Question about Boating
I have a Mercury outboard in Australia, manufactured in Belgium, but no size marked. The only number I can find is 9546370. How can I find out its age and size?!!
5 Suggested Answers
  • 47720 Answers
SOURCE: i would like to know where the ignition timing
there are none . fixed ignition
Posted on Apr 25, 2010
  • 13 Answers
SOURCE: mercury 20hp outboard s/no oc178692 what year of
If It reads as most do it was built on first shift seventh run August 6 1992
Posted on Aug 15, 2013
  • 519 Answers
SOURCE: what year was my 8hp 2 stroke Mercury outboard manufactured
Should Be On Tag (under covers)
Posted on Mar 24, 2015
  • 47720 Answers
SOURCE: 1965 Mercury outboard motor, How to remove the fly wheel ? Thanks Roger
they made a flywheel puller for that purpose after the large center nut is removed..
Posted on Jan 29, 2017
1976 mercury v-6 1750 hp outboard igot the motor and the lower end was already taken off and there isa part I never seen besides the impeller its a little housing wioth a plunger typ thing on one in
Hey Mark,
Find your engine from this list.. then continue until you find the correct parts diagram that corresponds to what you are looking for...More info would help.. serial number, ID number. any numbers on any plate..
Find Mercury Marine Outboard Motor Parts by Engine Model
Jun 09, 2017 | Mercury Boating
I have a mercury 75hp outboard ser#OD020354 would like to know what year the motor is
QUESTION:
How can I determine when my outboard was built?
ANSWER:
Every Mercury outboard has a serial number label located on the transom bracket area of the engine. The latest serial number labels display a 2-digit number in a box at the lower right portion of the label. These digits coincide with the last two digits of the year in which the outboard was manufactured. For example, if an outboard was manufactured in 2010, the number "10" would appear in the box at the lower right portion of the label.
May 01, 2017 | Mercury Boating
What year is a evinrude outboard with serial number 1451821
The motor HP is critical in such searches. Here are all the resources you need to find the information yourself.
About this result
How To: Outboard Engine Serial Number Year Match, iboats.com How ...
www.iboats.com/basics/serial_number_year.html
  1. Cached
  2. Similar
For engines prior to 1969 refer the the Johnson 1960-1979 serial number year chart located here. If you have a commercial model refer to the Johnson commercial serial number year chart located here. Evinrude changed how they indicate year in the model number in 1980.Mercury Outboard · ‎Evinrude Outboards 1950-1979 · ‎Johnson Evinrude Commercial
[PDF]5006145_Model Number Reference.fm - Evinrude
shop.evinrude.com/media/document/ModelNumberReference.pdf
  1. Similar
MODEL NUMBER DESIGNATION - OUTBOARDS. Model Years 1980-1998. V E 70 T L ED A. MODEL VARIATION. A = Australia. B = Belgium. C = Canada.
Evinrude Outboard Motor Model Numbers & Codes - Marine Engine
www.marineengine.com/manuals/evinrude/
  1. Cached
  2. Similar
The nameplate should contain a model number and a serial number. The model number will identify the year and certain details of that motor. 1980-Present: Evinrude outboards from 1980 to the present use a model number that can help determine the year and features of the motor. See the model number code here.0.5HP · ‎0.9HP · ‎1HP · ‎1.1HP
Marine Motor Look-Up Guide - Auto Repair Manuals
www.autorepairmanuals.biz/page/599222
  1. Cached
  2. Similar
keywords: Find year, serial, number, model, number, #, outboard, motor, marine, motor, look-up, Johnson, Evinrude, Mariner, Mercury, Force, OMC, Yamaha, ...
EVINRUDE OUTBOARD MOTOR MODEL YEAR LOOKUP GUIDE ...
www.maxrules.com/models/OMC_models_files/EVthru79/ev_index_79.html
  1. Cached
  2. Similar
WHAT YEAR IS THAT OLD EVINRUDE? FIND OUT HERE ON OUR MODEL YEAR LOOKUP CHART! evinrude outboard with serial number Google Search
Nov 29, 2016 | Boating
Finding year from a ssrial number on a mercury out bord
go google and type in--- mercury outboard serial numbers -- there are sites that listhp against serial numbers against year of manufacture
while you serial number may not be listed they state that the beginning of the number to the next changing number is the year of make
for example ---4261012 to 4302999 ( next number 48103665,year 2002) may be year 1999 so your number would be a 1999 model
The information provided will take a bit of understanding as it appears that the manufacturer changed the method a number of times
talk with a mercury / mariner service shop as they will have the information on hand
Sep 26, 2016 | Sierra Tilt/trim Motors, Outboard...
What year is a johnson 4 hp outboard serial number b 7643180 model number bj4brccs
To get the year of Johnson and Evinrude outboards use the word "INTRODUCES". Each letter corresponds to "1234567890" respectfully. It's best to check with a model year reference book, but this motor's model number contains "CC" which would indicate it's a '88.
Sep 21, 2014 | Clymer Evinrude/Johnson 2-70 HP Two-Stroke...
What is the year of a mercury marine serial #08308043
Aug 18, 2013 | Computers & Internet
Serial Number 1001499 Model Mark 25 Mercury Outboard what year?
pinched rom another website:
Jan 06, 2013 | Boating
Were can i find out what kind of outboard i have by the searl number
There is no universal, centrally held, outboard motor serial number record. But most manufacturers will keep records, so look for any manufacturer identifying marks (if the cowl labels have weathered away then under the cowling there will usually be markings).
Contact the manufacturer with a polite enquiry and you'll find out what you need to know.
Oct 24, 2009 | Bass Pro Boating
Boating Logo
111 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
