Question about Humidifiers
My honey well humidifier is on n filled with water but indicating yellow light n are is not coming out,is it not working?
  • 3 Answers
SOURCE: Humidifier control .
if humidifier was wired into thermostat circuit for power instead of seperate transformer , this can happen. you need to see if you voltage going to the solenoid valve. if you do , and it isn't opening, the valve is bad . this is assuming that it is using a # 50 relay to come on only when the fan runs . . make sure the water valve is open
Posted on Dec 28, 2007
SOURCE: Humidifier doesn't work as it used to,,,,,
First check to see if the two water sensing probes have been cleaned. After cleaning, if the problem still persists, try the following.
There is a small thermostat switch that sits on the heating coil underneath. This thermostat is designed to prevent the coil from overheating when no water is present. What probably has happened is the switch is doing what is designed to do but has become defective and is opening and closing at a lower temperature. So what is happening is the red light reset indicator will come on because this switch opens, the coil starts to cool and the switch closes and the light goes off. Because it is defective, this is occurring when it shouldn’t, causing this maddening on/off cycle.
Fortunately, this sensor is easy to replace if you’re handy. Make sure you unplug the humidifier from power. Turn it over, remove six screws, and carefully lift the lid. Look toward the heating element and you will see a small button type device with two wires plugged into it and is attached with two screws off to the side of the element. This particular thermostat is obsolete and very difficult to find. However, there is an excellent substitute made by Stancor for around $5.00. Their part number is STO-325.
Remove the two screws and lift off the thermostat and slide the wire connectors off. Simply reverse the process for installation and be careful to replace the bottom lid, being careful not to crimp the wiring.
Posted on Dec 30, 2007
Soulvisitor
  • 1113 Answers
SOURCE: No water
Owners manual LINK
Posted on Jan 20, 2008
SOURCE: I have the 6 gallon humidifier and the red
The white plastic float in the bottom of the water well is stuck to the bottom. Just lift it up.
Posted on Dec 14, 2010
SOURCE: humidifier filled with water, but red light is on
If you overfill it, the red light goes on. just dump a little out and it should go green. Worked with my crane duck humidifier. Hope it helps
Posted on Jan 21, 2011
No water
well these dont work in winter 1st off if heater is on were u from try to wigle the water buket on it just right so sits in and turns on sum sensor toucjy the way they sit in
Jan 19, 2008 | Honeywell HCM-300T Humidifier
My humidifier all of a sudden just stopped working. Can you tell me of any common issues and their remedies for this humidifier ?
From the troubleshooting section of the manual (http://www.crane-usa.com/manuals/HumidifierManual2008.pdf):
Problem Humidifier power light is staying red and not turning green Humidifier is working than stops: ? Solution Ensure that water level sensor is assembled properly. ? Clean water float ? Call service center and request replacement water float ? If humidifier does not work at all: ? Ensure it is properly plugged into a power outlet. ? Check that the switch is in the ON position. ? If Power On indicator light does not come on, bring to authorized service station.
Nov 01, 2010 | Crane Frog EE-3191 1 Gallon Humidifier
I tryt to turn on my humidifier tonight.1st the mist was coming out just little bi,but there was no green light on,like the manual sed and the humidifier was making some wird noises too.
Welcome to Fixya!
  • Ensure that the water tank cap is secured properly to water tank.
  •  Empty out water in water basin. Place filled water tank on to empty water basin.
  •  Clean Water Level Sensor.
Hope this helps!
Oct 26, 2010 | Crane Elephant EE-3186 1 Gallon Humidifier
Humidifier filled with water, but red light is on
Feb 01, 2010 | Crane Humidifiers
What does the yellow light mean?
when the light changes to yellow it is just adjusting to the newly added water. If you let it run the light should turn back to green. I think the light is only indicative of water level. I've had this humidifier for over a year and only gotten a yellow light once. It turned green after some of the water in the basin drained. Hope this helps
Dec 13, 2008 | Crane Cow Humidifier
Got it on Craigslist
The red light indicates that there is no water in it. You need to put water in it, then a green light comes on instead. When the water runs out you will see the light turn red again. You need to fill it about 2/3 - 3/4 of the way up to make it last.  You should refill it about once a day or every 2 days depending on how often you use it. But when you see the red light on then you know the water is gone.
May 03, 2008 | Crane Frog EE-3191 1 Gallon Humidifier
No steam comes out
I just took mine apart and cleaned the scale off the heating elements. Filled to the level with hot water and it was steaming good in about 2 mins.
Mar 01, 2008 | Vicks V150SG 1 Gallon Humidifier
Dec 24, 2007 | Aprilaire 700 Humidifier
Humidifiers Logo
60 people viewed this question
Top Humidifiers Experts
Paul Carew
Dennis
Are you a Humidifier Expert? Answer questions, earn points and help others
