Question about Boating
Evinrude Engine 15hr Lec Start SR# E000 1790 MODEL H 159 4E
What year is a evinrude outboard with serial number 1451821
The motor HP is critical in such searches. Here are all the resources you need to find the information yourself.
About this result
How To: Outboard Engine Serial Number Year Match, iboats.com How ...
www.iboats.com/basics/serial_number_year.html
  1. Cached
  2. Similar
For engines prior to 1969 refer the the Johnson 1960-1979 serial number year chart located here. If you have a commercial model refer to the Johnson commercial serial number year chart located here. Evinrude changed how they indicate year in the model number in 1980.Mercury Outboard · ‎Evinrude Outboards 1950-1979 · ‎Johnson Evinrude Commercial
[PDF]5006145_Model Number Reference.fm - Evinrude
shop.evinrude.com/media/document/ModelNumberReference.pdf
  1. Similar
MODEL NUMBER DESIGNATION - OUTBOARDS. Model Years 1980-1998. V E 70 T L ED A. MODEL VARIATION. A = Australia. B = Belgium. C = Canada.
Evinrude Outboard Motor Model Numbers & Codes - Marine Engine
www.marineengine.com/manuals/evinrude/
  1. Cached
  2. Similar
The nameplate should contain a model number and a serial number. The model number will identify the year and certain details of that motor. 1980-Present: Evinrude outboards from 1980 to the present use a model number that can help determine the year and features of the motor. See the model number code here.0.5HP · ‎0.9HP · ‎1HP · ‎1.1HP
Marine Motor Look-Up Guide - Auto Repair Manuals
www.autorepairmanuals.biz/page/599222
  1. Cached
  2. Similar
keywords: Find year, serial, number, model, number, #, outboard, motor, marine, motor, look-up, Johnson, Evinrude, Mariner, Mercury, Force, OMC, Yamaha, ...
EVINRUDE OUTBOARD MOTOR MODEL YEAR LOOKUP GUIDE ...
www.maxrules.com/models/OMC_models_files/EVthru79/ev_index_79.html
  1. Cached
  2. Similar
WHAT YEAR IS THAT OLD EVINRUDE? FIND OUT HERE ON OUR MODEL YEAR LOOKUP CHART! evinrude outboard with serial number Google Search
Nov 29, 2016 | Boating
Need yr for evinrude E8RLNR
Bruce,
Do you have the serial number of the motor? Reason I ask is twofold. Evinrude started using this model number layout as of 1980. Having said this, something is not making sense with the location of the "N" in your model number. Those last two letters as of 1980 are the year. Here is the chart. Letter on top with corresponding year below it.
I N T R O D U C E S
1 2 3 4 5 6 7 8 9 0
So... Example
1980= CS
1990= ES
2000= SS
2010= IS
You have E8RLNR which breaks down as:
E= Evinrude
8= 8hp
R= Rope start tiller steering
L= 20" shaft
N= 2nd year
R= 4th year
I would expect to see the N in the last spot:
1982= CN
1992= EN
etc.
Serial number is another way to identify the year.
This may hep point you in the right direction. Hope it helps.
marineengine.com/parts/engine-model-guides/omc-johnson-evinrude-model-number-guide/omc-johnson-evinrude-model-number-guide-00004.html
Regards,
Fred
Sep 26, 2016 | Light Outboard Motor Boat Bass Fishing...
Identifying this outboard motor from evinrude, AQABVA71K899
Rob, AQABVA71K899 does not seem to come up as a valid # for referencing engine. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Outboard Engine Serial Number Year Match up
EVINRUDE OUTBOARD MOTOR MODEL YEAR LOOKUP GUIDE 1913 1979 MASTERTECH MARINE
Jul 11, 2016 | Boating
Evinrudeomc 6hp what year
Evinrude OMC Model#E6REIA. Year please.
Alice, 1991. Check the attached links,instruction and guides, Good luck
Find 1991 Evinrude E6REIA 6hp Outboard Motor Parts by Engine Section
1991 Evinrude Parts
Mar 24, 2016 | Boating
I need information on an evinrude outboard unsure of year or HP serial number is 4416-03315
Sounds like it could be an Evinrude Sportsman model 4416. Here's the info I found online:
  • Model: Sportsman - 4416
  • Make: Evinrude Motor Co.
  • Inboard/Outboard: Outboard
  • Engine Type: Gasoline
  • Production Date: 1947
  • Engine Design: Two-Stroke
  • Horsepower: 2.0
Check google search for pictures and more info on it!
4416 evinrude Google Search
Jun 16, 2015 | Boating
Boating Logo
119 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
