Creative SBS 5.1 560 wire connection on PCB board.
I have Creative SBS 5.1 560 and wire from board has been cut by a mouse.Hence i am trying to soldering wire again so can you please help me by suggesting which color of wire and where to solder on board.
SOURCE: need help for hs-23 headset repair
In this middle section, the wires are as follows: MIC+: Yellow MIC-: Black L+: Blue L-: Copper/Grey Stripe? R+: Copper R-: Copper/Grey Stripe? (same as L-, they should be interchangeable...) Sirial?: Yellow/Orange Stripe Uout: Red GND: Green Hope this helps!
Posted on Jun 08, 2008
  • 515 Answers
SOURCE: New RCAS on Technics 1200 Getting a Loud Buzzing Noise
It is not suggested that you remove the ground cable. Performing the mod for the ground by soldering a bridge on the circuit board doesn't really do anything either than remove that buzz/ground hum. You've essentially removed the wire that grounds the turntable cabinet to the earth. The buzz is gone, but now your turntable is no longer grounded properly.
I would suggest replacing the ground cable to it's original state, then attach the Monster cables.
If this does not work, then either there is an issue with the soldering to the board, or the board itself might be damaged. You might want to look at the trace paths to make sure none are lifted, or damaged in any way on the board. Another issue might be faulty tonearm wires or not properly soldered wires.
FYI, monster cables are not good for this purpose. I would suggest the following cables:
Technics DJ Repair Videos
Technics DJ Repair
Technics DJ Parts
DJ Parts
DJ Equipment Sales
Audio Video Accessories
Posted on Apr 30, 2009
  • 221 Answers
SOURCE: repair wiring on weller soldering iron model ec1002
If the coil wire is snaped then you will need to replace all the coil. usually the power from the outlet goes stright to the coil and connects to both ends of it's windings
Posted on Jul 24, 2009
SOURCE: N73 camera switch problem
n 73 camera swich not working problem plz help me
Posted on Sep 24, 2009
SOURCE: Wires came loose of control unit from circuit
Rotate the iTrip AutoPilot FM Transmitter controller so that its buttons are facing up and its data cable is on the left side. The data cable wires attach to a row of contact points along the left side of the circuit board as follows (from top to bottom):
1 = Purple
2 = White
3 = Blue
4 = Red
5 = Black
6 = Brown
7 = Green
8 = Yellow
9 = <unused>
Posted on Apr 22, 2010
Can i use AC Adaptor that has input: 230V-50Hz output: 9VDC to Creative SBS 2.1 370 Speaker?
The Creative SBS 370 Works on 11.5V AC (IT IS NOT DC) 1600mA (Means 1.6 Ampere) and 18.4VA. So, the Power Adaptor which you connect to the power socket behind the woofer is an AC ADAPTOR and NOT A DC ACAPTOR.
Nov 02, 2011 | Creative Labs SBS 370 Computer Speakers
Creative SBS 2.1 370 Speaker. hello how are you today, i have a question regarding the wiring in the volume on and off switch in the Creative SBS 2.1 370 Speaker setup, ive lost the little contoller some...
posted by Sandeep Sharma
hai, Here is the solution. when u cut the PCB from both sides u will find 4 cables i.e. green blue yellow and a copper wire coming from woofer and 3 cables white, red, yellow coming from audio lead. connect the green cable to copper cable and yellow to blue coming from woofer. Now take white cable coming from audio jack.connect this with yellow blue cables of woofer. Now attach Red and Yellow, connect these to green and copper cables of woofer and enjoy. if problem persist then make experiment to make interchanges with red white yellow coming from audio lead to the 2 sections of woofer side. woofer connections green/copper and yellow/blue remain same.
Aug 30, 2011 | Creative Labs SBS 370 Computer Speakers
A creative speaker SBS A200 connector pin was damaged. we need to connect that cable directly into the we need that pin details.
Hi, I hope this helps,
Pins look like this: (Top view, not copper side)
1 2 3 4 5
6 7 8 9
1 = Thin white wire from thick white cable (Left input)
2 = Gray (Speaker out)
3 = Orange (+V return from volume unit to bass unit)
4 = Not connected
5 = Thin Red wire from thick red wire (Right input)
6 = Blue (+V power from bass unit to volume unit)
7 = Black (GND - if socket removed, solder 3 socket shield holes to each other or solder black wire directly leftmost hole)
8 = Not connected
9 = Shield copper from thick red wire
Shield copper from thick wire : Solder to GND or Left unconnected
Jun 23, 2011 | Creative Technology SBS A200 2 Speakers
I can not find the drivers for Creative SBS 380
Hi lorenzogoode
You don't need drivers for these speakers : it's a plug and play system .
Check your connections , power supply and volume settings .
Best regards ,
fanaudi .
May 25, 2011 | Creative Labs Creative SBS 380 2.1...
Creative SBS 2.1 370 Speaker - Volume Remote Controller not worki
Hi Arun!
Try to plug your speakers to an iPod or any MP3 Player to check if there's sound. If there is sound, then try plugging it to the green port at the back of your speakers.
If it doesn't have sounds then you need to buy a new speaker system.
Jun 05, 2010 | Creative Labs SBS 370 Computer Speakers
Have you checked on the PC that its not muted.? There is normally an icon at the bottom of the screen which looks like a speaker if you right click on it, it will give an option to open the volume controls. Check this to see if sounds have been muted.
Mar 13, 2010 | Creative Labs SBS 370 Computer Speakers
I just got my creative sbs 5.1 70 watt speaker 2 moths before.....everything was working fine but when other day i left the speaker on for 1 night the other day i tried to play it but the power was not...
Make sure all of the speaker wiring is seated fully in each connection point on the PC and speaker components themselves. Also, try leaving all of the speakers unplugged for a short while (1-2 hours), reconnect it all, then try again.
Feb 14, 2010 | Creative Labs SBS 580 Computer Speakers
Subwoofer problem
the wires inside may be the problem, or sometimes it is from it`s mainboard, ask an electrician to take a look inside
Oct 29, 2009 | Creative Labs Creative SBS 380 2.1...
Creative 5.1 sbs not working on mother
try to download the necessary drivers and reinstall
Jun 10, 2009 | Creative Labs SBS 560 Computer Speakers
55 people viewed this question
