Question about Sunbeam Dryers
How do I rewire a sunbeam mixmaster model k? has 3 speeds on switch but only getting 1 speed
From the 1930s 3 speed switch and wiring
  • 4 Answers
SOURCE: Sunbeam Mixmaster Heritage Series Model 2350 speed problem
The speed control on the back is simply a variable resistance potentiometer, the same thing that controls the volume on older amplifiers. The output current to the motor is supplied by the printed circuit board in the bottom of the unit. This allows gradual increases in speed to avoid over-torquing the motor on speedup. Even the poshy-posh-posh mixers do this.
At least it still works. The most common problem is the cheap plastic drive gears that strip out with a mild cookie dough, this jams the beaters together and requires burial-at-dumpster.
Posted on Dec 16, 2008
SOURCE: 3 speed switch 4 wires where do they go????
corrected by trial and error
Posted on Feb 11, 2009
  • 3 Answers
SOURCE: Sunbeam Mixmaster model 9 speed control problem
OK, this may not be a solution, but might help you get there.
The speed control is NOT a potentiometer, it is a mechanical governer, and may be out of adjustment, or one of two components in the speed control mechanism has failed. The following is a test/ adjustment procedure.
During this procedure you will not be fiddling with electrical components (No risk of shock) You will be making adjustments with the motor running.
In the centre of the speed finder dial is a chrome cap. This can be *carefully* pried out. Be gentle, it's easy to chip the phenolic resin plastic.
Behind this cap is a nut around a threaded part with a screwdriver slot. Using a spanner and screwdriver to stop the centre part turning, loosen the nut some.
Turn the speed finder dial to 1. Plug the motor in and switch on. Whilst restraining the outer nut with a spanner, turn the central screw. From memory, it needs to be turned clockwise, that is, screwed inwards. The motor should respond by slowing down. Should you get no speed change, try turning the screw the other way some.
If you get a speed change, continue turning the screw in that direction until the motor stops. Now screw the other way until the motor just starts again.
This is the lowest speed and corresponds to 1 on the dial. Check the speed finder dial is still pointing to the 1 position. Lock the adjustment screw by restraining the central part, and turning the nut clockwise with the spanner until tight. Try turning the dial to see that the speed changes smoothly throughout the range. You may need to tweak the adjustment a little to get things just right.
Once you're happy with the speed control refit the chrome button, and you're done.
If you could get no speed change, one of two components under the speed finder dial has indeed failed.
Now you will need to determine just what the machine is worth to you. A motor specialist should be able to diagnose which part has failed. However, new parts will not physically fit and modifications will be needed. This could prove costly. If you know an inveterate tinkerer, you're costs could be substantially lowered.
Best of Luck.
Posted on Jul 11, 2009
  • 3 Answers
SOURCE: Sunbeam Mixmaster 12 speed may need lubrication
Part 1. Oiling the model 12:
Anyone can do this part.
On the top of the motor are four places where oil should be applied.
Starting from the speed finder dial and working forward-
There is a small hole on the top of the motor, just in front of the speed dial. Using a wooden skewer or a match, clean the hole out, and apply two drops of good quality sewing machine oil.
On top of the motor, and near and behind the juicer attaching cone is another hole, sort of key-hole shaped. Clean it out and put in one drop of oil only.
Three drops of oil go into the juicer cone. Let them run down the side of the hole.
Next to the juicer cone is another round hole. You may need to turn the handle as in removing the beaters to uncover it. Clean this hole too, and apply another three drops of oil.
Do not apply more oil than specified. It will get into the works where it shouldn't.
The following proceedures assume some mechanical ability. Read first to assess whether you are competent before starting.
After all these years, the gears in the front of the motor housing probably need fresh grease. This is a fibre based food grade grease that can be obtained from most bearing sellers. (I used a non-food grade grease, but I have to watch that the motor doesn't get too hot, and the grease run down the beaters, which can happen in extreme conditions.)
Prepare to get greasy during this proceedure. Latex gloves are an asset for doing this job.
Remove the cover plate in the centre of the front, and then the central screw from the front and pull away the front housing cover and handle. Don't loose the coil spring inside. It goes over the screw you just undid.
Unclip the return spring on the beater ejector, and remove ejector and spring together, slide the ejector down and off the beater spindles, then up and out of the guides..
There are four screws that retain the gear cover. The lower right hand one also retains a wire. Remove the screws, and gently bend the wire so the cover can be removed. There is a gasket underneath. Take care not to break it, it's brittle.
Once the cover is away, the gears and worm shaft are visible. Using a pop stick or old screw driver, remove the grease around the under side of each gear. A square headed set-screw retains each gear. When you find each screw, remove it completely. Turning the worm shaft will make the gears rotate.
Once both screws are out, pull the beater drive shafts downwards and out of the housing, and lift out the gears.
Using pop sticks, paper towels etc, but NOT solvents, clean out the gear space. Remove all the grease possible. A toothbrush is good for cleaning the worm thread. Use someone elses.
Wash the gears and shafts in petrol, kerosene or similar and dry thoroughly.
Reassembly is the above in reverse order, first filling the gear housing with fresh grease.
Grease each drive shaft lightly before refitting. Note the holes for the set screws in the shafts.
The nylon gear goes on the left, brass under the juicer cone.
Fit the nylon gear first, working the shaft upwards until the locating hole in the shaft can be seen through the screw hole in the gear. Fit and tighten the set screw.
