Hi Mary
It sounds like, to me, your centre (center!) speaker has become disconnected.
In a 5.1 (or more) setup, the majority of voices come through this center channel - and without it, you'll hardly hear any voices, other than those which are not the 'focus' and are to either side.
Have a look on your remote controller for a 'Test Tone' button, which should cycle through all the speakers and play a noise - you'll probably find 'center' is quiet. If it is, check the wires - should be a simple repair!
Good luck :)
SOURCE: LGDVT418
i have the problem resolved got this answer from lg :
We are delighted to hear from you as our Valued Customer. We regret the trouble you have experienced with this product. Check the CENTER SPEAKER for operation. This single speaker carries the vocals for DVD discs, but is not uesd for TV and CD AUDIO. Check the wiring on this speaker to make sure that the contact points on the DVD player are touching the wire, and not the rubber insulation on the wire. If you have other questions or concerns, please do not hesitate to contact us again either via email, or by calling our customer service division at 800-243-0000 at your convenience. Neil E Electronic Correspondence Executive (ECE) LG Electronics USA 800-243-0000
SOURCE: How do I get my tv to play through the surround sound
If you have direct cable into the television, you will need to use an audio output if available on the back of your set into your HT system.
If you are using cable w/ a cable box you have two options. You can still connect everything directly into the TV then reroute the audio to the HT system... or, you could hook only video to the TV and audio from the cable box to the HT system. Really up to you.
SOURCE: CAN ONLY GET THE SURROUND SOUND TO WORK WITH DVD'S NOT WITH NORMAL TV OR SKY?? WHY??
You should have a AUDIO menu in which you can simulate true surround sound. This should be in your owners manual. Your DVD is recorded in dolby surround sound that's why on your set it will be reproduced as recorded. I hope Samsung is using a ATSC tuner in that model?
SOURCE: surround sound ok whilst playing dvd but not working for tv
On your Sagem TV you should have two RCA ouputs (red and white connection usually marked ouput) ) Connect these to the input on the surround system using the interlink cable.
You should then be able to hear the sound from the TV by changing the SOURCE on the home cinema remote.
Better still if you have a digital out on your TV use that instead.
