Hi I have a Deloonghi TI30arc air conditioner is it normal for the compressor to keep cutting on and of?
bobotfel
  • 236 Answers
SOURCE: hisense air conditioner
-If both compressor and fan motor starts and stop, thermostat is the defect.
- If only the compressor check for your outlet no sign of discoloration, check the voltage if normal, check the defective overload protector of the compressor it its external, or compressor itself is defective
Posted on Jan 04, 2008
Samspade30
  • 15 Answers
SOURCE: Air conditioner compressor clutch went out twice
The air conditioner turns on even when you don't use it. Like anytime you have your defrost on, it helps dry the air inside of your vehcile. So by letting the leak continue the clutch turns on then off on then off over and over instead of just kicking in and staying on. Yes, if you don not fix the problem it will continue. I wish I had better news for you.
Stan
Posted on Dec 26, 2008
daves944
  • 1050 Answers
SOURCE: put new water pump on, cannot get belt back on
Unbolt the pulley from the water pump, slip the belt over everything and refasten the the pulley to the pump while the belt is draped over it. Then tighten up the belt.
Posted on Mar 13, 2009
SOURCE: pac 35 split air conditioner not cooling
Could be:
- low on refrigeraant
- loose/burned/corroded compressor electrical connections
- bad compressor run capacitor
- tripped/bad breaker in main service panel
- faulty controller components/relays
- other...
If you don't have significant experince with similar appliances/systems a service call is in order.
Posted on May 08, 2009
  • 14036 Answers
SOURCE: replace air conditioner compressor
YOU HAVE TO TAKE CAR TO DEALERSHIP TO REMOVE THE REFRIGERANT.BUT THIS JOB YOU NEED EXPERIENCE OR KNOWLEDGE ON AIRCONDITIONERS SYSTEMS BECAUSE YOU NEED A VACUUM PUMP TO PULL OUT MOISTURE AND MANIFOLD GAUGE SET YOU NEED SPECS FOR OIL CHARGE AND REFRIGERANT CANT PUT TOO MUCH IN.YOU NEED SYSTEM FLUSHED OUT REMOVE DEBRIS OUT LINES.THE ORIFICE TUBE AND ACCUMULATOR HAS TO BE REPLACED.
Posted on May 18, 2010
Hi Just wondering if you could tell me some troubleshooting ideas for an Amana air conditioner--it seems to be getting power--we are hearing a noise coming from the unit indicating that it is getting...
Every air conditioner has a motor called a compressor. The compressor provides the cooling capacity for the air conditioner. If the compressor or its electrical controls are defective the compressor may try to start, fail, and create an electrical overload. If the unit does create an overload, every compressor circuit is also equipped with an overload safety switch. The safety switch is designed to protect the compressor from burning out. The safety switch will cut the power to the compressor for a certain length of time and then reset itself. When it resets it will allow the electricity to flow to the compressor once again. If the compressor then starts, the unit should function normally. If the compressor doesn't start when the overload resets, the overload will again cut the electricity to the compressor. This cycle will continue indefinitely. (Always allow three to five minutes before restarting the compressor.) If this situation is occurring, unplug the air conditioner and get help from a qualified repair technician. This problem is often fatal to the air conditioner because the cost of repair often exceeds the price of a new air conditioner.
To start a compressor you need a start contactor - relay and a capacitor. The click you hear could be from the contactor, which could be normal OR could mean that the contacts are not staying closed which would not allow the compressor to start.
Jul 22, 2011 | Amana Heating & Cooling
I have a small frigadare a/c.a one room a/c.it comes on then right back off.what can i do about this.
Hello, here is what the problem may be. Every air conditioner has a motor called a compressor. The compressor provides the cooling capacity for the air conditioner. If the compressor or its electrical controls are defective the compressor may try to start, fail, and create an electrical overload. If the unit does create an overload, every compressor circuit is also equipped with an overload safety switch. The safety switch is designed to protect the compressor from burning out. The safety switch will cut the power to the compressor for a certain length of time and then reset itself. When it resets it will allow the electricity to flow to the compressor once again. If the compressor then starts, the unit should function normally. If the compressor doesn't start when the overload resets, the overload will again cut the electricity to the compressor. This cycle will continue indefinitely. (Always allow three to five minutes before restarting the compressor.) If this situation is occurring, unplug the air conditioner and get help from a qualified repair technician. This problem is often fatal to the air conditioner because the cost of repair often exceeds the price of a new air conditioner.
May 25, 2011 | Frigidaire Heating & Cooling
AC Unit is not cooling.
hi...
Every air conditioner has a motor called a compressor. The compressor provides the cooling capacity for the air conditioner. If the compressor or its electrical controls are defective the compressor may try to start, fail, and create an electrical overload. If the unit does create an overload, every compressor circuit is also equipped with an overload safety switch. The safety switch is designed to protect the compressor from burning out. The safety switch will cut the power to the compressor for a certain length of time and then reset itself. When it resets it will allow the electricity to flow to the compressor once again. If the compressor then starts, the unit should function normally. If the compressor doesn't start when the overload resets, the overload will again cut the electricity to the compressor. This cycle will continue indefinitely. (Always allow three to five minutes before restarting the compressor.) If this situation is occurring, unplug the air conditioner and get help from a qualified repair technician. This problem is often fatal to the air conditioner because the cost of repair often exceeds the price of a new air conditioner...
hope this will give u a clear idea..
thank u
rate me!!!!
Aug 24, 2009 | Heating & Cooling
I bought a spree and has a colman moch airconditioner and does not seam to keep up in the heat of the day is this normal
Does it continue to stay running as in compressor stay on all time when asking for cool, or does compressor cut out?
Aug 16, 2009 | Coleman Mach 15 Air Conditioner
Wont blow out cold air anymore?
hi...
thank u
rate me!!!!
Jul 19, 2009 | Pelonis Heating & Cooling
How do you switch the air condition to auto
You can switch it to power saver mode, it would cut the fan when compressor cuts off as well. The other stting just cuts off the compressor. If your unit is too small for a room it will keep running, or it you dont have good insulation in your house.
Jul 02, 2009 | Whirlpool ACQ189XM Air Conditioner
Air condition problem
What type of thermostat do you have? If the fan is not coming on and neither is the compressor, then is more than likely a problem with the thermostat of control units of the Air Conditioners. The fan will come whether the compressor does or not if the thermostat and control unit are working correctly. Check for twelve volt at the control unit of the air conditioner ceiling unit. (Red Wire, should be labeled)
Jun 30, 2009 | Dometic Rooftop RV Air Conditioner
Air conditioner keeps tripping breaker replaced the termostat do you think the compressor is gone its only 6 years old.
if this helps please vote me a fix ya
Jul 18, 2008 | Heating & Cooling
Hisense air conditioner
Oct 26, 2007 | Heating & Cooling
Heating & Cooling Logo
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
