers
SOURCE: when filtering water it is
Is this a multi-port valve offering back wash, no filter, rinse, etc. modes? Have you ever turned it counter clock wise? (Never turn it counter clock wise.)
You will need to remove the top and put a new gasket in the valve.
If it is Push Pull, remove the two screws at the top and pull the assembly out. Remove and replace all "O" rings. Lube with silicone grease for pools and reassemble.
I think this will fis you up.
Thanks for your question today.
Posted on Jan 30, 2011
jharwell668
  • 640 Answers
SOURCE: While vacuuming my swimming pool
Try changing the setting on your pool filters control valve to waste. This will bypass the filter and vacuum directly to waste. If this works, it could be a problem with the filter's "filter" setting and you may need to service or replace your control valve.
Posted on Mar 15, 2011
Please where can I find valve body lower part no. 14965-0013 for my pantera sand filter
So sorry, this part is No longer available.
Has been... Obsoleted, Discontinued, Cancelled all production, Ixnayed, I think you get the picture.
Anyway, your option is to either get a whole new filter assembly with a new valve, or just a new valve...?
This one is the replacement for your filter tank. New and improved. Oooohh.
Take a look, some re plumbing will be required. One draw back : (
No Unions : (
Pentair 261186 Valve Replacement Sta Rite Cristal Flo High Rate Pool and...
Jun 10, 2015 | Pool & Spa
Tip
How to Choose the Right Swimming Pool Filter?
There is a lot of confusion about various filters, many different opinions, and several important facts to consider. The first is that a pool can be properly maintained with any of the filter systems available: Sand, Cartridge, or Diatomaceous Earth (DE). Here is a brief description of each type:
SAND FILTERS
Water is pushed through a bed of filter sand and removed through a set of lateral tubes at the bottom.
The filter area of a sand filter is equal to the area of the filter itself.
For example, a 24" filter will have 3.14 square feet of filter area. Only the top 1" of sand is actually used to filter the water. The principle behind this filter is that water is pushed through the filter sand, somewhat like an espresso machine. Dirty water goes in the top and clean water exits out the bottom. As the filter sand becomes plugged with debris from the pool, the pressure increases on the filter and the water flow drops. In order to clean the filter, you just run it in reverse and dump the waste water; this is referred to as "backwashing" the filter.
How to Choose the Right Swimming Pool Filter Pool filter reviews
on Jun 20, 2017 | Intex Krystal Clear Model 635 Pool Filter...
Tip
How To Connect Hook Up Use Above Ground Swimming Pool Vacuum and Hose With Sand...
<utube src="YEW-QUyP2Iw"></utube>This video will show you how to connect your above ground pool vacuum and hose to the sand filter on your swimming pool.
on Aug 03, 2013 | Pool & Spa
Pantera pool filter model p24
give them model number of filter and multiport you need new multiport gasket (spider gasket)
Feb 09, 2014 | Hayward SAND FILTER, PRO SERIES
Swimming pool Hayworth s240 sand filter suction is wimpy can it be old sand causing the problem?
The filter may be clogged. If you have a multi-port valve that you use to backwash, set it to "recirculate" and see if your suction improves. If it does then the filter needs to be cleaned out. If there is no difference the issue may be a clogged impeller or some restriction in the suction line. Has the pressure been running high?
May 19, 2013 | Pool & Spa
Have a pantera p24 sand filter from wicor and the lable has gone from the control lever. I need to know what function is in each position.. filter, rinse, backwash etc.
don't know if you got it fixed or not but can give you mine....if your looking at it from the top it goes like this....in the twelve o'clock position nothing,1 o'clock is recirculate then 3 o'clock is backwash then 5 o'clock is close then 6 o' clock winterise then 7 o'clock is waste then 9 o'clock is filter then the 10 or 11 o'clock is rince. hope that helps..
Jul 15, 2011 | Wicor Industries Master Plumber Geyser...
When filtering water it is also leaking through back wash pipe it is a sand filter pantera hi-rate filter with sta-rite water flow control
Jan 30, 2011 | Sta Rite Pool & Spa
Labels Gone
I also have the same problem with the label on my filter. My pool dealership said I would need deal with Wicor directly. I see two other people with the same problem, however, neither has been responded to. It is VERY difficult to run your pool properly if you don't have your control lever labeled. An immediate response would be greatly appreciated.
Apr 23, 2010 | Wicor Industries Master Plumber Geyser...
Pool & Spa Logo
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
