Question about The Watches
The Lap/Reset button on my Crane GPS/Heart Monitoring Watch does not work anymore Any clues how to revive it?
  • Buddy lotter
    Buddy lotter Jan 03, 2017
    You must take it in to a watch shop
SOURCE: I noticed condensation under my
You need to open your watch and let the condinsation out. Does your watch have screws in the back? Alot of times when you have the battery changed (in plastic watches) it is hard to tighten down the back properly because many people strip the tap because the screw is metal and the casing is plastic. Either way open the watch, let it dry out for at least 45-1 hour ,and if you can find some silicon ( a heavy grease) put that around the inside back seal, and close as good as you can. If this is not a plastic watch please let me know so I can assist you further.
Posted on Aug 04, 2008
  • 135 Answers
SOURCE: SPORTCRAFT Heart Rate monitor watch
Go to:
http://ftp.casio.co.jp/pub/world_manual/wat/en/qw2016.pdf
Full user manual and instructions there to download.
Please contact again if this in not successful, if it is, your rating would be most appreciated.
Mike.
Posted on Feb 23, 2009
  • 183 Answers
SOURCE: Have anAqualite digital watch - and no
Most digital watches set by holding down the mode or restart button until the display begins to flash. You can then cycle through the display and set on the right time.
Posted on Sep 17, 2009
  • 2501 Answers
SOURCE: Setting analogue time on a Crane & Viceroy Radio controlled watch
I haven't been able to locate your watch but since watches tend to be similar in operation, I suggest that you look at the instructions for my watch and try a similar settings.
Go to "http://ftp.casio.co.jp/pub/world_manual/wat/en/qw2735.pdf" and instructions for a Casio watch will appear. Go to page 4 and read instructions under "to adjust analogue time".
Posted on Apr 02, 2010
gemineye61
  • 831 Answers
SOURCE: I lost my bowflex watch
That is such a specific type of watch you will have to contact them at the following link:
https://www.heart-rate-watch.net/contact-us?osCsid=18b0055ce5db1b2b4eba5e48cb5eeb1e
Best wishes
Posted on Aug 12, 2010
Polar AXN300 Heart Rate Monitor Watch HRM AXN300 is not showing pulse
I would think it is the sensor circuit in the watch. When you replaced the battery did you activate the processor all reset for the watch? I do not know on your model where or how this would be activated.
Electronic watches normally have a reset procedure for when the battery is changed. Very important the watch's processor reset is performed after changing the battery. This is not any of the user readings reset. This is a reset for the watch's processor and system. It is sometimes a contact that has to be shorted out with the jeweler's screwdriver, or it is a contact that has to be shunted, or etc., depending on the model. Maybe if you call the support for the watch they will tell you this. Normally they do not like the user opening the watch.
Feb 10, 2018 | Polar AXN300 Heart Rate Monitor Watch HRM...
Hello , I own a timex iron man triatholon model no t5g691 , the problem is none of the buttons work . they only work when I press them all together to turn it off . I also went recently swimming with it...
this problem occur only if one of the buttons are stuck inside, because you cannot push two or more buttons at the same time unless that you have to reset the watch. 2nd probably the buttons of your watch didnot reached the contact inside, sometimes it needed to be cleaned and had to be lubricated. if still did not work. reset your watch using the reset button inside the watch. i hope this will help you a lot.
Sep 13, 2011 | Timex Ironman Triathlon Solar Powered...
How do I reset the chronograph? Once I start it I can't find a way to reset it.
In heart rate mode, click reset to go to Calorie burned mode. In that mode press and HOLD reset button and this should reset all lap,calorie data. etc
Jan 06, 2011 | Sportline 1010 Duo Heart Rate Monitor...
I have an aquatech watch and don't know how to set it.
Thank you for contactng FixYa.
Setting the Time and Date
  • To set the time and date on your Aquatech watch, begin by pressing the "Mode" button three times to access the time setting screen. Use the "Lap/Reset" button to set the hour on your watch. Use the "Start/Stop" button to advance the numbers to reach the correct hour. When you've set the hour, use the "Lap/Reset" button to set the minutes, using the "Start/Stop" button to advance to the correct minute. Repeat the procedure to set the seconds, month, date and day of the week on your Aquatech watch.
