Question about HP Photosmart C6180 All-In-One InkJet Printer
6180 will not print black text
I have the 6180 and can not get the black text to print. I have done numerous "clean heads" and also the "intermediate cleaning" done it in just black, etc. Still will not print black text. I have also uninstalled and reinstalled software. HELP
  • HP Master
  • 365 Answers
Are you using genuine or knock off inks?
Take out the blabk cartridge and knock in onto your hand while using a paper towel to absorb ink.
If ink comes out you have a communuication problen with the printer ink carriage or a defective cartridge.
Posted on Jul 21, 2009
HP 6180 Print Problem: I'm getting horizontal streaks when printing either in colour or black, Have cleaned the heads through the printers tool box and ued both levels of cleaning. Also aligned the pr
Fill an old black cartridge with hot water and scan and copy something with a lot of black on it. cleaned out my black ink clog after about 12 copies. Put new ink in and it's working fine. Oh yeah, use a syring minus needle to fill lower o-ring on back of cartridge.
Dec 26, 2011 | HP Photosmart C6180 All-In-One InkJet...
Only prints black ink text; cartridges full and good.
Run head cleaning and deep head cleaning for few times. If it doesnt help, you can try to remove print head, and clean the nozzles with distiled water.
And after that also run few times head cleaning mode.
Jul 17, 2010 | Canon PIXMA iP4000 InkJet Photo Printer
No black ink printing
Ah, solved already. Cleaning the black print head a few more times did it for me.
Mar 11, 2009 | Brother MFC-5840CN All-In-One InkJet...
Photosmart 6180 won't print black
Been ther and done all of the stuff Have pulled the ****** apart... wont go into detalis try copy black only sheet of text 12x20 times then run head clean I was getting white sheets output if no black run 25x3 times black only on copy then do head clean For me Voila! BLACK Inkypete
Jan 10, 2009 | HP Photosmart C6180 All-In-One InkJet...
H/P C6180 black not printing
Had the same problem for weeks. Had to go thru all three levels of print head cleaning in the HP Toolbox menu to get black to work again. The head cleaning option on the printer itself was insufficient. Unless you've already gone thru all three cleaning levels this may be worth a try.
I walked thru the steps via the HP website FAQs for the 6180. Basically: Open the HP Solution Center, select Settings->Print Settings->Printer Toolbox, then click Clean the Printheads. After the first cleaning you'll be asked if the test page printed OK (mine didn't), click the Intermediate Cleaning box. You'll be asked again if the test page printed OK (mine did, but an independent MSWord print test was still streaky), click the clean again (sorry, don't remember what this one was called) for the third and deepest clean.
This last one worked for me, now it's back to normal printing. From what the HP website says I'm guessing that my black print head was dried up. That's a reasonable explanation for my situation, we had let the black sit dormant for a couple of weeks after the black cartridge ran out before we tried to install a replacement.
Hope this helps, sure was frustrating for me. Good luck.
Nov 03, 2008 | HP Photosmart C6180 All-In-One InkJet...
Black text d not print
If the printer has been left for some weeks with an empty black cartridge then I suspect the print head is clogged.
To clean the print head, firstly remove it.
Remove each cartridge quickly and turn it upside down so ink does not drip out.
Flush warm water with a drop of detergent through the metal meshes at the bottom front inside of the print head unit. Continue untill the water coming out of the bottom of the print head is clear.
Then flush through with clean warm water for about 30secs.
Shake as much water as possible out of the unit.
Replace the cartridges quickly to avoid ink dripping out.
Undertake a nossle (head) clean on the printer until printing correctly.
Hope this helps.
Jul 20, 2008 | Canon PIXMA MP600 all-In-One InkJet...
Stripes on Images only - Text OK
Perhaps the CMY color heads need alignment. If you have not already done so, run a head alignment from the driver maintenance section. It will print out a page containing several lines and text, and request you select the closest-aligned images. After this is done, do another image print to check for improvements.
Normally, the printer uses the black cartridge for text and the CMY inks for images (even for black on photo and specialty paper). So when you are printing normal text pages on plain paper, only the black ink is used. A good check for this would be to print a normal text page, but select photo paper in the driver to trick the printer into using the CMY inks to make a substitute black text page. If this looks ok, then you are having issues other than cartridge alignment.
May 24, 2008 | Canon BubbleJet i560 InkJet Printer
Deep cleaned black nozzle several times, but still splotchy printing
I have the same promblem, after changing th print head.
It priints black if I change the paper to photo paper.
May 13, 2008 | Canon MultiPASS MP700 All-In-One InkJet...
Is it time to Replace my S200Print Head?
YES, IT IS EASY TO REPLACE THE CARTRIDGE, JUST PRESS DOWN A LEVER FOUND ON THE RIGHT SIDE OF THE PRINT HEAD AND EVERYTHING LOOSENS UP... YOU COULD ALSO CHANGE THE CARTRIDGE BY REPLACING IT WITH A BC-20 CARTRIDGE... IT'S A PURE BLACK CARTRIDGE.
Jan 05, 2008 | Canon BJC S200 InkJet Printer
HP Photosmart C6180 All-In-One InkJet Printer Logo
200 people viewed this question
Seeker5211
Seeker5211
