Replaced ac unit with new compressor. Fires up as usual but compressor wont start.No fault code coming on controller. Whats the problem?
    New Friend:
    A rookie expert who has answered 20 questions on their first day.
  • 20 Answers
Check voltage on compressor terminal if ok then electrical connection then check motor winding then check control devices (thermostat ....)
Posted on Jan 03, 2017
    Top Expert:
  • Heating & Co... Master
  • 48,272 Answers
Possible causes include
excessive gas
low gas
relay not working,
faulty thermostat
faulty start/run capacitor
bad circuit board
I have a Arctic King through wall AC model MWW-12ERN1-MI0 and the compressor will not engage to cool the air. Can anyone help me diagnose and fix this problem?
On the ac unit electric section, check for power at Y1, should have power, possibly to x or c ( common terminal).
Check for power across the compressor contactor, should have power or something is open such as a pressure switch or compressor protection. If there is control power at compressor contactor solenoid ( 24 volts control), then check for supply power on line side of contactor, then on load side of contactor (supply voltage e. g. 230 volts. If all voltages are present, then check the compressor for opens and electric continuity.
CAUTION: electricity is dangerous, can kill and/ or cause fires. Do not attempt if not aware of safety procedures.
Aug 08, 2017 | Heating & Cooling
Turned ac off while running well turned back on to soon
shut unit off and wait at least 5-10 minutes before re-starting. do not want compressor to struggle to start. good luck!
Jul 08, 2015 | Dometic Rooftop RV Air Conditioner
Compressor and fan comes on sometimes whats wrong
You question is confusing. Both need to come on folr the unit to work. Are you saying they come on all by themselves after you turned if off?
Do you have a remote control for the AC?
Jul 14, 2014 | Heating & Cooling
Fan will come on but compressor wont kick in on wall unit ac
The start capacitor on the compressor is bad. Replace it and the compressor will run.
Jun 30, 2013 | Heating & Cooling
Coleman mach rv roof ac, the fan comes on but the compressor doesn't, i've replaced all capacitors and stll is not comming on, how do i check voltage to the compressor to maske sure i have pow
At the compressor connectors you have a live and a neutral phase. The live usually goes to a ptc relay starting mechanism which you can test with a meter. If you can disconnect the relay and check the windings of the compressor from one pin to the other two it will tell you if the compressor is open circuit. It is more often than not an overload fault.
Apr 23, 2012 | Coleman Heating & Cooling
Ac unit wont come on the breaker was tripped, reset the breaker, checked the unit for 220 volts has the correct voltage. The unit is a split system heat on one side ac on the other. The blower motor wont...
maybe you have over current .compressor act over loud.
you wait was cooled compressor .than start again and check current and over loud and condenser fan.
Sep 06, 2011 | Friedrich WallMaster WS07A10D Air...
Had problems with vw caddy van starting when warm,...
2004 vw 2000sdi caddy van wont start some mornings you need to wind it over before it fires, immediately after it fires you can switch off ignition and it will start first time and continue to start all day. vw dealer says no fault codes present. gloplugs renewed, new battery,fuel problem? Has anyone come accross similar problem I
May 20, 2010 | Cars & Trucks
AC wont blow cold air/ 1996 dodge grand caravan es
the control module is bad it has an intermittant fault replace this and it will work fine
Aug 17, 2009 | 1997 Dodge Caravan
My blower blew a 3 amp fuse..i replaced it....the blower is running...but the ac wont kick back on
why did fuse blow thats what i would figure out? check for power at compressor it maybe locked up(you haft to reverse polarity to unlock)!! :)
Jul 05, 2009 | Heating & Cooling
Heating & Cooling Logo
43 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
