Question about Garden
How is the spring inserted for the trigger to function properly
Fixing a trigger on an old impact wrench.
You will need to find a spring for the trigger, parts are hard to come by new unless it is a Snap-on or MAC brand.
Sep 07, 2016 | Impact Air Tools & Compressors
Cd won't eject on a 2010 buick lacrosse cxl
Try inserting an "old" CD into your radio, just under the lip of the stuck CD...this can properly trigger the "eject" function on your CD player...Hope this works...
Feb 15, 2016 | 2010 Buick LaCrosse CXL
How do I repair a non-functioning solution trigger
The trigger has tabs on each side that snap into slots in the handle so that the trigger pivots in the slots. The slots where the trigger pivots may have broken, if so the trigger will not push the valve open and allow the water flow. If the tabs are broken you will need to replace the upper handle. If you supply me with your model number I will determine the proper part for your model.
Dec 14, 2014 | Hoover SteamVac F5914-900 SpinScrub...
Hold down lock does lock i think there is a spring missing
The trigger lock spring (just one does both functions) is quite a challenge. It uses an almost invisible slot in the trigger for the small end and the long leg pushes upwards on the other part that is depressed by the palm of your hand. I had to try three times to get it to assemble right on my small Jonsered chainsaw. The two halves of the handle should go together by finger pressure when it is in there right.
Mar 28, 2011 | Garden
DeWalt DW972 cordless drill has intermittent variable speed trigger. (Battery is fine, recently replaced) How can I clean the variable resistor in the trigger or must replace the whole trigger module?
have to replace whole trigger assembly.
worn brushes in the motor can also cause intermittent function, if you havent already checked those. i'd replace those first if they have never been replaced or look worn, broken, cracked, or if springs seem worn.
Dec 14, 2009 | Dewalt DC727KA 3/8" 12v Cordless...
Wii won't "take in" disks.
There is a trigger switch that the disc hits when it is inserted, this tells the consol to pull the disc in, when a disc is ejected the proper way the system retracts the trigger so the disc can be ejected, By pulling the disc out with force your son has either broken the trigger and the consol cannot tell that a disc is inserted, or he has pulled the trigger backwards and the disc is not making contact with the trigger...You will have to disassemble the consol to inspect the trigger (unless you can see it threw the slot) and either place it in its proper setting or super glue it back together.. Another option is to send it in for repair...Hope this helps
Oct 03, 2009 | Nintendo Wii Console
Trouble reassembling a daisy buckmaster 840 bb gun. We can not figure out the trigger mechanism in order to fit the side panels back into place.
1) Stack the trigger, seer (long black metal piece) and trigger block (large L shaped silver piece) on top of each other, with the seer in the middle.
2) You should have 3 springs, the long one attached to the end of the seer, the skinny one on the bottom of the seer and the fat one back between the trigger and trigger block on the back side
3) Compress the trigger block and the trigger together thus compressing that spring between them, keeping everything together. Now back the entire unit into the stock cavity. This is tricky and will take some practice. Be sure to keep the pieces squeezed together.
4) Insert the pin through the side which is countersunk. It only goes one way.
Jul 19, 2009 | Toys
Hand safety control on gmc grass cutter
A hypodermic needle assembly configured such that the movement of a needle shield into position to block the needle tip occurs as a direct consequence of a longitudinal force applied by insertion of a syringe plunger is provided. The hypodermic needle assembly according to the present invention includes a needle, a needle hub, and a safety spring clip assembly, the safety spring clip assembly being configured to automatically launch from the needle hub and slide along the needle to shield the needle tip, thus preventing accidental contact with the needle tip. Additional mechanisms for launching the safety spring clip are also provided, which include using a trigger ring for rotating and launching the safety spring clip.
Jun 21, 2009 | Garden
Finger trigger has come apart. Diagram needed to reassemble.
go to this site .and you will be able to get a break down . http://www.toolpartsdirect.com/portercable/portercable-4.html
Apr 11, 2009 | Porter Cable-Cable FN250C 1-inch...
Poulan 3400 chainsaw throttle trigger
Its a missing or broken spring in the handle(trigger). If you look inside the handle you should see a circular spring around the post of the trigger. This spring returns trigger to idle position. If its missing or broken the trigger won't spring back.
Oct 12, 2008 | Poulan Garden
Garden Logo
24 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
