Question about Kenmore Refrigerators
The red light on my Kenmore reverse osmosis water system came on so I changed the battery and reset it but the water still wouldn't come out. we stopped using it but I would like to get it working
dragonsthatk
  • 547 Answers
SOURCE: Hooking up a GE Model GXRM10G Reverse Osmosis to ice maker
cold water line
Posted on Feb 21, 2009
FreshWaterSy
  • 13 Answers
SOURCE: Culligan RO sstem has recently stopped producing more that 6 oz
This might be a possible tank pressure issue. This could also be a clogged filter. I would first check the tank pressure by using the following steps
Necessary Supplies:
1) Tire Gauge marked in 5psi increments (ie 5, 10, 15, 20psi, etc.)
2) Bicycle tire pump for standard type bike tire valve
To recharge RO System Tank:
1) Close cold water feed valve (valve located at some point along the cold water line from street plumbing).*
2) Leaving RO tank valve on, turn tank on side & locate valve stem on bottom side.
3) Remove stem cap.
4) Drain all water out of tank through open RO faucet into sink. (Continue to leave RO faucet open throughout procedure)
5) If current tank pressure is insufficient to empty tank, apply tire pump to valve stem and pump 10 – 15 times. Exit flow will increase and then gradually decrease as pressure equalizes. Do not overcharge internal bladder of tank during this procedure.
6) Repeat step #4 until tank is completely empty. (Tank is empty when additional pumping produces no more water)
7) At this point, adjust EMPTY tank to exactly 7psi. (Gauge reading midway between 5 & 10psi is sufficient)
8) Turn off RO faucet.
9) Replace cap on valve stem and reposition tank in upright position.
10) Open cold water feed valve.*
11) System water is useable immediately, however, tank will take 3-4 hrs to completely refill.
FreshWaterSystems.com: The Water Super Store: 1-877-335-3339
Posted on Apr 28, 2009
jyackle5
  • 8197 Answers
SOURCE: What line do you tap into to add an icemaker to a
If you want the reverse osmosis water to go to the ice maker then you tap in to the line that feeds the spiget on the sink.
Posted on Mar 03, 2010
h2oservices
  • 306 Answers
SOURCE: I have a GE smartwater reverse osmosis system
That is the drain for the reverse osmosis system. You have what is referred to as an AIR GAP faucet. The waste water is pushed up there before it goes to drain just as the drain for a dishwasher does. If water is coming out of the faucet the drain is most likely plugged or the line is kinked causing water to back up and overflow. Check the drain line for kinks and clean out the drain where it attaches to the stand pipe.
RJ
Posted on May 17, 2011
heatman101
  • 43501 Answers
SOURCE: Why can't I use reverse osmosis water in my
Because you take off of the impurity's out and it changes the qualities of the water..
heatman101
Posted on Sep 04, 2011
GE reverse osmosis water filteration system is not working: No water in the tank
The tank should have only 5-10 psi when empty of water. If your unit sat for any amount of time your reverse osmosis membrane may have a problem. was all the cartridges changed? Should be yearly.
Nov 21, 2015 | General Electric Profile Smartwater Ultra...
I have reverse osmosis water connected to the frig. The Filter indicator is red which I think means it should be changed. (?) With soft water that is passed through reverse osmosis I should not need a...
On some of the Samsung fridges when the filter is removed it goes into bypass mode. There is a reset on the panel you have to hold for a few seconds the light will go out Check your manual or download one online if you don't have one
Oct 17, 2017 | Samsung RF4287HA
Water coming from the hot water valve (so right off of the boiler) is cloudy, almost rusty colored. We just had our water changed to a new reverse osmosis system, but were using reverse osmosis water...
The boiler is contaminated if the smells funny, if not then the water is leeching the minerals out of the boiler. RO water is an acid (pure water), it is just as bad as distilled water for espresso machines.
Mar 07, 2011 | Astoria Argenta SAE-2 Espresso Machine
I have a GE smartwater reverse osmosis system model number GXRM10GBL02. Water leaks daily from the small hole on the faucet on my counter top. Any idea why water comes out that small hole? Otherwise the...
RJ
Oct 22, 2010 | General Electric GE SmartWater Household...
How do you know if you need to replace the RO membrane filter in the culligan good water machine
A TDS (total dissolved solids)meter is needed to test the Reverse Osmosis water and compare it to the feed water to determine how much TDS is being removed. Reverse osmosis membranes are designed to remove 80-95% of the TDS in your water supply.
For example: If your water has 500ppm of TDS the minimum TDS removal should be 400ppm leaving 100ppm. If the TDS from the Reverse Osmosis System drops to these levels it is time to change the Membrane.
Typically an RO system will consistently remove 90+% of TDS for many years. The normal lifespan for a membrane can be anywhere from 3-10 years. It all depends on the TDS of your water and your water usage. The higher the TDS the more frequently the membrane needs replacing. The other filters should be replaced every 6 months to keep the quality up and protect the membrane.
A TDS of 1000ppm compared to 100ppm is much more difficult remove to acceptable levels. I like to compare 1000TDS to taking muddy water, forcing it through a filter and getting drinking water. Where 100TDS may be more like a clear glass of water. Consequently a reverse osmosis system on high TDS will be less efficient, less gallons produced and filters will need to be changed more frequently to keep the quality and quantity up.
RJ
Oct 04, 2010 | Culligan Under Sink Water Filter
What line do you tap into to add an icemaker to a GE Reverse Osmosis water system?
Mar 03, 2010 | General Electric Profile Smartwater Ultra...
I bought a new tank for my reverse osmosis water treatment and it did not come with directions. It's supposed to be ''charged,'' whatever that means. When I hook it up to my system it does not fill with...
Typically a reverse osmosis storage tank should have a precharge of approximately 7 psi. Depending on the make/model of your tank it may have a higher charge currently which would cause the tank to not fill. There should be a schrader valve on the bottom or side of the tank. Using a tire gauge and bicycle pump you should be able to check the current pressure in the tank and adjust it up or down to 7 psi.
reverse osmosis storage tanks: http://www.freshwatersystems.com/c-32-reverse-osmosis-storage-tanks.aspx
Geoff D., CWS-I - WQA Certified Water Specialist
Fresh Water Systems, Inc - http://www.freshwatersystems.com 1.877.335.3339
Nov 04, 2009 | General Electric FX18M GE SmartWater...
Ice Maker Not Working
Hi: A lot of reverse osmosis systems don't supply enough water pressure to the ice maker to fill. Contact your manufactrue of your reverse osmosis system and see if it works with icemakers. I thind usually the require at least 20-30psi. Or hook your refrigerator to city pressure to see if it works. Also I don't know if you have just an ice maker or a water dispensing side by side, or your water quality. If you just have an icemaker, most chlorine will evaporate before the ice is frozen, any odors in the water will still be there. Good Luck, Jeff
May 26, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Reverse osmosis causing poor water flow
cheak the main water flow and clean the machine inlet water filter
Jun 17, 2008 | Whirlpool GD5SHAX Side by Side...
Kenmore side by side dirty water
the problem might be linked ot your reverse osmosis system itself, something about filtering and storing previously filtered water, which if i remember correctly creates a "harmless" bio film the consistency of what appears to be brine shrimp sized particles floating in water. so i would remove the filter from the refig and flush out again.
Mar 25, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Refrigerators Logo
42 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
