Question about Vacuums
Rug doctor deep carpet cleaner won't spray from the base. The water tank is full and when I turn it to rug the brushes move but make a loud noise. Checked sprayer but doesn't looked clogged.
Sprayer doesn't look clogged from looking at it. The back "extra" sprayer won't spray water either but the hand tool will. Any suggestions? This unit is less than a year old.
2 Suggested Answers
  • 78010 Answers
SOURCE: Can you provide for me a wiring schematic for the sprayer button on a mc-2d rug doctor carpet cleaner?
Sorry no have.
Posted on Oct 14, 2016
Rug doctor deep carpet cleaner leaks the clean water solution out the bottom so quickly I can only clean a very small section of carpet per tank. You can watch it pour out
You have a crack or hole in the container holding the clean water solution. Also check any hoses going in and out for integrity.
Aug 26, 2017 | Vacuums
WILL i HARM the hardwood floor under my Area rug to be shampooed. No pad underneath
Simple answer: YES
Anytime you are sampooing anything the under surface will be exposed to the cleaner. Move throw rugs to a location safe for the cleaner. Kitchen floors are usually good for this or a concrete floor. Remember to let carpet dry completely before replacing it. It will be lighter when dry so easier to move. But as a glass on a wood side table leaving a ring a wet carpet can leave a shaped stain.
Jan 22, 2016 | Bissell 9500 ProHeat 2X CleanShot Upright...
I have a rug doctor carpet pro its red. Brushes will turn, hand tool will work but when on carpet won't spray water
Take it to your local vac shop for diagnosis. Sounds like a bad pump, or possibly a bad pump switch. It could also be a stuck diverter valve
Feb 19, 2015 | Carpet Pro Vacuums
Rug doctor will not spray what should I do?
check your spray pump is working a little pump inside machine is operating .check switch is working as well
Sep 02, 2014 | Rug Doctor Mighty Pro X-3 Ready Pack...
Rug doctor won't spray water
I had the same thing happen to mine. I looked at the hose in the water tank and the screen at the end if the hose was slimy and clogged. I took the screen off and cleaned it up, put everything back together and it works like new again. Only 2 screws and a screen.
Oct 17, 2012 | Rug Doctor Mighty Pro X-3 Ready Pack...
I have the hoover automatic dual vac 5. this is the 3rd hoover rug cleaner i purchased and always the same problem the spray underneth the rotator bars hardly dispenses and the floor hardly gets wet, this...
The carpet is not intended to get soaked, like what you see with a spray application. If you are seeing a stream of water in the nozzle/tank during the recovery stroke, this is working properly.
Jan 17, 2010 | Hoover Steam Vac Dual V w/ SpinScrub...
Will not spray
The heater is probally clogged. Remove the upper housing and locate a rectagular shaped object in the middle of machine. Remove six bottom screws and clean with stiff brush, clear all lines then run 3 tanks of hot water trhought he system to clear it.
Apr 10, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Hoover steam vac model F5853-900 series 17.9
Make sure that the recovery tank is completely close.
Oct 13, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Vacuums Logo
85 people viewed this question
Top Vacuums Experts
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
