Question about Sewing Machines
Refill a bobbin - Sewing Machines
  • Sewing Machines Master
  • 11,500 Answers
Please provide the make & model of your machine.
Posted on Jan 03, 2017
Needle thead isnt picking up the bobbin cotton
the first thing that comes to mind, is to refill the bobbin and then re-thread the machine. you have probably already done this, so next I'd check to see if your using the appropriate bobbin for the machine.
Feb 26, 2016 | Sewing Machines
I am having problems with the hand knob & i can' seem to get it to work. So I can refill a bobbin thread.
If you can't get your machine to fill a bobbin, you can purchase a stand-alone bobbin winder at the local fabric store (JoAnn's and Hancock's usually have them or you can buy them online) for around $25. Makes it easy to fill bobbins and saves wear-n-tear on your machine.
Oct 15, 2015 | Sewing Machines
Can' rewind the bobbin for my sewing machine
have you loosened the hand wheel . bobbin will not wind if the wheel is tight
Mar 17, 2015 | Brother Sewing Machines
Winding bobbin
The metal bobbin wind stopper beside the wind pin needs to be adjusted to allow the bobbin to fill completely. Be careful if you try to do this yourself as there is a nut inside the machine backing the screw. If you loosed the screw to far, the nut will fall into the machine and you will need to take it in for service:(
Aug 06, 2013 | Brother PC-420
Threading bobbin singer athena 2009
Sorry... hate to say it but modern home singers are $%#&*@.
Have you tried a new bobbin? If the "spindle" spins... the bobbin should spin. Maybe your bobbin is busted or something?
Aug 02, 2012 | Singer Sewing Machines
Elna 6200 jammed on bobbin refill setting
Remove thread. Remove the needle plate. Turn hand wheel toward you. Rethread machine. Make sure presser foot in up position when you thread needle. Make sure needle all way up in shaft, flat side back and more rounded side facing you Turn hand wheel toward you again and observe the following: As needle comes down, make sure the needle's eye makes pass by the scarf of the needle. Hope this helps, and if not, try
Apr 03, 2012 | Sewing Machines
Bobbin winder
then there is something wrong with the bobbin winder & it needs to be repaired
Feb 29, 2012 | Brother CS-80
I've lost the manual to the Singer Tiny Tailor mending machine M100A and need to know how to refill the bobbins. Can you help me? Thanks
Jan 18, 2010 | Singer Sewing Machines
How do i refill a bobbin 7 thread machine
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} To wind a bobbin, guide the thread from the spool post to the small round tensioner /guide on the top of the machine.Wind a few turns of thread onton the bobbin.Place the bobbin on the bobbin winder post. Release the hand wheel and wind the bobbin as full as you like or until it stops. Remove the bobbin,place it in the bobbin case and insert the bobbincase into the hook.
Beginning with the spool, guide the thread through the thread guides to the tension assembly. Pull the thread through the tension assembly and test it to make sure the tension is working correctly.
(To do this test, adjust your tension setting to normal or medium or 5 or something in the middle. Raise the presser foot and pull the thread through the tension. It should pull easily!! Lower the presser foot and pull the thread. It should pull noticeably harder.) If it passes this test, continue up through the take up lever,then down through the thread guides to the needle. Make sure your needle is fully inserted and turned the correct way.( If you load your bobbin case from the left side,the needle rule is normally FLAT to the RIGHT is RIGHT. There are some exceptions. If you have a newer style drop in bobbin or your bobbin case loads in the front then the rule is FLAT to the BACK.
Apr 29, 2009 | Brother LS-2125 Mechanical Sewing Machine
Sewing Machines Logo
26 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
