Question about Sharp Office Equipment & Supplies
F 2 flashes alternatively in Sharp 5618S copier
  • 990 Answers
SOURCE: sharp copier model SF2530 F1 flasing and copier
Hello sir; F-1 is sorter problem, did you connect sorter with machine, turn power off and check th connecter .
Posted on May 15, 2009
  • 1447 Answers
SOURCE: I have sharp AR-5316E copier, the indicator is
it is the problem your copier fuser unite problem thermostater or heat roller is over temparature . You press # interrupt c inturrupt then 24 press print key 00 then machine is of after on is ok
Posted on Jul 15, 2009
  • 29 Answers
SOURCE: My Sharp AR - 2005 copier flashes H and 4
A H4 code on this machine means a Thermistor issue.
The thermistor messures how hot the hot section gets indide your machine. This code is re-setable though =]..
If it is the machine im thinking of, it is actually a AR-205.
To get into service mode press
*** c, (int), 0, (int) ***
>> (Clear, Interrupt, Zero, Interrupt)
The screen should then go blank,
Simply enter "14" then press the copy button.
The machine will reset, and the code will be gone.
If there is something seriously wrong with the thermistor though. The code will come back fairly soon, and in that case you will have to get a Authorized Sharp Agent to replace this part =]
Posted on Aug 19, 2009
  • 10 Answers
SOURCE: Error code H4 flashing alternately. AL-1641CS Sharp Copier
replace heating unit (fuser) it is not warming up
Posted on Jan 06, 2010
  • 1110 Answers
SOURCE: My Sharp AL-1551CS copier is flashing L 3. What
Scanner movement failure. The scanner is the part under the glass that lights up and moves back and forth. So if you lift up the feeder so you can see the glass, turn the machine off for a few seconds then back on. Watch the movement of the scanner. It should move right and inch or two then back to the left. If all goes well the copier should come to ready. Lay a piece of paper on the glass and press the print button to watch the scanner movement. If it binds up or does not scan correctly there are 2 possibilities.
1) your scanner lock is engaged and is preventing the scanner from moving. Check the clear plastic dial located under the far left upper side of the copier, near where the paper exits the machine. Make sure it is in the unlocked position.
2) Your scanner rail is dirty and dry. This rail can be seen under the glass towards the back of the copier. The scanner rides on this rail. It is very common for these to get dirty and for the grease to dry up causing the scanner to freeze up on the rail. The glass must be removed and the rail cleaned and lubricated.
Good Luck and thank you for using Fixya.
Posted on Mar 15, 2010
Sharp ar 5618s f2 error
check the toner or drum cart. if third party replace with OEM
Jul 22, 2015 | Sharp Office Equipment & Supplies
Code for develpoer in sharp ar-5618s
to obtain developer code you should contact the manufacturer
Jun 04, 2015 | Sharp Office Equipment & Supplies
Why is my Sharp ar-5618s showing a green light on the mainboard?
green light on the main board normally mean good!!!! why looking at the main board???
Apr 07, 2015 | Sharp Office Equipment & Supplies
Please help me, how to reset or clear off Sharp Copier/printer AR 5618s Service Maintenance and Developer Indicator.
try pressing *,#,0,#, 24,2,yes or 1 to reset developer light (circle of dots) Then 20, yes or 1 to reset the little man light.
Dec 19, 2014 | Sharp Office Equipment & Supplies
Your problem is that you should not use refilled toner in you sharp copier but if you chose so you have to change also the chip in the end of the toner it will work fine
Jan 30, 2014 | Office Equipment & Supplies
No reset code ;once you replace with new toner it should be ok.
Do not switch off machine when replacing.
Jan 30, 2014 | Sharp Office Equipment & Supplies
Sharp AR 5618S Error F2
Hope this help.
Hold down the copy start button
You will get F2 flash then 2 numbers will flash
Jul 06, 2012 | Sharp Office Equipment & Supplies
To reset maintenance codes requires going into service mode. This should only be done by an authorized trained technician as changing or adjusting something in this mode could create all sorts of problems you dont want to deal with.
Mar 17, 2009 | Sharp AR-5316 Advanced Digital Imager...
Flashing "L1" error
A letter "L"  and a number "1"  appear alternately = The scan head locking switch is locked. Unlock the scan head locking switch.
Hope this helps. Good luck.
Jul 29, 2008 | Sharp AL-1217 Copier
32 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
