Question about Kenmore Dryers
Made a mistake and in hooked the wires on my Kenmore Dryer with out taking a picture. There is 3 wires on the start button but only 2 prongs.
  • Kenmore Master
  • 8,220 Answers
One end is white wire or common the other end has a small terminal and a large terminal you can screw that up. If ya did screw that up it will run with door open and stop when door shut is all.
Posted on Jan 03, 2017
  • Zan GoFresh
    Zan GoFresh Jan 03, 2017
    There's a black and tan wire from the buzzer, making it three wires. The red and white wire plugs to the start button then there is two wires left. I plug the black one one up to the other side of start button then it's one wire left. Where does the tan wire go?
  • Dan Webster
    Dan Webster Jan 03, 2017
    got a picture of it?
Kenmore Dryer Model #11060932990 Proper grounding when changing 4 prong cord to 3 prong.
According to the National Electric Code, you will need to install a grounding strap from the frame to neutral in a 4- to 3-wire conversion.
Jan 18, 2014 | Kenmore Dryers
We were never given an owner's manual for our
Hi wildspiritmo...
Go to the following webpage and see pictures and discription of how to change you 3 wire dryer into a 4 wire dryer.
Please take time to rate me thumbs up
http://www.selfhelpandmore.com/switch-outlet/dryer-circuit-wiring-and-hookup.php
Sep 14, 2011 | Kenmore Elite HE3 Steam 8674 Dryer
Kenmore 700 dryer with a three prong cord is being converted to four prong. Is there a drawing of what wires by color going to the proper screw location?
There's a ground strap wire (green/yellow) attached to the dryer cabinet and connected to the center terminal where the white neutral wire of the power cord is connected. Disconnect this ground strap wire and remove the 3-prong power cord from the terminal block taking note where the wires are connecedt to. Connect the 4-prong power cord in the same way same wire colors of the 3-prong cord are connected to the terminal block. Connect the ground strap wire to the remaining fourth wire (green/yellow). Just do the reverse when converting 4-prong to 3-prong. The link below might enlighten you further on this matter.
Electric Dryer Prong Conversion
Aug 13, 2011 | Kenmore 700 6972 Dryer
3 wire to 4 wir
So you have an, ahem... problem....you have a Code compliant dryer (with it's 4 wire cord and plug)....and have moved into an older home that is not Code compliant (with it's 3 prong receptacle outlet)....and this is fairly common.
At this point - you have two choices....replace the wiring from the dryer's breaker to the receptacle with all new 8/3 with ground romex (it more then likely only has 8/2 with ground now)....and replace the receptacle with a 4 prong grounding receptacle to match your dryer's cord....OR - as an alternative - you can replace the cord on your dryer with a 3 prong cord to match the existing dryer receptacle outlet.
Out of the 2 choices....the first one will bring the old wiring in the home up to current Codes (all NEW homes must have this 4 wire/4 prong set-up per Code...but older homes are grand-fathered)...but it is clearly the most involved, time consuming and most costly approach...and it is recommended only an electrician do this work. If this approach is taken....your dryer cord can stay as is...it will now fit the new receptacle outlet with no modifications.
The second approach - is to pick up a 3 wire 3 prong cord at your local hardware store to match the existing 3 prong receptacle.....and replace the 4 wire cord on your dryer with it. Although this is the least desireable - it is an allowed approach because this is an older home with existing wiring. This is a much less involved approach...all you need to buy is the 3 wire dryer cord (they come all ready to go) remove the 4 wire cord and install the 3 wire cord to your electrical connections at the back of the dryer. Hopefully...when the 4 wire cord was installed on your dryer, the ground strap wasn't removed completely (this is a metal strap that will connect the white wire to the metal frame of the dryer)...because now you will need to re-use the ground strap. For more on this....see the images of the differences of the 3 wire and 4 wire dryer hook-up at:
http://www.applianceaid.com/general.html#3to4
NOTE: the only real difference between the 3 wire cord and the 4 wire cord is now the white neutral and the ground are kept seperate in a 4 wire..the green ground will connect directly to the dryer frame....where in a 3 wire there is no seperate ground wire - ground and neutral are one and the same...the ground strap connects the frame to the white neutral. The 4 wire permits a better safety measure...in the event of an electrical problem (ground fault) in the dryer...the fault now has a seperate path to your panel's ground...and less chance of a shock from touching the metal frame of the dryer.
The choice of how to proceed is up to you....if you go with completely updating the dryer wiring from the breaker outward...I recommend an electrician do this work for you (it's about an hour's work...plus materials). Then your exisiting dryer's 4 wire 4 prong cord can stay as is....the electrician will install a 4 prong receptacle made to fit your cord.
If you go with simply replacing the dryer's cord....changing it to a 3 wire so it will fit the receptacle...make sure the ground strap is re-utilized as seen in the images at the site above.(also make sure all work is done with the dryer breaker (or fuse if a really old home) off before starting any work. If you change the cord yourself...make sure to reconnect in exactly the same manner as the previous cord was connected...(make a note on paper or take pictures so that there are no mistakes)..and that you tighten the nuts securely to the posts once the wire lugs are on them. Where you state you do not have a background in electrical work...you can have an electrician change this cord for you...(typically in under a half-hour)....or you can do it yourself - by carefully following the pictures.
The choice is yours...if it was me - I'd change the wiring from the breaker outward...making the older home meet today's current Codes and be complaint for this dryer..and then you wouldn't need to change a thing on the dryer....but you can go either way....Codes allow this grandfathering in older homes with existing wiring.
Feb 11, 2010 | Kenmore 94802 Front Load Stacked Washer /...
Kenmore dryer 3prong cord installation diagram
if its a" flat cord" what-ever color jacketed 3 wire cord, the 2 outside wires are your 2 hot power wires they go to L1 and L2 on your dryer,the center is the N neutral wire and goes to the N terminal,usually the L1 and L2 are a gauge larger than the neutral: HINT: the center is normally neutral on both the cord and machines terminal board in the back of the dryer,there usually is a diagram on the dryer on how to install the input power at the place you hook up power
Feb 07, 2010 | Kenmore 62602 Electric Dryer
We have a Kenmore front load dryer. We just
I would check the thermal fuse. It is just inside the rear of the dryer and is usually attached to or is near the exhaust duct. It is about an inch long and can be tested using a multimeter or ohmmeter. Check for continuity. A lack of continuity indicates a blown thermal fuse. Changing from 4 prong to 3 prong should have no effect if the wiring was hooked up properly. It is most likely just a blown fuse. Hope this helped and best wishes.
Aug 28, 2009 | Dryers
I need help in changing the 4 prong to a 3 prong cord
It would be a better and safer idea to change the receptacle from a three prong to a four prong. You would also be in compliance with the electrical code. That being said, here is the info you will need to go either way.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=10&newsdesk_id=5
Apr 03, 2009 | Kenmore 84832 Electric Dryer
Dryers Logo
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
