Question about Car Audio & Video
Earthquake sub remote control replacement - Car Audio & Video
2 Suggested Answers
  • 52 Answers
SOURCE: i have 2 12'' earthquake sub zero subs, i would
there is a web site that gives the equation
Posted on Apr 11, 2010
Sound is only coming out of one side of my earthquake sub. Could I have blown the other side? Thank you
That's certainly a possibility, but there are others, like a wire coming out of the terminal, etc. First step is to pull the speaker out and check it with an ohm meter. If there's no continuity it's blown.
Jun 11, 2016 | Earthquake Sound Audio Players & Recorders
2 Earthquake balls 12 subs specs for a vented box
Go to crutch fields website for sub box sizes and wiring it depends if you want vented ported enclosed sub box for your sub as to box sizes.
Oct 12, 2014 | Car Audio & Video
How do I set up a RX-V667 receiver to a Earthquake powered subwoofer? Will I need a special kind of cable?
The cable required depends upon the type of connector at each end. You could have an RCA connector on the rear of the receiver and terminals on the sub or maybe an RCA connector
Apr 13, 2013 | Earthquake MiniMe P8 8" Side-Firing...
Wiring power house phd2 mono amp to the earthquake 4 ohm speakers.
When i hooked up my bass knob the amp made my subs hum i unhook the rca but still humming unhook bass knob still hummin
Jun 12, 2011 | Earthquake Sound PH-D2 Car Audio Amplifier
I have a earthquake 700.1 amp with nothing else hooked up to but the power wire and remote and ground i am getting a red protection light anybody have a answer .
Your power supply is toast. Might be repairable at a electronics repair shop. But for an Earthquake amp I wouldnt waste the money.
Dec 22, 2010 | Earthquake Sound PH-700.1 Car Audio...
Visonik V12D4
i would wire the coils of each sub in series which would yield an 8 ohm resistive load per sub - and then wire the subs in parallel to the amp which would bring the resistance back to 4 ohms for a bridged load which will give you max power handling from the subs and draw the full power of the amp at the same time
Jun 18, 2009 | Earthquake Sound PH800W.2 Car Audio...
I have 15" subzero earthquake and i need to reconed
Usually the voice coil is bad on these subs...if your surround is rotted or torn - EXTENDING YOUR FINGERS PUSH DOWN GENTLY ON THE MIDDLE OF THE SUB AND RELEASE...Is it free? If not, forget the rebuild...If you need a kit for rebuilding the Earthquake...try Googling "Lesco Distibuting" in Orange City, FL and ask them who their closest Earthquake dealer is.
Good Luck
Jun 15, 2009 | Orion 15" Competition Subwoofer H2 15D4...
Earthquake eq-12 subwoofer parameters
I can't seem to locate the specs in my files or on line. From what I remember, you can use/build a sealed enclosure for each sub ranging from 1.5 to 2.5 cu.ft per sub. The larger boxes will play lower bass than the smaller ones at the expense of overall power handling and some efficiency. Ported boxes get a little more difficult but with some trial and error, they can be very effective. Even more so when tuned by the listeners own ear. Let me know if you need specifics on how to do this. Also General specs of your sub can be determined by knowledgeable audiophiles with a brief inspection. Perhaps a local electronics shop (if available) could help in this regard. Good luck and let me know if I can help further.
Dec 29, 2008 | Earthquake Sound EQ-SWS12 Subwoofer
Cant figure out my car audio problems!!!!!
There are a couple of tests you can perform. I'd first recommend checking the shield ground. You'll need an ohm meter. The details can be found on the following page.
RCA shield ground test
You can also test the output with the multimeter. Set the multimeter to AC volts. If it's not an auto-ranging meter, set it to a voltage range of ~2v AC. Disconnect the RCA cables from the head unit. Touch one meter probe to the outer ring of the head unit's RCA jack. Touch the other probe to the metal contact in the center of the RCA jack. With the head unit near full volume and a clean signal source, you should read at least one volt on musical peaks. If you have a bass disc or a test tone disc (~60hz sine wave), use those.
May 04, 2008 | MTX Thunder 8302 Car Audio Amplifier
Car Audio & Video Logo
32 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
