Question about Singer Sewing Machines
Hi there. I have a singer 507 machine which was sewing fine until I changed thread in bobbin and now the feeder teeth are not moving to feed thE fabric thru, not sure what I may have done - Help!
    Top Expert:
  • Singer Master
  • 48,235 Answers
The bobbin has nothing to do with the feed teeth
however it is possible that at some point you moved the forward /reverse knob lever to middle where the teeth will not move
Posted on Jan 03, 2017
  • 1 more comment
  • Pauline
    Pauline Jan 03, 2017
    Thanks Bill, not sure where the forward/reverse knob lever is?
  • Pauline
    Hi Bill am not sure where this knob / lever is?
  • Bill Boyd Jan 03, 2017
    go google and type in --user manual for singer sewing machine model 507-- and see if there is a pdf version for download
    that will show you where all the controls are and what they are for
Singer - 241-12, bobbin thread not stitching
I have a 241-12 Singer. New to me. It was running great. Then the bobbin thread ran out. Put in one prewound bobbin that came with it, even though the bobbin appeared different. The bobbin thread didn't feed and the machine jammed up. I finally wound the old bobbin and put it in. It will only feed about 6" of thread before the bobbin thread breaks. It becomes so tight I can't get it to feed. Both bobbins will not feed. However I don't believe it's the bobbin tension because thread will pull through fine when pulled manually (if it hasn't been in the machine yet). What am I doing wrong?
Sep 15, 2013 | Singer Sewing Machines
What's your problem?singer simple feeder teeth
While attempting to engage the feed dogs with the switch, wiggle the hand while a little back and forth. Sometimes that motion will help it slide back into sewing mode.
Nov 03, 2012 | Singer 3116 Simple
Singer 507 sewing machine - material wont feed through
if the fabric won't feed thru then there is something wrong with the feed dogs
May 25, 2012 | Singer Sewing Machines
Feeder dog is in reverse and thread won't feed through bobbin..
it would really be a good idea to have the machine serviced at a sewing
machine shop
May 05, 2012 | Sewing Machines
Singer Electronic Control Sewing Machine 3343C--- The tread on the bottom of the fabric bunches up when sewing . The top thread OK What is my proble?
Hi Cat,
This seems to be a common problem, but easy to fix. Check the bobbin, and see if the thread feeds out quickly when holding the thread and letting the bobbin case drop. You should see a small screw on the front of the bobbin case for adjustment. Screw that until the drop rate is slight. You may need to adjust a few times to get just the right rate of feed.
Hope this helps, Please rate and comment, Thank You
Sep 07, 2011 | Singer 3343 Mechanical Sewing Machine
Singer 507 sewing machine is not sewing correctly on top of fabric, fine underneath, any ideas
Check your bobbin threading, it is usually the opposite of what you think.
Sep 13, 2010 | Singer Sewing Machines
Sewing machine won't raise the bobbin thread
Hi. The two main reasons why the top thread doesn't pick up the bobbin thread is either the needle is inserted wrong or the needle is bent. Since your machine was sewing properly until the thread broke, I'd be inclined to think the needle may have gotten bent. Sometimes this can happen if you sew over a pin.
Change the needle (making sure the flat side of the needle shank is inserted properly for your machine) and see if that solves the problem. Let me know if it helps, ok?
Jun 07, 2010 | Singer Sewing Machines
My Singer 507 sewing machine keeps on jamming up, the thread gets wound around the bobin and jams. I have thread the machine as in the manual. PLEASE, PLEASE could you help.
If you have the 507 with the grey or black plastic bobbin case you may need to undo the two screws on the right hand side on the silver bit and push it over to the bobbin case so it is tight or enough gap between the bobbin case and the silver bit about a thread width.
Apr 05, 2010 | Singer 5070 Mechanical Sewing Machine
I was using a Singer 9018 sewing machine, I rethreaded the bobbin, loaded it up and threaded the machine fine, but when I power up and start trying to sew, I can hear the machine motor going, but the...
Did you remember to tip the clutch on the end to being flat when you were done with the bobbin winding?
The disk tips to disengage the works while winding bobbins.
Dec 30, 2009 | Yamata FY101-1A
I have a singer model no. 507 (hush matic) but don't have a
You can find Singer bobbin winding instructions at
Singer sells manuals on their site (a few you can download for free) at
Jun 29, 2009 | Singer 5070 Mechanical Sewing Machine
Sewing Machines Logo
37 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
