Question about Samsung Dryers
Samsung dryer DV350AG the machine gives a buzzing sound, drum does not move. Is it motor problem?
    Top Expert:
  • Samsung Master
  • 50,583 Answers
Possibly a faulty start/run capacitor
have a technician check it out
it will become a motor problem if you let it keep humming
Posted on Jan 03, 2017
  • Rosalie Yuen Jan 04, 2017
    Thanks for the info. Any idea if it will be expensive to replace a new capacitor? I turned the drum manually and got the dryer start but thought it migbt be better to replace the capacitor.
  • Bill Boyd Jan 04, 2017
    what you have done to get the drum to start is further indication that the start/run capacitor is failed
    capacitors start in price from as low as $10.00 aud to around $60.00 aud depending on the Uf and voltage specifications of the capacitor
    It may be best to talk with a technician first then have him bring a capacitor with him to fit after he does a proper diagnosis of the problem
  • 1462 Answers
SOURCE: Fisher and Paykel Dryer will not spin, motor buzzing
take top off. set it going and give the drum a push by hand. if it starts and keeps going then the fault is the motor capacitor - cheap part
Posted on Nov 14, 2008
barkencoa
  • 3463 Answers
SOURCE: hotpoint vtd00p tumble dryer giving
I assume you fitted the right value capacitor and connected it up correctly,if you have then slip the belt of the motor, and make sure it is free to turn with no resistance.
Try it without the belt on, if it runs o/k then problem is elsewhere, if it still does not run , then you could have faulty motor, and or timer. That is as much as I can help you.
Plz rate my solution.
Thanks.
Posted on Dec 22, 2008
  • 686 Answers
SOURCE: drum not turning
no brushes in those motors you need new one or different dryer
Posted on Mar 12, 2009
SOURCE: Hoover Tumble Dryer 5030D
That is the sign of a bad capacitor. It is the capacitor which gives the motor the extra boost it needs to start up. Mine has blown twice (due to overlaoding by the kids).
Posted on Jul 26, 2011
oldTech2332
  • 2341 Answers
SOURCE: When i tried to turn
Those symptons (humming/buzzing ¬ starting) are 99 out of a 100 times a sign of a motor that has locked up.
Gene
Posted on Aug 07, 2011
Testimonial: "nice"
Inglis Gas Dryer... mercy me?
Sounds like what you said. Time for a motor. The motor has an internal overload and will shut the machine off if the motor runs hot.
Good Luck
Feb 26, 2014 | Inglis 6.5 Cu Ft Super Capacity Gas Dryer
Hotpoint TDC62p is making a buzzing/humming sound and the drum will not spin though it does move if you push it.
Either something is binding the blower wheel up or the motor is bad. The best thing is to take the front of the machine off to access the blower wheel to verify ifanything is indeed binding it.IF not read the next section.
If you can turn the drum and then the dryer starts you have a bad motor. The way the dryer works is when you initially push the start button, electricity is sent to the start winding, or stator, of the motor. This will in turn start the motor turning. From there the stator will drop out of the electrical process and at the same time the run winding, or rotor, will take over and the motor will continie to run. Your stator is damaged, has a burn spot, etc so by you turning the drum, the belt around the drum is moved which is attached to the motor pulley. You basically take the place of the stator. Long story short, you have a bad motor.
May 17, 2012 | Hotpoint Tumble Dryer Tdc60n Tdc60p Tdc60s...
Maytag mde9700 no power and has buzzing sound
Usually on these models if it sounds like a stuck motor sound could be the motor or the pading on the drum that peeled off and probably stuck between cabinet and drum
Jun 04, 2011 | Maytag MDE9700AYW Neptune 174 Electric...
Tub stopped turning, connot turn by hand either.
Dryers have a belt that turns the drum, I think dryer belt being broken or slipping badly, burn out motor, or worn support parts.
---Dryer have a belt that rotate the drum, If the belt worn out or broken, it can not move the drum then you just need to replace it. ---You can check motor by hearing buzzing sound, if the belt has the problem. If you do not hear any sound from the motor then you may have to replace it. ---Try to move drum manually (by hand), if it is hard to turn then problem with the idler pulley, glides, or drum rollers.
I hope this will solve you problem
Thanks..!!
4 thumbs rating keep us motivated to answer more free questions.
Oct 06, 2010 | Maytag Dryers
Drier does not tumble but it still heats.
Sound like the belt being broken or slipping badly, burn out motor, or worn support parts.
  • Dryer have a belt that rotate the drum, If the belt worn out or broken, it can not move the drum then you just need to replace it.
  • You can check motor by hearing buzzing sound, if the belt has the problem. If you do not hear any sound from the motor then you may have to replace it.
  • Try to move drum manually (by hand), if it is hard to turn then problem with the idler pulley, glides, or drum rollers.
Good luck and have a nice day
Rating the solution is highly appreciated.
Jul 05, 2010 | Asko T701 Electric Dryer
Motor is noisy (loud buzzing). Drum belt seized.
the problem, is with a component,called a capacitor.a capacitor gives a"jump start"to the motor.when this charge or jump start cannot be given,the motor will "hum" or"buzz".a new capacitor should not too expensive.
Oct 16, 2009 | Tricity Bendix TM310W Electric Dryer
LG dryer will not start just buzzes
Try this:
Unplug the dryer, reach inside the drum and try to rotate the drum 1/4-1/2 turn. Plug the dryer back in a push the start button. Sometimes motors get dead zones in them, and this will move it from that zone.
If that doesn't work, then you will have to go farther.
If you have a front loading machine, remove the front, this will expose the belt and drum, check the belt to see if it is broken, if not then remove the drum and belt and this will expose the motor, idler arm with pulley, Your belt may have slipped off the motor pulley or the idler arm pulley.
Before reassembly, lubricate the drum rollers at the shaft with a good grade of machine oil such as 3 in One Oil.
I hope this helps
Oct 04, 2009 | LG DLG2525S Electric Dryer
Nov 14, 2008 | Fisher DEIX2 Dryer
Whirlpool condenser dryer not working. Power coming in to machine but that is about it.
hiya
does the machine make a buzzing noise? or heat up?
if it makes a buzzing noise and heats up it will more than likely be the motor surpressor, all this does is gives the motor a kick start to set it off tumbling with a wet load. theres a quick way you can check if it is this at fault, make sure the drum is empty and set timer as you would normally, open the door and spin the drum as hard as you can then shut the door quickly (whilst drum is still turning if you can), the dryer should now run normally until it stops again.
hope this helps
please dont forget to rate the helpfulness of this reply, thanks kj
Aug 05, 2008 | Whirlpool Dryers
Dryers Logo
66 people viewed this question
Top Samsung Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Samsung Dryer Expert? Answer questions, earn points and help others
