Question about Sony KV-9PT40 9 in. Television
Can this be fixed so color doesn't go off?
Can set be fixed so color doesn't suddenly go off every few weeks and stay bad for a few weeks?
Why are my photos taken with my iPhone 5 suddenly coming out off color and very dark?
First, I suggest you look into the camera lens. Perhaps it is not clean? Next, how does the preview image look before snapping the picture? If the preview is good then the problem may be in automatic post-process settings.
May 10, 2014 | Apple iPhone 5
Wd52525 yellowish color when static. Menu has some pixelation. Colors are off.
It does not matter---these sets are so bad (this one) they sell the entire chassis or the light engine which has the color wheel in it and last time I looked the wheel does not come unless you buy the engine.
May 24, 2012 | Mitsubishi WD-52525 52" Rear Projection...
Spin cycle doesn't work
bad drain pump or clogged drain line. some units have drain trap you can clean,if so you can clean it out yourself but will make a huge mess if you don't pinch close the drain hose between the tub and pump.
Nov 12, 2011 | Haier HLP21N Washer
2002 Pontiac Grand Prix - I put the key in and turn to start, I hear a click, then it doesn't start - in fact the entire car suddenly goes dead and the key gets stuck in the ignition. I can press the...
The first thing I would do is clean your battery connections very good. you may have to remove the plastic covers off the cable ends to get them cleaned good. Also make sure you get the connection bolts tight.
Sep 04, 2011 | 2002 Pontiac Grand Prix
My midland weather radio wr120 makes a loud beep about every 30 to 45 minutes. what is causing this?
I just caught mine in the act and the message was "BAD RECEPTION" - but it doesn't stay on the display very long, if you don't catch it right when it beeps, you'll miss it.
Sep 03, 2011 | Midland WR-100 Weather/RDS Radio
No picture no sound
something in the set is getting hot. there is freeze spray you can buy at electronics places.
open the set and run until it fails... spray a few components in the power supply and deflection.
see if it stays running.
warning in a C R T set the high voltage can be 28kvolts or higher .it can hurt or kill you.
the horizontal drive transistor runs on 160vdc and has spikes of over 2000 volts to drive the flyback transformer.
unless you really are knowing,it is best to stay out,they are dangerous
May 13, 2009 | Konka K3290U 32" TV
TV colors distorted
make a degosing coil or try to look for a website how to make it in the phillipine we only make it coz we can't buy or its not available in the marker ok thanks that is the only solution you can do k
about akai tv may be it just coldsolder in crt socket try to solder it thanks inform me
Sep 10, 2008 | Televison & Video
Picture gone.
You have bad conv. ic's.On these sets when the ic's go bad it will usually pop a fuse or burn up a few safety resistors,causing ith video to go away.
Mar 03, 2008 | Toshiba 50H72 50" Rear Projection...
Toshiba Plasma TV Green and Pink (Diffusion?) Problem
I could be wrong but sounds like your plasma display is going bad. What is your model number?
Dec 28, 2007 | Toshiba 42HP66 42 in. LCD Television
Will not stay powered on.
Unplug the convergence yokes and see if set comes on DO NOT leave set on for longer than 2 minites with the plugs out presumming the set comes on, if it does replace 2 x STK 392-110 convergence ICs
Aug 03, 2007 | Toshiba 50A61 50" Rear Projection...
Televison & Video Logo
19 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
