KUDC21OS3 stuck impeller. Tried freeing up the impeller moving it clockwise that didn't work then counterclockwise and it didn't work. It starts to spin after I unstick it and gets stuck again.
  • 641 Answers
SOURCE: The drain pump only turns 1 turn counterclockwise and clicks to a stop. What happened?
To check the pump you should remove it from the washer and try to rotate its pulley manually to both sides. If it doesn't turn freely (frozen or stiff) look for foreign object inside the pump. In case the pump is clean and doesn't turn freely,you should replace it/ Good luck !
Posted on Aug 27, 2007
  • 25 Answers
SOURCE: Agitates forward but not reverse.
lower gear box coupling has sheared
Posted on Jul 03, 2008
donnastr
  • 10 Answers
SOURCE: Admiral Washer not spinning
broken or slipping drive belt, ( motor) to spin pulley , losse pulley, defitive drive clutch, spin brake fails to release, or transmission is frozzen
Posted on Oct 08, 2008
TheMobilian
  • 8220 Answers
SOURCE: kenmore washer won't agitate,drain or spin.
What you have here is a broken drive coupling
the part looks like this:
To fix it CLICK HERE
Posted on Dec 29, 2008
SOURCE: Whirlpool Ultimate care ll Quiet wash Model # LSQ9564SQ0
whirlpool washer makes a loud noise after spin cycle. What might that be?
Posted on Jul 08, 2010
Brita faucet filter adapter is stuck in my faucet
It sounds like the adapter was screwed in at an angle. This causes the threads to cross in turn making it near impossible to unscrew. Since it is plastic I recommend buying a new adapter. I know it's unfortunate, however it is a lost cause.
Jan 23, 2014 | Clorox Brita Water Filter For Faucet White
Hi, I have a QC 1072 A.O. Smith pool pump motor. How to get the impeller off? Which direction does the impeller spin off? Where to but impeller and seal? Thank you very much Greg
The impeller is just screwed on the shaft. COUNTERCLOCKWISE to remove. Some have a screw in the center attaching it to shaft. This is removed by by turning CLOCKWISE.(reverse threads) Remove back cover and secure shaft with a wrench. There are flats on the shaft to hold it. You might need a large pipe wrench to loosen impeller. Wrap with rag so you don't damage impeller.
May 18, 2011 | AO Smith A O Smith Motors A O Smith 3/4hp...
I have a proline 1.5hp pump need to replace the shaft seal. I can't seem to get the plastic impeller off. We use a screwdriver to hold the shaft screw and try to turn the impeller counter clockwise...
Keep trying - It is stuck and will likely break but you have to remove it to change the seal. It is not uncommon to need to replace the impeller when the seal fails since the water gets behind the impeller shaft and rusts the metal causing the impeller to bind. If you still cannot get it free pull the motor thru-bolts and lock the rotor once removed from the motor in a vice. Use a large pair of channel locks to break the impeller free...replace it if necessary.
John
May 15, 2011 | Waterway 1.5hp Hi Flo Above Ground Pool...
Black & decker mm850 can not get blade off so can replace how do I get off tried loosen clockwise and counterclockwise plates move will not loosen up
The nut is counterclockwise but will most likely take an impact wrench to remove the blade because the impact will not need the blade or spindle to be held in order to remove the nut.
Thanks,
Chad
Mar 23, 2011 | Garden
Dont understand why on top of an side of scope setting there is ur ur instead of left right or up down
The "U" indicates Up on the elevation dial, and the "R" indicates Right on the windage dial. Turn the elevation dial clockwise to move the point of impact up, counterclockwise moves down. Similarly, turning the windage dial clockwise moves Right, and counterclockwise moves left. Here's a scan from the Zeiss Conquest manual:
Jan 05, 2011 | Zeiss CONQUEST 3-9X40 MATTE Z PLEX
How do you remove the impeller from the motor shaft?
Thank you for posting your question here on Fixya.com.
Lock the shaft using a wrench at the end where the electric leads connect. Then spin the impeller off counter-clockwise.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
Jun 13, 2010 | Flotec 1 - 1/2 Sprinkler Pump Composite...
How does the impeller come off of the motor shaft
It unscrews. If it has a lock screw in the center that is left handed so it unscrews in a clockwise direction. Then the impeller unscrews in a counter clockwise direction. Usually needing a good sharp rap to get it started. I usually use a screwdriver held sideways in the impeller and I hit it straight down with a cresent wrench.This will usually start it spimming. if that dosen't work you will have hold the back of the motor shaft and break it free by turning it with water pump pliers or the like.
May 30, 2009 | Jacuzzi MAGNUM POOL PUMP 1-1/2 HP MAGNUM...
J 440 treadmill belt moved all the way to left
clockwise on the left tightens, tighter forces away. Counterclockwise on the left would allow it to come to the left.
Jan 12, 2009 | Tunturi T30 Treadmill
Waste water does not get expelled, does not empty
youve got a blockage,most of the time its at the air gap on top the sink.It can be at the disposer.start there and work your way back
Dec 31, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Washing Machines Logo
29 people viewed this question
Top Washing Machines Experts
