Question about Sewing Machines
How to fill bobbin on a vx1005. Bicor - Sewing Machines
SOURCE: Thread bunching underneath fabric on Bicor VX1005 mahine.
The impulse is to blame the bobbin, because that's where the thread bunches. But the problem is probably with the top thread tension. The tension is too loose, allowing the bobbin to help itself to all the thread it wants. Retrace the path of the thread from spool to needle and see if you missed anything. The instructions in my VX1005 manual are not clear. I had to try a couple of paths before I got it right. Make sure the spring in the tension disk setup is moving freely. You should feel a fair amount of resistance when you pull on the needle thread. Hope this helps.
Terry
Posted on Jan 31, 2009
SOURCE: Bicor vx1005 ...thread keeps bunching
Try a different bobbin. Look for one that is a little narrower. I had the same problem and changing to a narrower bobbin fixed it.
Posted on Mar 29, 2009
  • 980 Answers
SOURCE: presser foot lifter is stuck can i fix it
If you can't lift the presser foot up at all undo the presser bar screw on top of the presser bar, if you have a dial turn it to 0, you should now be able to move the lever, if it is still tight put some WD40 on the presser bar and leave it for a couple of hours.
Posted on Nov 04, 2009
  • 1116 Answers
SOURCE: how do you thread bobbin for Bicor VX1005?
Look through these threading guides for a Brother that has the same features. http://www.sewusa.com/Sewing_Machine_Threading_Diagrams.htm
The above site has a manual, but I not a threading guide. Unless it is the same as another model.
Posted on Mar 07, 2010
Make sure that you have the top thread in all the correct positions. I missed two and had the same problem. When I rethreaded it my problem was solved.
Posted on Sep 06, 2010
I just need to know where I can get the bobbin case for Brother Bicor VX1005. if not available, which bobbin case can be used in stead? I already checked ebay but I don't see it.
Contact your local Brother dealer or try the online Brother contact/support department. They should be able to provide you with the bobbin you need.
You can also try search some of the online sewing machine parts suppliers.
http://www.sewingpartsonline.com/
Sewing machines quilting machines embroidery machines vacuum cleaners...
Sep 23, 2015 | Brother Sewing Machines
Need a manual for the Bicor vx1005 sewing machine
I ordered the manual through http://www.mastersewusa.com but still do not have the download link. It has been almost a week now. The site said it would be in my e-mail in 3 hrs. Well today is day 5.
Feb 07, 2014 | Sewing Machines
I NEED A BOBIN AND ALEAVER THAT RAISES THE NEEDLE FOOT
try these sites and see if they can help you,,you'll have to call or
email them
sewvacdoctor.com
a1sewingmachines.com
Jan 16, 2013 | Brother LS2020 Sewing Machine
Difficulty threading bobbin- thread bunches under fabric. vx1005
I would suggest to check the needle to see if it's damaged
also check to make sure the machine is threaded correctly,,that the thread is in every thread guide
also some sewing machine have a problem with the top thread coming off the thread take up lever
also I would check the bobbin area for lint or any loose threads
also check the top thread tension to see if it's set correctly
also the hook race cover & hook need to be taken out & cleaned & then put back in
some machine have had problems with the hook getting grooves worn into them & need to be fixed or replaced
Oct 08, 2010 | Brother LS-1520 Mechanical Sewing Machine
How do you thread bobbin for Bicor VX1005?
Mar 07, 2010 | Brother LS-1520 Mechanical Sewing Machine
Presser foot lifter is stuck can i fix it
Nov 04, 2009 | Brother XL-5130 Mechanical Sewing Machine
Need Bicor vx1005 Manual
Unfortunatly it won't be free, as all websites I have found charge for the manual. MASTERSEWUSA.COM however was the least expensive, charging $5.00 for the manual. Hope this helps! Matthew
Mar 31, 2009 | Brother LS-1520 Mechanical Sewing Machine
Terry
Nov 11, 2008 | Bernina Activa 130
Jun 14, 2008 | Brother LS-1520 Mechanical Sewing Machine
Sewing Machines Logo
24 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
