Question about Toshiba Televison & Video
Nee access codes for Toshiba HDTV MODEL NO.MW24FN3( )-R using radio shack universal big button remote cat. no.15 310
    Top Expert:
  • Toshiba Master
  • 75,386 Answers
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. The site has set-up code list & set-up procedure to many popular brand remote controls. The site has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Set-up code list to many brand remote controls also is given. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote.
• Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device.
Search the site by type in the "brand name" to your device; to which you want set-up codes; in the "Search box at the top right of the display window" to get gathered related posts.
Posted on Jan 03, 2017
SOURCE: code needed
Here's the link to the Radio Shack product document support. It has all the codes and how to info.
http://rsk.imageg.net/graphics/uc/rsk/Support/ProductManuals/1502200_PM_EN.pdf
Posted on Jan 02, 2009
SOURCE: Radio Shack HDTV remote codes for a (15-135) That
radio shack HDTV remote..need codes for vizio
Posted on Oct 14, 2009
xdmann
  • 43 Answers
SOURCE: i need the code no. for the universal remote
http://www.remotecentral.com/cgi-bin/files/rcfiles.cgi?area=other&db=devices&br=radioshack&dv=universalremote&md=1521473in1easytouse&kw=&st=&ar=&dt=&so=date&pg=1&file=others/radio_shack/152147-manual.zip
Check this out. Has all the codes for that remote. Download it for free. It's a pdf file.
The Toshiba TV codes listed here are:
0154, 0156, 0093, 0060, 1945, 1935, 1918,
1704
Posted on Feb 14, 2010
Testimonial: "thank you very much.. answered by questions."
  • 7 Answers
SOURCE: I misplaced my booklet with
Hi what exactly is it you need to do. Reprogram your remotes?
Posted on Sep 21, 2010
  • 11 Answers
SOURCE: hello I need the manual
Try this. It is a pdf fleRC Files: Miscellaneous - Radio Shack 15-2147 "3-in-1 Easy-to-Use" Universal Remote by
Posted on Sep 25, 2010
Tevion big button remote codes
The Tevion ARC 2030 (Sold at Aldi) is the same as the Radio Shack 15-310. Took me a bit to find it. Cut and paste this link into your browser for the manual: http://data.manualslib.com/pdf3/68/6702/670162-radio_shack/15310.pdf?9eafcf5e4d4c0046c669d595596d16fe&take=binary
Dec 02, 2012 | Big Button TV Universal Remote
Hi, I have a radio shack remote cat. No. 15-302 & a I lost my remote to my Toshiba model # 27AF45. How can I program it to my Toshiba? Also it 'WAS' programmed to my Insignia. HELPP!
There are a lot of codes for Toshiba TVs: 021, 028, 030, 032, 033, 035, 036, 052, 063, 096,
102, 123, 125, 127, 128, 136, 137, 191, 230, 239, 241, 257, 275, 283, 312, 318, 320, 328, 422,
440, 473, 507
With the Toshiba TV on and the remote pointed at the IR sensor of the TV, press and hold Set and then press TV. The LED will light up; release both buttons. (caution holding the buttons for longer than 3 seconds or the auto search will start) Press each digit of the code to try (the device key will blink with the key strokes and go off after the final digit is added). Check if the remote controls the TV (check the features you are sure to use like changing inputs). If it works, stop. Otherwise repeat from the press and hold Set with a different code.
If those codes don't work, then you can try the auto search or the manual search feature.
You can find the manual and code list here: http://www.radioshack.com/product/index.jsp?productId=3964905#tabsetBasic . (The pdfs there are available in English (EN in the file name) or Spanish (ES in the file name).)
I hope this helps.
Dec 24, 2010 | Radio Shack 3 in 1 Universal Remote
Toshiba Regza 32C3000A tv sound keeps droping out, the mute button when pressed on and then off brings it back on. seems as if the tv is auto muting itself?
Could be a contact piece of the MUTE button from your remote that is causing it.
Go out and Big Lots or Radio Shack to get a cheap universal remote control(big lots would be between $5-$10) Pick up the code for it,and when the tv happens again,your the OLD remote MUTE button to turn it back on and then put away this remote control and use the new universal remote control.
However,if the problem is coming from the manual MUTE button on the TV,you need a repair tech, to fix it!
solutiondoct
Nov 10, 2008 | Toshiba Televison & Video
I am trying to find a universal remote code to control the new Zenith digital tv tuner converter box. The model # is DTT900. It is for a person with low vision who cannot see the buttons on the remote...
Pls post back with the brand and model of the universal (replacement) Remote Control or what remote control you would want to use with the Zenith DTT900 Digital-to-Analog Converter Box.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Oct 23, 2008 | Televison & Video
Code and instructions foremote radio shack 15-2114
I lost my manual for my remoet cat,no, 15-2114. Could someone help me with the code for a hitachi 60" TV?
fandrewszion
Jan 11, 2008 | Radio Shack 15-2200 Remote Control
Open Questions:
I was given a 2007 Toshiba Regza LED television ( I believe it to be LED just because of the Year 2007.) I have the television plugged into the wall standing alone with nothing connected to it no wires no cable boxes nothing. When I push the power button on the side it goes on because the green light is on the bottom it's not flashing but it is on okay. Now what's happening is I'm not getting any picture and I went on to shop Jimmy's and they recommended that I contact you. The back lights are on as I can see through the slots on the back of the television that there is light coming from there. The thing I'm trying to find out if I did the flashlight cuz I couldn't see any picture whatsoever and I don't know I turn the volume up as much as I possibly could through the side and also with the remote. I change the batteries in the remote of course to see make sure that they were working and I shine a flashlight on the screen I could see no picture whatsoever no menu picture no nothing and no sound. So my question is to you, after following shop Jimmy's recommendations it said that if you have your back lights working but you still have no sound or picture then you would need to replace one of two parts or both. I'm not sure what those parts are called I forget but my main question is how much is it to even get those parts and can I still get them. Like is it really worth doing that or should I just go and buy another television. Mind you to see me was given to me at no cost so that is basically the question would it be worth buying those two parts that they recommended and putting them in one at a time or should I just go get a whole new television remember I'm not which call Rich either so... If you could contact me with an answer that would be great please be specific as I am not what you call text Abby okay? I thank you in advance for your time patience and cooperation and helping me to answer this questions. I look forward to hearing from you! Respectfully, Stephanie Whitman PS can this television only be controlled by the remote. There are buttons on the side but to truly get the best quality of the television I would need to use the remote correct?
Jun 14, 2018 | Toshiba Televison & Video
Televison & Video Logo
29 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
