Question about Sanyo Televison & Video
My sanyo tv model dp42840 has picture but no sound. it is seeing the hdmi connection as dvi
4 Suggested Answers
  • 5100 Answers
SOURCE: blueray dvd player to dp42840 hdmi cable hooked up
Check your set up again. Mine says the HDMI/DVI is HDMI 1 (and then connect the audio to the video 3 audio input).
I need a magnifier to read the label on the TV. You just need the only HDMI input that has (DVI) in front of the word Input.
I hope this helps.
Posted on Jan 07, 2011
caroldon
  • 17129 Answers
SOURCE: Just purchased new Sanyo 42"DP42840.
Being a new set it is important that you should have tested the model to your liking in the showroom. However some of these models have poor sound as the sound is normally fed into the home audio system. So if you have any audio system connect the audio outputs to the auxiliary and you will be able to get better sound.
Other wise you need to check back at the showroom if the same model sound as same as yours. Otherwise exchange the set under warranty.
Posted on Mar 30, 2011
  • 1702 Answers
SOURCE: when i plug an hdmi
Hi, When you use the HDMI you have to switch the TV to HDMI to make it work. Not the other way around. Select the menu on your TV click to HDMI 1 or 2 depending which you are using. Sometime you have to ignor what it says. Try it out any way. Good luck.
Posted on Jul 22, 2011
How can i connect my hp pavillion s5610y to my bravia tv
This is a bit complicated since there is no HDMI output capability to the PC, only VGA and DVI. First, check to see if the Bravia has one of its HDMI ports listed as DVI capable. If it does, it should have accompanying audio jacks (red/white) for it. What you would need to get is two different cables for interface. The first is a DVI-to HDMI cable to run from the PC DVI port to the Bravia DVI-compatible HDMI port. You cannot run the DVI to a regular HDMI port because if you do you will get only picture and no sound. DVI outputs, unlike HDMI outputs, do not carry the audio signal. A DVI-compatible HDMI port on a TV set will connect the video from the HDMI port and the audio from the reserved audio port accompanying it. The second cable you need will be a mini stereo audio plug to RCA jacks. This will connect between the PC audio out (green), and the DVI audio plugs on the set. See pictures for cables below
Once you have this done, selecting the appropriate HDMI port on the set should result in audio and video getting to the unit. If you only need the video (you are going to use the PC speakers), then you don't need the audio cable and you can use any HDMI port, but you cannot control the volume using the TV set remote. You would need to use the PC volume settings. (Just as an afterthought if the set has no DVI-compatible HDMI port).
Jan 26, 2016 | HP Computers & Internet
My Sanyo TV (Modele # DP42840) has a problem?
It sounds like the power supply inside the TV is failing. You can try disconnecting everything that is plugged into the back of it EXCEPT the power cord and one source cord (ie: the cable or HDMI from your video source (like the cable box.))
If that doesn't help, then an electronics technician would have to troubleshoot the internal power supply.
Aug 31, 2015 | Sanyo Dp42840a
I HAVE SOUND AND CABLE CANNEL BUT NO PICTURE. IS THERE A RESET FOR THE PICTURE. THE TV IS A 2010 SANYO 42" MODEL DP42840
Are you on cable or satellite? You'll need to reset the receiver box, not the TV, and if that doesn't work, call your cable or satellite service.
Dec 01, 2014 | Sanyo Televison & Video
I just bought a phillips blu ray and trying to hook it up to my sanyo 50" plasma through a hdmi i get video but no sound the tv says to use the dvi port and audio 3 inputs but the blu ray does not hav
Hello there, the hdmi cable is a great way to get high definition video from a bluray player to a tv, but if the bluray player is part of a surround sound system you will need to get the sound to the tv separately. There is often a red and white audio terminal in the rear of the bluray player, sometimes located next to a yellow terminal, these are known as a component connection as each component (coloured terminal) is separate and operates a separate function, but all 3 connections can be used together to create a SCART equivalent. You may need to connect an 'Audio Component to 3.5mm jack' cable from the white and red terminals to the headphone/line in socket on the tv.
alternatively, as wilth my player, there is a button on the remote which switches the audio source from component, hdmi, SCART, etc, this may be the same for you.
hope this helps.
Mar 12, 2014 | Televison & Video
How do I connect my PS3 to my sanyo dp50747 in hdmi? I have everything hooked up correctly, but its not coming up on the TV. What do I do?????
If you see a no signal message, then it means that the signal output format of the PS3 does not match . It happens if you have previous used it on another tv and now connected it to a different tv. To resolve this, turn off the PS3 . Press and hold the power button on the PS3 till you hear three BEEPS. The PS3 should automatically detect the tv's resolution and the initial setup screen should appear. After that you should just follow on-screen instructions to set it up.
Sep 26, 2011 | Sanyo DP50747 50 in. Plasma TV
When i plug an hdmi cable into the hdmi port on my sanyo tv it says a dvi connection and not a hdmi which i have tried 2 hdmi ports and i cannot get any sound or picture on the tv
Jul 22, 2011 | Sanyo Televison & Video
Mar 30, 2011 | Sanyo Televison & Video
What cable do i need to connect my laptop to my Sanyo DP50740?
Hello jaygee7414,
Sanyo DP50747 not support for D sub conection (PC in).
To connect PC in, you can use DVI or HDMI input.
Some Laptops already have HDMI or DVI out put. Like HP mini, sony vaio.
Or you can use s-video input.
Thanks.
Mar 21, 2011 | Sanyo DP50747 50 in. Plasma TV
How do I Connect a Dell Latitude E6500 to a Sanyo Television
Check your ports on the lap top see if you have s video or hdmi or dvi or VGA the best is hdmi if you have that get a cable for either one of you connections also match connections from the lap top to what you have for your TV more than likely if they are both fairly new you should have hdmi connections for both get a cable that is long enough. I get my cables at amazon.com their prices are the bomb.
Connect them together both ends to lap top and to tv then make sure that you have a line in jack stereo jack with RCA ends hook that to the back of your tv and your lap top in stereo jack even better to your surround sound system. Set your TV to AVI 1 or 2 or DVI or whichever is your connection start a movie on the lap top and turn your sound on and see if you have a picture on your screen you should have the same thing as what is showing on your monitor on your lap top. Adjust settings and have fun!
Jan 08, 2011 | Dell Latitude E6500 Laptop
Sanyo DP46840 purchased less than 1 week ago from Walmart. Worked fine for first couple of days, now HDMI connections don't work. monster cable works on other lcd tv and all video sources. rest TV...
Hi gregschirk,
I bought the same model and I am experiencing a similar problem. My HDMI components worked fine before. Now both my cable box and DVD player will not be recognized as HDMI systems. It thinks they are DVI to HDMI connections. Good picture but no sound. Would like to know if there is a fix for this.
Thanks Gilbo72
Nov 27, 2010 | Sanyo Televison & Video
Televison & Video Logo
26 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
