Question about Radio Communications
A MSR3007 with4 speakers works,installed rca cables into R and L out took this to headsets music comes from headsets and speakers. any way to shut off the speakers. Thanks in advance Mack
zzedly
  • 300 Answers
SOURCE: music won't play through speakers
Please provide more detail of your system's setup and connections. Thanks!
Posted on Mar 05, 2008
SOURCE: RCA 25110RE3-A cordless headset
Mine was doing the same and I just pressed the "find" button on the wall plug in thing- and the headset started working....you may want to try that.....?????
Posted on Sep 06, 2008
techniwiz
  • 275 Answers
SOURCE: cant hear from headset
niraj hi
well that was a mistake you did when u install the lg recovery disk
still you can contact the hp people and they will be able to send you the recovery ...
dont tell them what you have done ... just tell them u the recovery disk is not working and tell them that u are facing issue which u were facing when u tried the lg disk ....
byt the end of the call demand for a recovery disk ...
if the agent doesnt agree sending it ... ask for the suppervisor
Posted on Nov 14, 2008
PuterCare
  • 226 Answers
SOURCE: no sound speakers or headset driver install
Firstly check the volume is not low or muted on both windows and the speakers. In windows click the speaker icon in the bottom right of your screen, check the volume is turned up. Then click mixer or advanced and check that all volumes are turned up.
If using a laptop, check that the hotkey control for volume is on. You will see an audio icon on one of your ‘F’ keys, hold the Fn button located near the ctrl and press the volume function key.
Next open Device Manager from Control Panel and check there are no yellow exclamation marks on any drivers. If there are then you need a new driver.
If you are still having issues the sound card may be faulty, this is usually integrated into the motherboard. In a desktop PC you could buy a new PCI soundcard if you have a spare PCI slot in your machine.
You need to goto the manufacturers website, find their support section and there should be a list of drivers for your specific machine. Installing these should resolve your problem. I have a list of links to most manufacturers drivers on my website.
Hope this helps,
www.PuterCare.com
Posted on Jul 14, 2010
dunnbiker
  • 8546 Answers
SOURCE: RIght speaker not working in
Let's name the product and use FM for troubleshooting. Are you saying you have the Right Front and both rear amp channels/speakers not working? What DOES work?
Posted on Jan 17, 2011
How to hook up a laptop to play utube music
Buy a 3.5 mm-to-RCA audio cable (you will probably need a long one). Plug the 3,5 mm. end of the cable into the headset jack of your laptop and the RCA end of the cable into the RCA/composite (R/L) audio input of your receiver.
Dec 21, 2014 | Sony Str-k665p Am/fm Receiver Digital...
I accidently put the rca wires in the wrong audio input/output on my craig cd graphics karaoke player.Could this be why i have no sound?
The RCA outs are designed to send a signal to an external amplifier. That amplifier, in turn, sends the music signal to speakers.
The RCA inputs are designed to take audio signals from another device (like an ipod, CD Player, or computer) and play it through the Craig System speakers. If you sing into the microphone, the vocals will be mixed with the incoming music. However, in these cases, there won't be lyrics on the screen. If you play a karaoke DVD in a DVD player, connect the red, white and yellow RCA cables from the DVD out to the Craig Inputs, the lyrics should appear on the Craig screen while the music plays.
If you mistakenly plug RCA cables into the Craig Inputs and plug the other end into an amplifier's inputs, neither will produce any sound.
Using RCA outs is only necessary if you want to have louder music than the on-board Craig speakers can handle. Of course, you can run the yellow video cable to a TV RCA input to get a bigger lyrics window and the RED and White RCA to the TV RCA Red and White inputs to hear the music through the TV's speakers.
Aug 30, 2014 | Audio Players & Recorders
MTX Thunder 3401 not responding. Lit but no sound.
turn down music open sub box and put another speaker at wire and check again if work means sub is ok if not check the signal cable, and put there the speaker to try signal
Apr 05, 2010 | MTX Thunder 3401 Car Audio Amplifier
Amp 7541a amp was working fine, Took it out of one
REMOVE THE RCA INPUTS AND DISCONNECT THE SPEAKERS, THEN POWER THE AMPLIFIER UP WITH THIS NO INPUT, NO SPEAKER LOAD CONDITION. IF IT STILL GOES INTO PROTECTION AND YOU HAVE VERIFIED THAT THE POSITIVE AND ESPECIALLY THE GROUND CONNECTIONS, ALONG WITH THE REMOTE CONNECTIONS ARE 100%, THEN THE AMPLIFIER WILL NEED TO BE SERVICED. KEEP IN MIND, THAT DURING THE INITIAL TURN ON OF THE AMPLIFIER, THEY SOMETIMES WILL ILLUMINATE THE PROTECTION LIGHT WHILE STABILIZING THE POWER SUPPLY AND OUTPUTS, BUT AFTER THAT THEY SHOULD SHOW NORMAL POWER UP. IF YOU GET IT TO POWER UP FINE, THEN RECONNECT THE SPEAKERS AND IF STILL OK, THE RECONNECT THE RCA'S. IF IT IS STILL POWERED UP, THEN START TO TURN UP THE MUSIC. IF IT IS STILL POWERED UP AND NO MUSIC, THEN CHECK THAT YOU DEFINITELY HAVE A PROPER SIGNAL COMING FROM THE RADIO. LET ME KNOW IF YOU NEED FURTHER ASSISTANCE.....V
Nov 18, 2009 | Infinity Reference 7541a Car Audio...
How can I listen to music from my LG ENV 3 Using the Motorola H71
Your blue tooth does not have that capability .I check myself google motorola h710 bluetooth
Aug 26, 2009 | Motorola Mobility H710 Bluetooth Headset
Music won't play through speakers
Mar 05, 2008 | Alpine CDA-9855 CD Player
Only one speaker on hte headset is working
Even I have encountered the same problem with Logitech headset.Also my microphone is not working at all.
I thing I noticed that when I tilt the cable connected at the end of microphone towards the other direction both the speakers work as I hold the cable in that position.But when I release the cable only one of them works.
Jan 05, 2008 | Logitech 250 Headset
Speaker Failure
jamin is not silent.
jamin can vibrate but wont ring.
music works fine only if though a headset.
calls work fine only if through a headset.
was working fine playing music and then we tried to make a call after pulling out the headset and got no audio and as it was expecting a headset it wasnt picking anything up from the mic. maybe its a mic issue? ie mic died so jamin switches to headset? just thought of that so will investigate.
Nov 27, 2007 | i-mate JAMin Smartphone
Sound only coming from one side
you should have 3 leads going into you multi changer, two rca's and one bus lead. power up the unit and remove the first rca cable if the music goes off unplug the second rca and plug the first rca where the second was plugged in, if the music comes back on then the multiloader is working fine and you need to check the radio controller and its connections
Nov 06, 2007 | Sony CDX-646 10-Disc CD Changer
RCA RT2250 Chck Speaker message
I have the same problem... I read that it can be a capacitor issue, they are on backwards. I just dropped mine off with the repair guy today... Does anyone know of a fix? Mine first had an electrical zap, then smoked, now CHCK SPEAKERS then off, and on standby...
Jul 22, 2006 | RCA RT2250 System
Radio Communications Logo
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
