Question about Miscellaneous
I just bought a dlp chip from you and the cable that goes from the main board to the dmd board ?that the dlp chip is attached is damaged I don't even know what it is called
Where can I get one
  • 2,189 Answers
This site does not sell anything it is a question and hopefully an answer site only (hopefully as some questions have been waiting years for an answer )
Posted on Jan 03, 2017
How can i tell if my dmd board or the chip on my samsung dlp hls-6187w has gone bad
Your problem is not the DMD nor the IC. Try part number bp96-01579a for color wheel. You need to use caution when replacing. The part and flat cable are delicate. Watch a you tube video to get an idea what needs to be done.
Jun 26, 2017 | Samsung Televison & Video
How to clean mirror and optics mitsubishi 73 dlp
You have to remove the lower panel on the back of your tv, then remove the light engine. Unhook the wires attached to the DMD board. Remove the DMD board. Remove the heat cink from the DMD board. remove the optical lens but don't touch the lens. There is a video on shopjimmy.com that shows the entire procedure. Takes 2 hours. The optical lens can be cleaned with an eyeglass cloth, same for the DLP chip lens. no wet solutions on lenses. Remove dust from other internal parts with compressed air in a can. Your picture will be clean and clear. Wear latex gloves and make sure you are grounded to prevent static electricity.
Feb 23, 2013 | Mitsubishi WD-73827 73" HDTV DLP TV
Bright white spots on mitsubishi wd-73833 I just replaced the lamp and now these bright white spots have started to appear!
This unit uses a DLP (digital light processor) chip and if this starts to fail then you will get spots appearing on the screen. The DLP chip will need to be replaced.
Mar 24, 2011 | Mitsubishi WD-73833 73" HDTV
Mitsubishi dlp tv WD65733 has white spots, like stars on screen, what causes this
If you get White or black dots all over the screen (DMD symptom)
If you get a pixilated picture (DMD Board)
Mar 27, 2010 | Mitsubishi WD-65733 65" HDTV
I have a DLP samsung Tv modelHL-T5075SX/XAA. Four weeks ago it started with a few white dots and now the sreen is full. A technician came and said that the problem is the DMD board. They said the are...
this is a failing DLP chip on the DMD board. I dont know if your model has the removable chip but most do. They will fix it for you but expect it again and again. Design of these TVs cause the UV from the lamp to damage the chip over time.
Mar 08, 2010 | Samsung HL-S5087W DLP TV
White spots are just emerging on my 50 inch Samsung DLP TV everyd
the problem is in the DMD Board is it something like this?
usually this happens to Samsung DLP...
here is a link where you can find a DMD Board Good luck
you will need your part number
http://www.discount-merchant.com/SearchResults.asp?Search=dmd
Aug 01, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
Samsung DLP HL-S4266W White dot problem
Its the DLP IC chip itself that is bad. The DMD board is where the chip resides but if you order a board, it will come without the chip. Its not cheap and the replacement is tricky because the DMD board must be removed and then an alignment of picture centering will be necessary.
michtech
Feb 12, 2009 | Samsung HLN5065W 50" Rear Projection...
White spots on screen of my Samsung DLP TV
What causes the DMD board to go out?
No Picture, but have sound
Had a new lamp put in this morning
TV now has 2 white spots
TV - bought in 2003 for $3600.00 and only used 5 months of the year
Jan 21, 2009 | Samsung DLP HL-P5663W 56" TV
Miscellaneous Logo
Top Miscellaneous Experts
Andy Fraser
Andy Fraser
Dan Grod
Level 1 Expert
dennis lewis
Level 1 Expert
Are you a Miscellaneous Expert? Answer questions, earn points and help others
