Scanner door is open on display riso G3750, although the lid is closed! and I don't know how to fix it.
  • 518 Answers
SOURCE: faulty goodmans 1104s dab player
In the lid should be a mgnetic plate that holds the disc to the motor spindle (much like slight pressure would). Inspect it to make sure it's free moving and seating all the way when the lid is closed. I had one unit where the spindle on the motor shaft had slid down slightly causing the magnetic plate to not seat down all the way. Also, if the magnetic plate is removable, try placing it on the disc with the lid open and bypassed and see what happens.
Hope that helps...
Geno
Posted on Mar 06, 2008
JohnnyBeans
  • 223 Answers
SOURCE: close door read out appears
You have a problem with the door alignment and the door switch.. The slightest movement triggers the door switch. You should have someone look at what is causing this issue.
For service on your saeco espresso machine in the New York area: www.cerinicoffee.com
Posted on Jun 02, 2008
  • 258 Answers
SOURCE: Display shuts off when lid is closed
Right click on your desktop and select properties
Click Screen Saver
Power
In here you will find all the options to shutdown, hibernate etc. when on battery or adapter and also what to do when shutting the lid,
set these as required.
Posted on Feb 01, 2009
SOURCE: Lid switch location??????????
I had a similar problem with my HP/Compac nc4200. Every time I had had the lid closed, the display would be black for a couple of hours, and then work again. I realized that the machine belived that the lid was still closed, and started looking for the lid-switch but I could not find it! The answer is that there is no mechanical switch! In the lid by the microphone (3 cm from the left hinge) is a small magnet hidden and in the base unit by the switches is a magnetic sensor (probably a hall-switch). Over time the the metal next to the sensor has been magnetized by the magnet enough to activate the swith even when the lid is open. The solution was simply to take a magnet and sweep it over the area a copule of times, and suddenly the screen came back to life! I am not sure for how long this fix works, but now I know how to fix it again.
Posted on Mar 01, 2009
motor1258
  • 6674 Answers
SOURCE: door open display light is flashing when doors are closed
Check your buttons, levers, that are pushed in when door is closed, at your door posts. Use your thumb or finger and watch interior light go on & off as you push them in. If light flickers when in all the way, you found the bad switch. If they work o.k., check and see if maybe your door striker where door latch locks onto, needs adjusted in slightly to keep door tighter. Usually you can tell that if the door doesn't line up good when closed, with other door or rest of body. It will be sticking out slightly further.
Posted on Mar 27, 2009
Riso EZ 200E model gives error message A-01 -211
A-01-211 basically means there is master material under the position sensor while in standby. Referring to the manual open the master drawer and clamp rewind the master material back on it roll and close the lid/clamp. This allows the master unit to reset or to say "return home" action. Now open and re-insert the master material in its proper place. This is similar to A-34-218 code.
Nov 07, 2013 | Riso RZ220 Duplicator
Scanner error 12 on hp laserjet m1005
When the lid or door of an HP Laser Jet printer isn't properly closed, the printer's display will read "Error 12." You can usually correct an "Error 12" by closing the printer's door securely -- a process which may require that you first fix the orientation of a toner cartridge so that the door can close. In some instances, an "Error 12" appears due to some other issue, such as a missing toner cartridge or a defective paper-feeding component.
Apr 22, 2011 | HP LaserJet M1005 All-In-One Printer
My printer is not printing I need to know how to intall the ink
Hi Good day. Here are the ways to install the ink in your printer.
1 Ensure the All-In-One printer is powered on.
2 Lift the scanner unit or access door (
The cartridge holder will move to the center of the Inkjet or All-In-One.
3 Press down on the cartridge carrier latch to raise the carrier lid.
4 Remove the used cartridge. NOTE: If you are removing both cartridges, repeat the preceding two steps for the second cartridge.
5 Remove the protective tape from the back and bottom of the new cartridge(s).
WARNING! Do not touch the gold contact area on the back or the metal nozzles on the bottom of the cartridges.
6 Insert the new cartridges into their respective carriers. The image at right illustrates inserting the color cartridge.
7 Close the carrier lids so that they remain closed.
8 Close the access door or scanner unit, taking care to keep your hands out from underneath the scanner unit as it is being closed.
9 On some All-In-One units, the control panel display will prompt you to load paper and print an alignment page. NOTE: The scanner unit must be closed before you can start a new scan, print, copy, or fax job.
Oct 07, 2010 | Lexmark X5470 All-In-One InkJet Printer
Hotpoint washer - errotr message saying 'door' on display but door is properly closed have opened and closed it and turned off the machine to see if message will re-set but washer wont start you hear a...
if your model is a top load washer replace the lid switch likewise the same for a front loader you can find the lid switch and have it directly sent to you by looking up marcone appliance hope this helps if you are unable to make electrical and mechanical fixes plz call a technician although they usually charge between 125 and 189 for this simple install of a 30 dollar part
Jun 26, 2010 | Washing Machines
MFC8860DN SAY'S SCANNER LOCKED?? WHAT'S THE FIX??
Hello my friend.If you open the scanners door under the document cover is one switch that locks and unlocks the scanner.Move it to the position that shows that is unlocked.If this doesnt work it means the scanner lamp is in the park position and is stuck. You need to lean the printer away from the sheet feed side and bump it on the side. This should fix it. If it doesn't turn off the power and remove the two screws that hold the scanner lid on. Then remove the other 6 screws located under the lid on the left side while the lid is hanging from lid open sensor cable . After removing the base screws you can set the lid on the scanner again while you lift the scanner bed exposing the scan lamp mechanism. Push it a few inches in the machine and close the lid. You can do a test by powering the unit on and hold the lid open sensor button located on the bottom left of the lid. The system should initialize and bring the scan lamp back to the proper position. Turn off replace all screws and your done. If it doesn't work the first time push the scanner lamp more into the scanning area and repeat until works.
Feb 09, 2010 | Brother MFC-8860DN Printer
LG Top load fuzzy logic washing machine DE problem.
I have the same problem. please let me know if yours got fixed
Sep 11, 2009 | LG Washing Machines
Ink cartridge replaced on laserjet 1018 and nothing will pring, worked prior to cartridge was replaced
THERE IS A PLASTIC PIN ON THE FRONT DOOR THAT PUSHES THE LOCK TO OPEN THE SCANNER LID WHEN YOU CLOSE THE DOOR (IS BROKEN) OPEN THE FRONT DOOR AND CHECK CAREFULLY.
TO FIX IT YOU MUST PUSH THAT WHITE LITTLE LATCH WITH A SCREWDRIVER UNTIL YOU BREAK IT OR DISAPPAR FROM YOUR SIGHT.
Jul 28, 2009 | HP Hewlett Packard LaserJet 1018 Printer
I cant repair my riso
Need proper error code.. A letter should come before..
Apr 29, 2009 | Riso RZ220 Duplicator
Riso ks800
e4-ink over flow. solution-clean ink sensor.
e3-clamp motor locked. solution-use code 64
Sep 21, 2008 | Office Equipment & Supplies
k24674
jasbo
jasbo