Align the brass gear so both screws face forwards at the same time when engaged with the motor worm, to prevent the beaters clashing. You may have to put the brass gear in and out a few times to get the right teeth engaged with the worm shaft. Then slide the shaft in, once again observing the alignment of holes to ensure the set screw locks the gear securely.
Put everything else back in reverse order. Apply a smear of grease for the beater ejector where it slides, and don't forget to put the wire back under it's screw.
Part 2, speed control.
The jerky operation at low speed is probably due to dirty points in the governer. Addressing this involves disassembling the rear end of the motor.
DON'T pull the motor armature out of the housing without first removing the brushes during this proceedure. There's no need to remove the armature, but if you're curious....
Remove the chrome cap from the centre of the speed finder dial. Remove the lock nut from the thrust control screw under the cap. Remove the dial, catching the washer that goes under the nut.
There is a resistor, usually green, and a capacitor, a small aluminium cannister under the dial. Gently pry the retaining legs away from one end of each and remove them. Note which one goes where so you can put them back correctly. Marking with a felt pen is a good idea.
Now are visible two slotted screws. Remove these screws and pull the governer housing back and away from the motor. Note the pin with a plastic head, and remember to put it back when reassembling the same way around.
Locate and clean the points with a slip of soft wood and metal polish. Clean away the polish thoroughly. Do not use emery paper, it will make the points arc, and speed control will be worse than now.
Put everything back the way it came off.
To reset the governer, leave the locknut on the thrust controling screw loose. Set the speed control to position 1. Whilst pressing the dial home with one hand, screw the thrust screw in or outwards until the motor just starts to run, and lock the screw by tightening the nut. Test the control for full range, and tweak by slightly altering the thrust screw position as required. Getting the speeds just right first go is usually a fluke.
Replace the chrome cap and you're done.
Posted on Jul 18, 2009
SOURCE: I have the aloha model 5745, need to replace speed
I'm an electrician and
I just replaced the speed switch on a 5745. This people at Aloha Housewares, Inc. were very nice and speedy in sending a new unit at no cost.
Connections are:
Posted on Aug 14, 2009
Sunbeam mixmaster 12
There's a governor assembly inside that is bot working any more.
Sep 15, 2016 | Sunbeam 1957 Mixmaster Model 12 Kitchen...
How do I tighten the speed control dial on a vintage Sunbeam Mixmaster PowerPlus?
There is a cover plate over the screw that you need to tighten. This cover plate is held in place by two spring latches, 180 degrees apart. Use a small flat-tip screwdriver to depress first one latch, then the other. Don't use too much force - the latches are plastic and will break if treated roughly.
Jan 27, 2015 | Sunbeam Food Mixers
How to disassemble a sunbeam 2370 mixer
To disassemble a sunbeam mixmaster 2370, find four plastic snappers arranged at 1, 5, 7 and 11 o'clock around the front circle of vents. They can be seen with the help of a good flashlight. un-snap them and the top and bottom shells will separate. From there on, it is clips and screws. Good luck!
Nov 28, 2013 | Sunbeam 2370 MixMaster Series Stand Mixer
I have a Sunbeam Model A24 Mixmaster which will only operate at fast speed , I.E. the motor speed control no longer functions. Is it the capacitor? I have checked the points and they appear good.
G'day tandjcox842, did you get an answer to your question? If not, and you'd like to offload your mixmaster, I may be intersted. I've got one that works well but is missing parts. Regardz, Perry.
Jul 17, 2010 | Sunbeam 2545 Mixer
Mixmaster motor won't spin. Leads from circuit board to motor read 119 volts at the motor. voltage does not vary when speed knob is rotated but does turn off & on. 275 W sunbeam mixmaster, white...
so far I determined the thermal fuse had blown. I jumped around it but can get replacement. Now the motor runs full speed when turned on. I suspect the pot turned by the speed knob is bad. Having trouble locating a replacement circuit board.
Jan 19, 2010 | Sunbeam 2366 MixMaster Series Hand/Stand...
Sunbeam Mixmaster is smoking from the motor.
I wouldn't turn it on again , if the switch is smoking then for all practical purpose;s the brush;s are nearly shot as well. I would look around the good will thrift shops or a Salvation Army Store you ;ll find a nice one there for less than a repair bill. You never know what you will find there. Have fun hunting.. DFD please rate me. Tku
Apr 11, 2009 | Sunbeam 200 Watts 2372 MixMaster Series...
Dec 14, 2008 | Sunbeam 2346 Heritage MixMaster Series...
You can download the manual for your specific model there, and most of them that I saw included at least basic maintenance like oiling and greasing locations. Good luck!
Oct 26, 2008 | Sunbeam 2386 MixMaster Series Stand Mixer
My sunbeam mixmaster is stuck on one speed - fast!
it will be the motor suppression capacitor fitted accross the speed control. When they fail and go short circuit, sunbeams run at their highest speed. Remove it and replace and all will be well.
Feb 09, 2008 | Food Mixers
Sunbeam mixer
When you open it, there is are contact points and a piece that has to touch to change the speed. It may just be slightly bent or out of place. Some food may have gotten in there.
Nov 25, 2007 | Sunbeam 2485 MixMaster Series Hand Mixer
Dryers Logo
Top Sunbeam Dryers Experts
Are you a Sunbeam Dryer Expert? Answer questions, earn points and help others
