My paper comes out without images - Office Equipment & Supplies
  • kakima Jan 03, 2017
    Hi Jalen Law, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
    What make and model printer? What program(s) are you using to print?
My canon ir2016 copier comes with blank paper when printing and the paper jamed before it reaches the paper pick up roller
Check very carefully it sounds like something small is caught in the paper path, probably a small piece of paper.
Dec 11, 2014 | Canon Office Equipment & Supplies
Paper comes out black
Check the image unit. And check the charge grid on the top of the drum. also check the three little springs that the top of the machine comes down on under the image unit.
Feb 28, 2014 | Minolta EP1031/1031F CS/PRO Copier
Docucolor 12
check scanner unit which hit the opc drum, may be hide by something
Dec 27, 2013 | Xerox DocuColor 12 Color Copier
Risograph pressure roller isnt coming up
Dust on paper exit sensor? (small hole between the exit belts)Sensor blocked or defective?
Sep 12, 2012 | Riso Office Equipment & Supplies
Got the C5180 from a relative because it didn't work. I tried a new black ink tank, it doesn't print anything in black. Color print looks weak and washed out without black for shadow, and black...
The printed output is fuzzy, blurry, or grainy, or the edges of objects in the images are jagged. Solution Follow these steps until the issue is resolved. Step one: Check your paper
  • Many papers have printing and non-printing sides. Load the paper with the printing side down.
  • Use the correct paper type for the project. For everyday documents, plain paper works well. For documents with dense printing, such as high-contrast graphics or photographs, use HP Advanced paper for the best results.
  • If these steps do not help, try a different paper. Ink might not bleed as easily on heavier paper. Paper that does not accept ink well is also prone to bleeding and smearing. HP designs its inks and papers to work together.
Step two: Check the settings
  1. In the program being used for printing, click File , and then click Print . The Print window opens.
  2. Make sure the appropriate product is selected, and then click Preferences or Properties . The Preferences/Properties window opens.
  3. Click the Printing Shortcuts tab. Consider modifying some or all of the options in the Printing Shortcuts menu to increase print quality.
    • Print quality : If the quality of the printouts is not acceptable, try increasing the print quality. To print more quickly, try decreasing the print quality.
    • Paper type : If one of the options matches the paper type exactly, select it instead of Automatic .
    • Paper size : Make sure that this option matches the paper loaded in the product.
    To see additional options, click the Advanced tab, and then click Advanced Features . The Advanced Features window opens. Consider changing the following option: Ink volume : Adjust the amount of ink that prints on a page. For lighter images (less ink), drag the slider to the left. For darker images (more ink), drag the slider to the right. The lighter the ink volume, the more quickly the printout dries.
Step three: Check image resolution Make sure that the image file has enough resolution for the size of the printed picture. Although many photo applications can enlarge an image or part of an image to any size, eventually the individual pixels become visible and the whole image looks blurry. Here are some general guidelines for image file resolutions:
  • 94 pixels per cm (240 pixels per inch) for images to print on smaller format photo paper, such as 10 x 15 cm (4 x 6 inch)
  • 117 pixels per cm (300 pixels per inch) or higher for larger format photo papers
  • Lower resolutions might produce acceptable images when printed on rough-textured paper
Step four: Align the cartridges If the previous steps have not improved the appearance of the printout, align the cartridges. See the user guide for alignment instructions.
Jul 02, 2011 | Office Equipment & Supplies
I have a IR2200I copier and paper keeps getting jammed when feeding through the machine where it should circulate at the side and come out onto the feeding tray. The paper just folds back inside the...
it sounds to me like the registration clutch is faulty. The symptoms of faulty clutch are: "Z" or "S" folded paper in section before drum ( in right side way door ) and image goes out out of center or in very big angle.
Its hard to say without seeing the machine.
You can also try to clean the paper path rollers in right side way of copier, but I don't think that will help!
I can only give you the service manual, write me on emma.servis@gmail.com.
Apr 29, 2011 | Canon iR 2016i Black and White Copier
Printer hp laserjet p2015n
laser unit mirror is dirty clean it than solve it
May 29, 2009 | HP LaserJet P2015dn Printer
Want to copy images from notebook paper without blue lines apparent
yes, you are loking for border erase function. when you find it then look for what looks like two peices of paper side by side, you will then possible be allowed to adust the sixe of the erased area
Apr 24, 2009 | Xerox DocuColor 12 Color Copier
Printing photos onto 6x4 inkjet paper
which is the model of the printer, not all the printers permite to you do this
Oct 30, 2007 | HP PSC 2175 All-In-One InkJet Printer
k24674
jasbo
jasbo