  • Setting an Alarm
  • To set an alarm on your Aquatech watch, begin by pressing the "Mode" button two times to access the alarm setting screen. Use the "Lap/Reset" button to set the hours place, using the "Start/Stop" button to reach the correct hour. Repeat the same procedure to set the minutes for your alarm. When you have finished setting the alarm, activate it by simultaneously holding the "Lap/Reset" and "Start/Stop" buttons until the alarm icon appears. When the alarm sounds, silence it by pressing the "Lap/Reset" button.
  • Deactivating the Hourly Chime
  • Many Aquatech watch models feature an automatic hourly chime. This can be inappropriate and inconvenient in many situations. To deactivate the hourly chime on an Aquatech watch, simply press and hold the "Lap/Reset" and "Mode" buttons simultaneously. After you have correctly deactivated the hourly chime, the hourly chime indicator icon will disappear from the watch's main screen.
  • Best regards. Jewel
    Sep 18, 2010 | Watches
    Timex Ironman 30 lap heart rate does not display
    the battery type is written on the back of the watch.
    Jul 12, 2009 | Timex Ironman Tri 30 Lap Sleek T59671...
    I have an Athletic Works watch and can not turn off the alarm.
    the mode button controls the different functions of the watch.  time, alarm time, stopwatch, timeset, alarmset, in a repeating cycle.  Make sure you are on the time function (seconds ticking and changing every second, but not flashing twice per second.  This is the normal mode that shows the time.
     A press of the lap/reset button (labeled) will show the alarm time, Unpress will show the time of day. Press again toshow the alarm time. Press and hold the lap/reset button will show the alarm time again, but it will hold there.  While holding this lap/reset button, press the start/stop button (labeled). This will turn on (or off) the alarm (tiny indicator).  Press this start/stop button repeatedly (while still holding the lap/reset button and you will see the indicator turning on and off with each press.  Stop this button pressing with the indicator OFF, let up on the lap/reset button, and the time will return to the screen.  The alarm will now be OFF.
    Jan 24, 2009 | Casio Sea-Pathfinder SPF40-T Wrist Watch
    I have a mio euorfit heart monitor watch. During my workout I
    Yes, you definetely need battery replacement.
    As the hart rate monitoring is most sophisticated part of the device, it has more IC (Integrated Circuits) than any other features.
    More IC's means more power is needed, so, if the heart rate monitor is starting to malfunction, that's the very first sign of underpowered battery.
    Find your nearest watch repair shop and ask for battery replacement.
    Do not forget to rate, please.
    Jan 23, 2009 | Mitac Mio Fit Heart Rate Watch
    Setting a generic one-button digital watch
    I too lost the instructions for my generic 4 button digital watch and had to find the functions by trial and error and the results are below.
    Adjust Alarm/Time/Date - Press and hold Mode Button. When alarm displays, release. Start-Stop Button SELECTS, Lap-Reset Button ADJUSTS selection. Pressing the Mode Button again changes from Alarm to Time/Date, ADJUST as above. Pressing it again exits.
    Select/Deselect Alarm, Hourly Chime or Both - Press and hold Lap-Reset Button, Start-Stop Button TOGGLES through the above options.
    Select 12/24 Hour Mode - Press and hold Lap-Reset Button, Mode Button TOGGLES through the above options.
    Select Stopwatch - Momentarily press the Mode Button, use the Start-Stop and Lap-Reset buttons to control.
    Display Date - Press Start-Stop Button in normal time
    display mode.
    Display Alarm - Press and hold Lap-Reset Button in
    normal time display mode.
    Cancel Alarm - Press Lap-Reset Button in normal time
    display mode to silence alarm.
    Hope this is helpful,
    George.
    Nov 06, 2007 | Watches
    Watches Logo
    18 people viewed this question
    Top The Watches Experts
    D. E. Hev
    John mullen
    vince
    Are you a The Watch Expert? Answer questions, earn points and help others
