Question about John Deere Garden
I have a 1996 John Deere 455 diesel It started running only 20 minutes before it dies for no apparent reason. After about 10 minutes it will pop right off again. The engine runs strong, no hesitation
The temperature gauge runs in the lower portion of the green. Regular maintenance on all filters. Recently replace fuel filter assembly due to broken elbow. Having same issue before and after changing assembly. Seems to have adequate fuel flow.
  • 237 Answers
The fuel injection pump has a fuel supply from the fuel filter and a fuel return line from the fuel injections to the fuel tank. This fuel return line is kinked or restricted in some way . Repair fuel return line and it will run. Check return line and fitting on injection pump also. If it is an electrical problem it is most likely the operator presense switch in the seat overheating and loosing connection then cooling off after a few minutes.. Check it out.
Posted on Jan 03, 2017
Testimonial: "Thanks Bud! I tried everything you steered me towards. The fuel line looked good. I replaced the switch and connectors for the seat, so far so good. Thanks again."
John deere 455 keeps dieing
Clogged pilot jet inside the carb. You need to remove the jets and ream them so they are clear. If it starts and then dies as soon as you try to throttle up, then it is the pilot jet.
Apr 25, 2017 | John Deere Garden
John deere - 455 Diesel
check your seat safety switch
Nov 19, 2013 | Garden
Can anyone tell me where the thermostat is on a John Deere 330 diesel lawn tractor?
follow the raid hoses to the engine should be at a bolt on neck
May 08, 2012 | John Deere Garden
When starting John Deere 455 lawn tractor, runs great first 15-20 sec with normal black exhaust, then engine starts knocking and exhaust turns grey at that point i shut it down, tested this 3 diff times...
Unless you have a diesel, the black smoke at start up is not normal, it should be white if anything. It sounds like you are burning very rich, or no air at all, check the air filter, check the fuel cond, check the governor thing, make sure it moves freely and rebounds. Change the spark plug. I don't know what else it could be without being there. The carb could be clogged up, some carb cleaner wouldn't hurt. Hope this helps.
Jul 18, 2010 | John Deere Garden
1974 John Deere 2030 diesel tractor and the engine dies
I will assume you have bled the fuel system per the owners manual to ensure no air lock in your system. This is especially critical after replacing the injector pump.
The next step is to ensure you fuel filters are good and flowing and last but probably the problem is the screen on the petcock (fuel shut off) in the fuel tank. Remove this shutoff valve and clean the screen with a fine wire brush and carburetor cleaner.
Nov 16, 2009 | John Deere 420,1020,2010,2020,2510,2520...
My John Deere 345 dies for no apparent reason
You have dirt in the fuel tank and it sucks the dirt up on the filter that is attached to the pump. After the machine stalls, the dirt falls off and it will restart and run for a few min.
Oct 02, 2009 | Garden
Blade wont stay engaged john deere 14 sb mower is 20 years old i have not replaced the belt could this be the problem
I have a john deere 14sb lawn mower that will start and run for about one minute and die wont start again until later.
Jul 01, 2009 | Garden
Kohler small engine problem
1989 Kohler 20 backfires through the exhaust. What are the possible causes?
Jun 02, 2009 | Kohler CH25 PA-CH730-0040 Command Gasoline...
Garden Logo
63 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Wayne Fellows
Wayne Fellows
Are you a John Deere Garden Expert? Answer questions, earn points and help others
