Question about Avital Vehicle Parts & Accessories
Need Avital 5105L Installation Manual. Where can I get it?
When I tried to unlock my car with my remote it would not unlock the car, I used the factory remote that came with my car, the alarm went off and would not go off. We had to pull the fuse out to get i
You can put the alarm in valet mode so it's inactive. There is a pushpurltron switch il under your dash all you need to do is turn the ignition on and within 10 seconds press that button once then turn off the ignition. Link to a owners manual
Jan 29, 2015 | 5303L 2Way LCD Remote Start Security...
Need to program additional fob to Avistart 4111
Turn ignition on, press and release valet switch then, press and hold valet switch. Press button on remote. Release valet switch, turn off ignition. Test
Feb 08, 2014 | 4111 4111L Remote Car Starter
The full trigger alert icon is illuminated on my avital 5303
What is the full trigger alert icon? Please describe it.
Jan 17, 2013 | 5303L SecurityRemote Start System
Need wire diagram for avital 5103
You can download a copy of the installation manual from this link:
Avital 5103 installation manual
Sep 24, 2012 | Directed Electronics 5103L Avistart 5103...
Avital 4113 makes my cars horn constantly go off
The most likely causes would be an improper installation or a failure in the receiver unit. I'd be inclined to take it elsewhere to check the installation. Hopefully you still have the instructions & paperwork that came with it.
Good luck.
Feb 10, 2012 | 4113LX 1Button Remote Start System with...
Hello. I have an Avital 4103 system and the key light on the dash does not go out after starting the car, inserting the ignition key and turning. I can drive the car, but the key light keeps flashing and...
I have a Dodge Caravan 2001 SE. Had the Avital 4103 installed. My question is, before installation i had a Chrysler car alarm in the van. When the remote start was installed they removed the alarm.
The shut down toggle switch was not installed, also the push button valet switch was not installed also. Is this a correct installation, I was told that I did not need the last two items to be installed.
Oct 27, 2009 | 831002/4100 4100 REMOTE START SYSTEM WITH...
Vehicle Parts & Accessories Logo
112 people viewed this question
Top Avital Vehicle Parts & Accessories Experts
D. E. Hev
Billy Mac
Are you an Avital Vehicle Part and Accessory Expert? Answer questions, earn points and help others
