Question about Graco Air Tools & Compressors
A graco ultra nova 395 stand model airless paint sprayer Will packing go bad after sitting an extended period of time ? It is not a tool I use very often but I do like to have a quality tool ready
  • Todd Grantham
    Todd Grantham Jan 04, 2017
    I'm sorry I wasn't intending on giving you a 1 rating but it's my first time and I screwed up 5 * is better show me how to fix it
  • Bill Boyd Jan 04, 2017
    no matter -- if my answer was a help to you then that is all that matters
    Top Expert:
  • Graco Master
  • 47,745 Answers
Yes
the gland packing will go hard from the paint contamination ( even though you washed the unit properly)
the secret is to get spares now before they become hard to get
talk with paint shops as there may be something you can spray through the system to keep the packing and seals supple
Posted on Jan 03, 2017
I would like to know where to find the diagram for a graco nova model #390 pump
I have a copy of the parts manual for you, but its not a video or a photo, so I will try to send it as a photo.
Tried this but Fixya doesn't like it, so I will ask them how to send it, or you can send me an email and I can send it back to you.
Please keep by email address confidential:
david.dundas1@gmail.com
Mar 07, 2015 | GRACO INC 390 Stand Airless Paint Sprayer
Graco paint sprayer repair
Odd that you have air coming out of the suction, however it sounds like your inlet valve is not closing, the ball damaged or missing, or the O-ring under the valve seat is missing or damaged.
Aug 14, 2014 | GRACO INC Ultra Max II 795 Electric...
Trying to prime my 395 air assisted finish pro and I have fluid coming out of air holes in gun
I had the same problem. turned out I was using the rubber gasket on the tip saddle instead of the hard plastic one.
Aug 30, 2013 | GRACO INC FinishPro 395 Air-Assisted...
Prime valve repair
In all the paint sprayers I've worked on, I've only been able to repair a couple prime valves and they went totally bad a short time after that. They can be taken apart and cleaned up but in the long run you'll be much further ahead replacing it if it isn't holding pressure in your system.
Jan 17, 2013 | GRACO INC 258720 - Ultra Max II 695 Hi-Boy...
Graco x9 won't hold pressure
If it comes up to pressure but won't hold it when the motor stops, you have either damaged packings or a bad check ball-to-seat seal. If it's the check ball(s) not seating properly a real good cleaning should take care of it. If it's the packings the only remedy is to replace them.
Aug 11, 2012 | GRACO INC Magnum Pro X9 Electric Airless...
Graco magnum paint sprayer won't prime
Airless won't prime- I always start trouble shooting an Airless that won't build/hold pressure look at sump hose inlet filter (the hose that goes into the paint if its got paint debris on it clean off filter and pour the paint thru a strainer bag into a clean 5 gal bucket-also remove the filter housing on the spayer and clean and flush and replace filter and housing- the shaft or the metal sleave has two ball bearings called "check balls" that maybe stuck turn on sprayer and put a piece of wood on shaft and give it a few good taps this will knock the check balls loose if after all this fails then you need to have new packings put in becuase the old ones are worn this is pretty easy to see because the rod the compresses the paint will have signs of paint on it indicating that the packings are worn.. Note keep rod and other moving parts oiled ith graco throat seal and finally Graco sprayers with the X on them are there (Graco) home owner line of sprayers that sell at home depot they are rated for only a certain amount of Gal per year keep it in good condition and cleaned store with coro-check inside of the pump when you are done using it.....
May 27, 2012 | GRACO INC 232745 Magnum XR-7 3/4-HP...
Air Tools & Compressors Logo
290 people viewed this question
Top Graco Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you a Graco Air Tool and Compressor Expert? Answer questions, earn points and help others
