Good evening, I have attempted multiple times to print images and the paper keeps producing blank pages. Can you help me please?
  • kakima Jan 03, 2017
    Hi Jalen Law, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
    What make and model printer? What program(s) are you using to print?
  • 6 Answers
SOURCE: Canon MP730 won't print at all (blank pages).
try to move the blue nozzel over the printing head to the from the right to the left and try, it will work
Posted on Mar 20, 2008
Joed911
  • 4338 Answers
SOURCE: My printer only prints gibberish
With the printer on, pull the printer's AC plug from the wall.
Then power down the computer.
Wait 30 seconds, turn the computer on first.
Put the printer's AC cord back into the wall.
After the computer has booted to the desktop, turn the printer on. This should clear the issue.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on Nov 26, 2008
SOURCE: Printer prints multiple pages with DPR1260 print server
I was having the same problem when I added a Windows Vista PC to my home network. My older XP systems workd fine, but the Vista system would keep printing. The following fix worked forme in vista, may work in XP also.
1. First, be sure you have the latest firmware in your DPR1260. Version 1.24 is what I am using.
2. From the printer window (or via controlm panel) select your printer, then select Properties (either right click, or from the menu via File-Properties)
3. In the Properties Window, select the Ports tab. You should see your printer highlighted and checked, under the port heading next to thcheck box you'll see IP_192.168.x.x, under descriptio Standard TCP/IP Port, and undr Printer, the name of your printer.
4. Click the "Configure Port" button, be sure "LPR" is selected, not "RAW". Under LPR Settings, check that the "Queue Name" matches that in our DPR1260 status screen, and be sure SNMP Status Enabled is not checked.
The problem on my Vista machine went away when I changed from "RAW" to "LPR" settings.
Hope this helps.
Posted on Feb 09, 2009
  • 990 Answers
SOURCE: Ricoh SP C410DN Will Only Print One Page
Hello sir; you need to set up your system from printer, go to manue ,roll down to system , roll down to auto continue,then press enter ,
Posted on Feb 13, 2009
d2704
  • 101 Answers
SOURCE: laserjet 3015 is printing multiple pages on one sheet
exists special function in driver of the printer which quantifies pages of the document on one signet sheet. Sounds like "Multiple printing" you can manipulate or disactivate this function.
Posted on Mar 07, 2009
Media jam fuser
replace the fuser unit. and replace the transfer roller and belt,
Jan 30, 2014 | Konica Minolta Magicolor 2530 DL Laser...
Prints some blank pages
Hello Mike,
Please try to refill the catridge and if it dint help you then replace the Catridge ,which will surely pay off you..Thank you...
Please Post on how things turned or for further assistance..!!
Regards!!...
Jul 24, 2008 | Canon SmartBase MP730 All-In-One InkJet...
My Xerox 4150 keeps taking lots of blank pages through when printing multiple page documents sometimes 30 or 40 at a time
Two possible solutions to your problem.
If you are talking about grabbing more sheets than one from the tray, you need to make sure the tray guides are up flush against the paper.
If on the other hand you are talking about scanned/copied jobs, check the setting for your scanner, it may be set to letter size which is longer than A4, so the machine thinks it needs another sheet to complete the job causing a blank page to be sent.
Hope this helps
Jan 10, 2011 | Xerox WorkCentre 4150 Black and White...
Reading no paper paper tray is full
Instructions
  1. Check the display for an error message. If the display reads "Clearing paper from printer," the engine has detected a jam and is attempting to eject the jammed pages automatically. These pages will often be blank.
  2. Check the display for "Performing PRINT/STOP TEST" or "Performing SERVICE TEST." Either of these messages indicates that the printer is going through a test procedure that may eject blank pages.
  3. Reduce the amount of paper in the input tray if the printer is feeding multiple blank sheets at a time. The printer will pull extra pages through if the input tray is overfilled.
  4. Replace the paper in the input tray with the correct size if needed. If the 4600 printer detects the paper as an incorrect size for the print job, it may eject the paper without printing anything on it.
  5. Replace the ink cartridges if certain colors are blank on the page. Replace the black cartridge if printing a black text document that is coming out blank. The printer may attempt to print even if the ink level is low or empty, but will unable to print anything on the page, causing it to come out blank.
  6. Remove the sealing tape from newly installed cartridges. The tape covers the print heads and should be removed before installing the cartridges. If the tape is left on, it will prevent ink from getting on the pages as they print.
  7. Press the "Check mark" button on the control panel to enter the printer menu. Run a diagnostic so the printer can attempt to determine the cause of the blank pages printing. Press the up or down arrow to select "Diagnostics." Press the "Check mark" button. Press the "Down" arrow to highlight "PQ Troubleshooting." Press the "Check mark" button. The printer runs a diagnostic and returns to a ready state when done.
Jan 08, 2011 | HP LaserJet 4600 Printer
Lexmark 5400 series printer won't grab paper for printing
Whenever the printer doesn't pulls the paper please pull the pack of papers, browse through the papers with your finger and put them back gently.If it doesn't work it means the wheels that pull the paper are worn and you need to replace them.
For the second problem, this is not a printer problem but a software problem, please specify which software do you use so we can help you, as each software has individual options to print multiple pages. It will also be more logical to post the problem in the specific software area.
Good luck,
GetAFix99
Nov 17, 2009 | Office Equipment & Supplies
Producing blank pages
repeated nozzle cleaning (6 times) which almost emptied the cartridges but it is now printing
Jan 03, 2009 | Epson Stylus CX3200 All-In-One InkJet...
Dell A960 printing blank pages
I just sprayed windex on bottom of cartridge several times and wiped with paper towel until dark streak of black appeared. Then I dried off cartridge and replaced. It works now. Must have been clogged.
Nov 18, 2008 | Dell A960 All-In-One InkJet Printer
Printer acts like it's working then produces a blank page
Try to print first a self test page on the printer. Does it print a blank page also ? Do you have good or new ink cartridges in the printer ? Let me know.
Jul 31, 2007 | Dell A920 InkJet Printer
jasbo
jasbo
