My slice machine is cutting lines around the outside of the die cut pattern and a line inside of pattern, ive cleaned the cutting board, honed the blade, change blade & tried other cartridges
jackboy
  • 2985 Answers
SOURCE: tops of characters cut off
Go to www.fixyourownprinter.com for expert help on this particular problem
Posted on Jul 12, 2007
  • 286 Answers
SOURCE: Brother MFC-5440CN Printer Problem
If this only happens when you are copying.
1. Your scanner glass is dirty. Open the lid, use windex to clean the flatbed. Look on the left side. You should see a strip of glass, with the scanner sitting under it. This strip is used when the document feed is being used. Make sure it is clean. Most common problem is getting a little whiteout or the sticky residue from scotch tape on this glass, which causes lines down your copies.
Clean it with alcohol which will dissolve the sticky stuff and the whiteout.
If this does not solve the problem, the CCD scanner in your machine might be going bad.
Posted on Dec 30, 2007
Candyhelp
  • 136 Answers
SOURCE: answering machine wont pick up it just cuts off incoming call leaving line busy
just set the amount of rings higher on the back of the phone and make sure all you old messages are deleted and also make sure its not set to do not disturb
Posted on Mar 30, 2008
Tinteiros
  • 85 Answers
SOURCE: poor quality output
Hi If your printer has been left unused for a while your print head is clogged.
You need to unclog it with a print head cleaning kit like Magic Inkjet Flush or if in a rush give it the Magic sauna treatment.
Heres how:
1. Remove print head
2. Hold print head directly in escaping steam from a kettle for 5/10 seconds only
3. Wait 5 seconds and sit it print head down onto a paper towel untill you get an inky foot print.
4. Print test.
5. If any white lines repeat above.
6. Also try wrapping in a paper towel and FLICK DOWNWARDS to put fresh ink into print head after steaming.
Good Luck!
Tinteiros (Ebay)
Posted on May 30, 2008
  • 13 Answers
SOURCE: I have a juki mo-3614
first, pull out the bvlades and make surte they are sharp. It could simply be that they are dull. Next, line tyhe bottom blade up level to the surface of the needle plate. The top blade should be adjusted to where it slices against the botom blade. You may have to experiment with the height adjustment on the top blade, assuming you have a suitable cutting edge.
Posted on Dec 15, 2008
Burda pattern 6921 Please can you give me information on how to make the lining for this jacket?
Um, that may be difficult to explain. Generally, you would have facings all around the open areas. Then use the same jacket pattern to cut out the lining, BUT be sure to add a double amount of seam allowance for stitching the facing to the lining.
http://www.threadsmagazine.com/item/4366/bag-your-jacket-lining/page/all
https://www.youtube.com/watch?v=t3u4-ylDMv4
https://www.craftsy.com/blog/2016/03/lining-pattern/
Mar 18, 2017 | Sewing Machines
Tip
Making a wooden picture frame with perfect corners
Picture frames are very easy to make, but many people make the same very basic mistake that will ruin your frame. It is very important that you follow the carpenters rule of measure twice and cut once. If you don't cut the sides of the frame to be the same length, and you cut the angles of the corners slightly off then when you put it together the final corner won't line up.
The things that you are going to need is a miter saw, some clamps, a backer board and a drafting squares to make sure you have the right angle.
To set up take your backer board and cut off a piece that's around 4 inches to be used as a sliding marker gauge. After cutting it off attach a small piece of wood to keep the slider from shifting around.
With the saw unplugged and turned off clamp the backer board to the back of the saw. To cut the corners of the a frame you need to set the saw to a 45 degree angle. Make sure to check the angle using a drafting square align one side with the backer board and bring down the saw blade align them to make sure its a 45 degree angle. When you think that its right grab yourself a piece of scrap wood and make an initial cut. After cutting the test measure the angle to make sure that it is the right angle.
