Question about Coby Televison & Video
Coby TFTV4028 LCD TV won't turn on. Blue light is on, but pressing power button doesn't do anything.
I am trying to troubleshoot this as to whether it is the main board or the power supply. There is 110V AC at the input to the power supply board VP270UG01-GP ver. 1.0, and the fuse tests ok, but the outputs never have the stated voltage 5V, 24V. Pin 9 on CN3 is labeled as PSON on the board, which I guess is a signal telling the power supply to wake up, but this never changes from 0V when the power button is pressed. Is it more likely to be the main board 002-FV40-2810-00R ver 1.0 not sending the required signal that is the problem? Is there a way to verify this before I order and replace the wrong part?
  • Coby Master
  • 6,694 Answers
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts. http://electro-medical.blogspot.com/ In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here.
Posted on Jan 03, 2017
BoiseLCD
  • 63 Answers
SOURCE: I have a NS-LCD37-09 tv. No picture or backlight
Your main board is faulty. I've done several of these but haven't been able to figure out which component is actually bad these yet. I've simply had to replace the board itself, and it fixes it every time. One thing you can do to get your backlights to come on (and so you know I'm not Jive'n you) Is unplug the three wire bundle that spans from power supply to main board. This will usually make the backlights fire up. I even had one that after I left it that way for a minute (with the backlight on) it suddenly started working again! But this was short lived. :-(
One time I even tried recapping the entire main to see it that would fix it. It did not. I think it might be something to do with the small chip labeled SL37HA37. It's a 16 legged bastard near the 3-wire plug I told you to pull. It's that or possibly the bigger IC near it that has a heat sink on it. The ball grid array solder joints may be faulty. Just guesses, if any smart guys out there figure this one out, be sure to tell the rest of us please!
Thanks, Chris Boise LCD www.boiselcd.com
Posted on Apr 23, 2010
SOURCE: ILO LCD, Power supply issue, MLT169B. 24v output is dead.
I want to know R3 value
Posted on Dec 27, 2010
budmrtn
  • 11361 Answers
SOURCE: Sharp Aquos LC-42DH77E 42" LCD TV TV appears to
The PNL-POW (LCD panel Power) and the PS-ON will be 0V until the main board send out the signal to turn them on, it is working.
Do you get backlights?
Did you check the fuses on the Inverter board? You power supply is working.
This service manual may match your chassis:
http://elektrotanya.com/?q=showresult&megnev=Sharp&megnev2=LC-42DH77E&kategoria=&kat2=all
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Posted on Jun 01, 2011
Testimonial: "Helpful"
bugoy31
  • 1238 Answers
SOURCE: Fault TV
that is main board issue..
Posted on Jun 15, 2012
spr1949
  • 1182 Answers
SOURCE: Power supply board troubleshooting - p50x01au
If you have a service manual, please match the voltages as per that and problems might be in areas where these do not match. But read on what condition these voltages are to be checked, this is usually written in a service manual, i.e, without any signal or feeding some signal etc.
Posted on Aug 06, 2012
How to test my tv to find bad part to replace ?
Mr. Folk have you took a flashlight when picture goes off and shine in screen and press like menu button and look to see if you can see any letters or anything, if so you probably have a defective screen assy or backlight. This may help?
Feb 08, 2016 | Coby 40 TFTV4028 LCD TV
Need fix how do i make it stop flickering
Coby lcd tv keeps flickering Flat Panel Televisions ... - Fixya
www.fixya.com > ... > lcd tv keeps flickering > Flat Panel Televisions
Coby flat panel televisions lcd tv keeps flickering related questions and answers. Ask your Coby ... Why does my Coby 40 TFTV4028 LCD TV keeps flickering.
Coby adjust air fuel mixture Flat Panel Televisions ... - Fixya
www.fixya.com > ... > adjust air fuel mixture > Flat Panel Televisions
Coby flat panel televisions adjust air fuel mixture related questions and answers. Ask your Coby ... Coby 32 in tv ... to last channel, and will stop, and will display the first channel it has got. Then we have to make adjustments on channels. ... Ad. Question about 40 TFTV4028 LCD TV. 1 Answer ... Flickering can be adjusted.
Won't turn. on red standby light changes to on but then
Jan 04, 2016 | Coby 40 TFTV4028 LCD TV
Can a tv inverter board cause tv to not display
inverter board may be used to power backlight for the lcd display. If it is similar to laptop lcd displays in functionality .
http://www.ehow.com/how_7501465_check-tv-inverter-board.html
Apr 17, 2015 | Coby 40 TFTV4028 LCD TV
My coby tv went off and will no come on( tftv4028)
Unfortunately, this usually means a failure on the main TV board. This part is hard to find and expensive to replace. Lots of people have this failure. Sometimes it is just the power supply, but most of the time it will be the mainboard.
Aug 08, 2012 | Coby 40 TFTV4028 LCD TV
Try changing the input device to something you are sure works.
Look for any loose contacts in RC jacks/sockets/Cable. Check your power outlet for any loose contacts.
Jul 30, 2012 | Coby 40 TFTV4028 LCD TV
Where to find Mainboard, 002-FV40-2812-00R?
This Coby LCD TV mainboard is found in some models like the TFTV4028. shopjimmy.com and eBay sometimes have them. Usually they are salvaged from sets with broken panels. There are similarly names ones (002-fv40-2810-00R and 002-fv40-2812-00R but they seem to be incompatible,
Jul 15, 2012 | Televison & Video
My coby tftv4028 has major overscanning. i need the codes to open service menu and adjust height and width
In most cases there are NO scanning adjustments. More likely check the "picture size" or "format" button on your TV remote control or on your cable or satellite remote control. Good Luck : )
Jul 26, 2011 | Coby 40 TFTV4028 LCD TV
My 19" LED Coby tv
Consumercare@cobyusa.com
I looked but no known phone number
Feb 06, 2018 | Coby TFTV3225 32 in. LCD TV
Need 4 digit code for dish network remote
Hello! My name is Becki, with DISH Network. Here are some simple steps to program the remote to the TV, adn the codes to do so. You only need a 3 digit code in this case.
1. Hold down the clear TV button until all lights light up at the top of the remote
2. Punch in a 3 digit code (provided below)
3. Press the # (POUND) button
4. Try powering the tv on/off, and the volume. If one or more of these functions do not work, start over from step 1 with a different code
505
594
627
633
Becki Barned
DISH Network Customer Service
Jun 21, 2011 | Coby 40 TFTV4028 LCD TV
Try to connected my laptop sony vario to coby lcd tv TFTV4028 40" lcd monitor used windows 7 64 professional. On the dispaly setting menu windows 7 it saw the LCD TV TFTV4028 and it said nosignal. ...
Your tv doesn't supports the resolution the laptop is sending it . To fix that select in the display settings a lower resolution before clicking Apply - use 1280×1024. After that (once the tv is working) you could try to use higher ones.
Jun 12, 2011 | Computers & Internet
Televison & Video Logo
77 people viewed this question
Top Coby Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Coby Televison and Video Expert? Answer questions, earn points and help others
