Honey well electric thermostat only goes on at 70
How long can honey last before going bad?
I was told by a bee keeper that as long as honey is kept in a closed container that there is not time limit as far as spoilage. He said it will keep several years with no problem. I have a container that is three years old and it is just as good as when I purchased it.
Feb 06, 2015 | Melvita Bee Hive Honey from the Pyrenees...
Thermostat is following a schedule when none is set
Your Lennox thermostat could be defective, but it may have been programmed by some inadvertent button pushing. The thermostat also has certain default settings such as a low limit that will trigger heating if the indoor temperature becomes too low (to prevent freezing of pipes).
Feb 09, 2014 | Heating & Cooling
Honey wire
Look for reset button push in and try to Program if this doesn't work time to replace T-Stat.
Jul 05, 2013 | Honeywell Programmable Thermostat Heater
Honey friedrich replaced with a honeywell RCT 8100
on some of the older models you must go into the installers program to make sure it is set for heating and cooling. also possibly gas or electric heat. and fan on during call for electric heat. these are all sellections in the installers program and usually they have one or more options for each sellection. see the installers guide for your tstat.
Nov 23, 2009 | Honeywell Electronic Programmable...
Car running sluggish volvo v 70 2001 comes goes
Check the thermostat in the air inlet to the air-filter.
(Replace it is probably what you need to do.)
Sep 28, 2009 | 2001 Volvo V70
My honey well thermostat keep clicking and I can't program it
If you have a programmable thermostat and it is a couple of years old you will probably have to install a new one. What kind of thermostat do you have? You can turn power off to furnace and then take thermostat off wall and take wires marked r & w and connect them together your heat should come on when you turn power back on. If not you could have blown the 5 amp fuse inside furnace. I would check the fuse inside of furnace. If you take panels off front of furnace you should find a controll board inside that runs furnace.If you have anymore question just reply back to me
Jan 07, 2009 | Honeywell Programmable Thermostat Heater
Wiring
On the Goodman control panel each wire is marked (on the PCB board) Y, R, B, W, Br etc. These should also be letters next to the screws for the wires on the thermostat. match the letters/colors to both sides.
Nov 08, 2007 | Goodman GMS90703BXA Heater
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
