Question about Sony FD Trinitron WEGA KV-32FS120 32" TV
Power led flashes 5 times and repeats again , but screen still black, no picture, even that sound of buzing click when I press ON BUTTON doesn't come up. thanks in advance if you can help.
    Problem Solver:
  • 7 Answers
U need a "d" board
Posted on Jul 23, 2009
  • hiran242
    hiran242 Jul 06, 2012
    adjust fbt screen and focus controls if still the same replace fbt and video output ic or transistors fixed mine kv20m50
  • 30 Answers
5 blinks=AKB circuit
probably video output tda6108 or 200v supply from the high voltage transformer going to the CRT board on the back of the tube. If you don't have experience in electronics i would take it to a service center
Posted on Jul 21, 2009
I am trying to unlock the region code for Sony BDP-S5100 with the URC7740. The hack program refers to "press and hold the &#147 key. Where or what is "&#"?
I would have to guess, that is probably not the correct remote. I feel I must inform you, trying to upgrade your firmware, from an unsavory hacker, can turn your unit into a brick(doorstop). IMO, proceed with caution.
Jan 14, 2015 | One For All URC 7740 Remote Control
I have a Panasonic PT-52LCX66 television that I bought just over 4 years ago. I have replaced the bulb for the second time just 3 months ago and now the set will just shut off after about 3 minutes of...
Tv making and have clicking sounds as tv shutdown as lights flashes?Yes.The board that call the Ballast board might be dying and dead soon.This Ballast board job responsible only are to ingnite the tv projection lamp only.
Jun 30, 2011 | Panasonic PT-52LCX66 Projection Television
I have a 62" rca led hdtv.. when I push the power
How many times does the light flash each time? Also whats the full model number of your set?
May 30, 2011 | RCA Televison & Video
I have an aquios LC-42D64U which suddenly has the following two lights blinking power & OPC. They both blink, once together, the second blink is only the power, and repeating the sequence. I've...
Sharp LED/LCD EEP cleared Step 1 Remove Mains Plug 2 Press On/Off Switch from LED/LCD Panel 3 Press Ch Down & Input Switch together and plug in mains cord 4 LED/LCD will start 5 "K" will appier on Screen 6 Press Ch Down & Vol Down from LED/LED Panel 7 1/9 Page will appier on Screen 8 Go to 9/10 page by pressing Up & Down arrow of remote 9 Select EEP Cleared 10 Press ok button from remote 11 On Screen dispay EEP running 12 Remove Mains Plug after complete EEP Run 13 Restart LED/LCD
Feb 05, 2011 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
I’m having a problem with my Toshiba 42HL196. Once or twice the red LED was flashing and I held the power button in for a bit and it started working again. Today I was having cable installed and after a...
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Mar 13, 2017 | Toshiba 42HL196 42 in. LCD HDTV
Mitsubishi projection tv picture and sound turn off but the power button remains on with no picture or sound turn tv off real quick and then back on and works for 2 mins then turns off again what could be...
Here's the basic troubleshooting:
  1. Make sure that no front panel buttons are inadvertently stuck in an "engaged" position.
  2. Disconnect ALL devices from the TV.
  3. Press the SYSTEM RESET button and hold for 10 seconds. Proceed if the problem still exist.
  4. Press and hold POWER and MENU buttons simultaneously for 20 seconds. Proceed if the problem still exist.
  5. Unplug the TV from it's power source for various times, ranging between 5 minutes and 24 hours.
  6. If it still shuts down, press the DEVICE and MENU buttons on the front panel simultaneously and hold it for 5 seconds to activate the Error Code Operational Check. The status LED indicator will then flash denoting a two digit code.
  7. Count the number of flashes then pauses for about a half second then flashes again. The first number of flashes indicates the first digit of the error code and the second number of flashes indicates the second digit of the code. For example, if the error code is "35", the LED will flash 3 times, pauses, then flashes 5 times. The error code is repeated a total of 5 times.
Please let me know the code you got and I'll tell where the problem lies and how to fix it.
Dec 01, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Canon PIXMAR MP150 E5 problem
hi,
CANON PIXMA MP160 All-In-One InkJet Printer
has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.canon.com/printer/prob676ijt65/solution
toi-i-28
Apr 10, 2009 | Canon PIXMA MP160 All-In-One InkJet...
No picture
you have the ATC311 chassis. do this proceedure and you can track down where the problem is. let me know if you need more assistance. i can also post a link where you can get the training manual at a cheap cost emailed to you if you would like a copy.
5. Apply AC power and press power button.
6. If LED turns on and then off, disconnect J11501 (Audio CBA) and press power
button again. If power LED comes on and stays on suspect Audio CBA. If LED
still flashes or does not light go to step 7.
7. Disconnect J26903 (AV IN CBA) and press power button again. If power LED
comes on and stays on suspect AV IN CBA. If LED still flashes or does not
light go to next step.
8. Disconnect J19500 (Convergence CBA) and press power button again. If
power LED comes on and stays on troubleshoot the Convergence CBA. If
LED still flashes or does not light go to next step.
9. Disconnect J14801 (Deflection CBA) and press power button again. If power
LED comes on and stays on suspect Deflection CBA. If LED still flashes or
does not light suspect DM2 module.
Jun 08, 2008 | RCA HD61LPW42 61" Rear Projection HDTV
Free Pulse
The following procedure will re-establish the communication link between the Headphones and the Wireless adapter, this is called "pairing". Before you start please make sure both the headphones and the wireless adapter are fully charged and turned off.
Note: The headphones and the wireless adapter come pre-paired from the factory.
1. Press and hold the power button on the headphones. See Figure 1.
Figure 1
2. Continue to hold the button down until the LED starts flashing red/blue in an alternating pattern. Release the button when the LED starts flashing red/blue. See Figure 2.
Figure 2
3. Once the headphones LED is flashing red/blue, press and hold the power button on the wireless adapter. See Figure 3.
Figure 3
4. Hold down the button until the LED starts flashing red/blue in an alternating patter. The LED will blink blue, then turn off for a few seconds then blink red/blue. Release the button when the LED starts flashing red/blue. See Figure 4.
Figure 4
5. Once both the headphones LED and the adapter LED is blinking red/blue, press the volume up button once on the headphones. See Figure 5.
Figure 5
Once the headphones is paired with the adapter, the LED on the headphones will blink blue once every two seconds. See Figure 6.
Figure 6
When the adapter is paired the LED will be solid blue. See Figure 7.
Figure 7
The adapter may continue to blink red/blue for a few seconds even after the headphones LED starting blinking blue. This is normal; the adapter may take a few additional seconds before the LED turn solid blue.
Once the headphones and the adapter are paired, it is not necessary to pair them again even if the batteries on both units are completely drained.
Additional Note: Repeated pairing will not improve the sound quality or give the headphones and the adapter a cleaner connection.
Mar 11, 2008 | Logitech FreePulse Wireless Consumer...
Sony FD Trinitron WEGA KV-32FS120 32" TV Logo
289 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