When you are ready to cut the frame itself take the four pieces of the frame and make an initial cut. Once all the boards have been cut once take your slider marker to the length that you want the sides of the frame to be and clamp it in. Take the first two sides and one at a time line it up with the backer board with the angle on the outside and the cut point against the slider. Turn on the saw and cut the other end. Repeat these steps to cut the other three sides.
After all the sides have been cut use a 90 degree angle to align the corners of the frame. Lay out all the sides of the frame and line them up as tight as you can. To connect them you can use a staple gun to staple the corners together. If you were aligning it and pushing the sides together when you stapled the corners you should have perfectly aligned corners.
Now all that's left is to sand it down and get the inside ready for a picture and stain it if you want.
on Feb 17, 2014 | Saws
When u start the car it dies out why?
There are many issues that can cause this. Most common are fouled spark plugs, clogged fuel injectors, bad Oxygen sensors, PCV valve stuck, broken or disconnected vacuum lines. DFENSO plugs and O2 sensors will fix those problems. Vacuum lines require a thorough inspection using the diagram inside the hood; tracing every line and inspecting for cracks. Your fuel injectors are also DENSO, they can be cleaned using specialized machines... a Bosch service center has the machine to clean them and test the spray pattern for proper flow. Vacuum lines are easy to replace and the PCV valve just screws on. If these don't work, then you have an ECU problem. Rebuilt ones are available on line for around $100.
Mar 12, 2015 | 2004 Honda Accord
Why is planer leaving scratchs in wood after changing the blades
1. If the scratch is on the side not being cut, check the infeed and outfeed tables for debris or defects.
2.. If the scratch is on the cut side of the board:
(a) check for problems with the rollers and any parts that hold the board down while being planed. (b) check for nicks in the blades. Shift the blades a little left and right so the nicks don't line up; or (c) hone and reset the blades.
Oct 07, 2014 | Tools & Hardware - Others
Slice machine wont home in proper position
The same thing happened with mine so I changed the blade and it worked.
Aug 13, 2013 | Making Memories Slice Die-Cut Machine...
Trimmer bogs down after starting. Giving more trottle engine stalls.
Check the air filter isn't dirty.
If the machine runs ok on high speed but cuts out while idling, the idle speed may be too low. There is usually an adustment screw for increasing the speed.
If the fuel line is a flexible type which moves around inside the tank, check it is able to move freely because if you are cutting at awkward angles, the end of the line can end up above the surface of the fuel, **** in air and airlock the line. You can eliminate this as the problem by fully filling the tank.
Check whether there is a one way check valve on the tank. This vents air into the tank as the fuel leaves for the carburettor. Sometimes particles of dirt can get stuck in this.
Apr 21, 2011 | Homelite Garden
In my 1986 f250 changed the fuel filter between carb and fuel pump ran fine but noticed i was leaking fuel due to the fact i kinked the line. well I cut out the area that kinked with a hand saw and...
I hope you cleaned the fuel line so there weren't any cuttings in the line? I would have probably used a small round file to clean burrs inside metal line. I don't know liter size of engine? I looked at 5.0L--carbed engine--fuel pressure 5--7 psi.
If your fuel injected, the pressure is a lot higher.
Nov 09, 2017 | 1986 Ford F 250
Repair pin hole in metal fuel line for Pontiac Gram Am Car.
I would suggest cutting the line in two and bridging the two pieces with a piece of rubber fuel line hose. Use a hose with an inside diameter within which the metal line will fit snuggly. Use a clamp on either end of the hose.
May 06, 2009 | 2005 Pontiac Grand Am
I have a juki mo-3614 serger and I can't seem to get the blades lined up right for cutting. It just seems to want to roll the fabric instead of cut it. How do I line up the blades the right way.
Nov 29, 2008 | Juki MO-644D Mechanical Sewing Machine
Answering machine wont pick up it just cuts off incoming call leaving line busy
Mar 28, 2008 | Uniden Cordless Phone
22 people viewed this question
k24674
jasbo
jasbo
