Question about Home Security
Can't slide open the back to replace the batteries
I need to replace the sim card
In almost every cellphone the Sim Card is located under the battery. Open the back of your phone where the battery is located and remove the battery. You should see the Sim Card that you want to replace. Most Sim Cards slide under a small holder. Gently slide the Sim Card out. Make sure that you are aware of how the old Sim Card is positioned so that you can simply slide the new Sim Card in exactly the same way as the old Sim Card came out. Replace the battery and close the back cover and you are finished.
Oct 05, 2012 | Motorola Mobility V950 Cell Phone
How do i replace the battery in the garmin streetpilot c330
Follow these steps : 1. Determine that you do have a Garmin GPS with a replaceable battery. Find the information by checking the manual or with a close inspection of the back and sides of the GPS unit. GPS units that have a battery that can be replaced by the owner will have a battery cover lock on the back or side; it looks like a small sliding piece of plastic with slots or ridges.
2 Open and remove the battery cover by sliding the battery cover lock and pulling off the battery cover. In some models, you may have to hold the lock up while simultaneously pulling the battery cover off.
3 Remove the battery by sliding the battery out of the battery cavity. You may need to use gentle pressure to get it to slide out.
4 Put the new battery in by sliding it into the battery compartment. Line up the metal contacts on the battery with the metal contacts in the battery compartment to make sure it is properly installed.
5 Click the battery cover back into place. The battery cover lock should automatically lock and secure the cover. If this does not happen automatically, slide the lock back to the locked position.
May 16, 2011 | GPS
How do i remove the battery out of my garmin 1300
  • 2 Open and remove the battery cover by sliding the battery cover lock and pulling off the battery cover. In some models, you may have to hold the lock up while simultaneously pulling the battery cover off.
  • 3 Remove the battery by sliding the battery out of the battery cavity. You may need to use gentle pressure to get it to slide out.
  • 4 Put the new battery in by sliding it into the battery compartment. Line up the metal contacts on the battery with the metal contacts in the battery compartment to make sure it is properly installed.
  • 5 Click the battery cover back into place. The battery cover lock should automatically lock and secure the cover. If this does not happen automatically, slide the lock back to the locked position.
  • Mar 01, 2011 | Garmin nuvi 1300 Car GPS Receiver
    Cant open my programmable key pad safe. the code wont work
    Locksmiths agree try replacing the batteries just slide open the battery cover located just below the keypad.
    Insert a paper clip or pen point into the small hole in the cover. Push in while sliding cover to the right. Disconnect and remove the battery holder. Insert the 4-batteries as indicated.
    reconnect the connector and put back the battery holder. Slide the cover back in place.
    How do I insert the batteries on my advanced electronic lock safe? On the newer model Fireproof Sentry Safes my locksmith recommended me To install batteries,
    turn the electronic lock case to the right and remove. Insert four new batteries as indicated, replace the electronic lock case and turn to the left to reassemble.
    Aug 12, 2010 | Sentry Fireproof Safe
    Need to change batteries.
    The middle part slides out.
    There are openings on two sides. One side has a larger opening than the other.
    Once you gently slide it out, you'll see the two batteries. Make sure the positive side is facing up when you put them back in.
    Just firmly push in on the tab that's on the side with the smaller opening.
    What you'll be doing is pushing it through, kind of like a little "tray" for the batteries.
    You'll see it'll slide out and expose the batteries so you can replace them.
    By the way, it takes two size 2032 lithium 3v batteries.
    May 15, 2010 | Salter 2001 electronic kitchen scale
    How do you replace batteries of a Sentry S0607?
    How to install electronic fireproof sentry safe batteries
    New advanced electronic lock safe battery replacement instructions
    May 05, 2010 | Sentry Fireproof Safe
    The Sentry V260 safe will not open. Replace batteries?
    Locksmiths agree on how to install sentry safe batteries
    reconnect the connector and put back the battery holder. Slide the cover back in place. How do I insert the batteries on my advanced electronic lock safe? On the newer model Fireproof Sentry Safes my locksmith recommended me To install batteries,
    Mar 11, 2010 | Sentry Fireproof Safe
    How to change battery in keyless entry remote
    For a 2008 Prius the "Best Solution" and "#2" are WRONG! If you pry it appart, that does not release the battery, and you have to glue it back together. There is a sliding cover, the piece with the Toyota logo on it. It is released by the same spring loaded locking slider that releases the "valet key". The cover slides in the direction of the bottom of the logo. Then there are four phillips head screws (jeweler screwdriver size) that open the battery cover. The battery is type CR2032.
    Sep 12, 2009 | Toyota Prius Cars & Trucks
    My Sentry S3807 just will not open. I have the combination right and the key, but it won't open. The batteries could be shot, I suppose, but how do I get in?
    How to install sentry safe batteries
    Aug 26, 2009 | Sentry Fireproof Safe
    Sentry S3807 safe-cannot open
    locksmiths agree on how to install sentury safe batteries
    to install batteries, turn the electronic lock case to the right and remove.Insert four new batteries as indicated, replace the electronic lock case and turn to the left to reassemble.
    Jan 26, 2009 | Sentry Fireproof Safe
    Home Security Logo
    Top Home Security Experts
    Lawrence Oravetz
    Are you a Home Security Expert? Answer questions, earn points and help others
