Question about Electrolux Refrigerators
New electrolux french door fridge. I connected the water line and plugged it in. held a glass in it for about 2 minutes to get the water through. no water. Is there something else i need to do?
I verified water getting to the fridge connector
SOURCE: HOOK UP OF ICE MAKER TO THE WATER LINE
The ice maker is not making any ice, or water or crush ice. The wheel that crushes the ice will not spin. Please help
Posted on Aug 19, 2008
  • 16 Answers
SOURCE: No water to door dispenser
The water lines might be frozen. The found the water lines in my fridge behind the bottom drawers and used a hair dryer to melt the ice.
Posted on Jan 23, 2009
  • 29 Answers
SOURCE: Why does my water line shake on the back of the fridge?
Does it shake all the time
Posted on Feb 24, 2009
projdoc
  • 2237 Answers
SOURCE: Water build up on inside of fridge door of ge french door fridge
humid air in the house. any time you open the fridge, house air is sucked in. when you close it, the fridge cools the air and moisture from the warm air condenses on any cold surface. also check to see if there is a gap in the seal.
Posted on Aug 26, 2009
  • 1891 Answers
SOURCE: French Door with bottom freezer Electrolux ice
sounds like the drive in icemker head is bad and not turning the timing wheel . the timing wheel controls the harvest and the water comming in ect . best to replace the icemker with ther kit . come with instructions . mm hope this helps . if more info needed i need the model # and ser of your unit .. feed back pls ..
Posted on Dec 11, 2010
The Ice machine wont produce ice.
here are some things to try first before calling repair person.
unplug the unit, if you can remove the unit , do it., IF NOT, JUST REMOVE THE ICE TRAY UNIT, leave unplugged for 30 minutes.
make sure the water is following, see if you get cold glass of water, this means the system has water, and IF NOT, check the line frozen or damaged,
after 30 minutes plug the unit back in, install the ice tray properly secured in place, make sure the leaver flush against the ice maker
it may take 1 hour or more and go look see if it producing ice
if it is not producing ice than call a repair person.
Oct 02, 2015 | Electrolux EI28BS56IS (278 cu ft) Bottom...
Ice Maker works but water dispenser doesn't
The solenoid valve is located where the water line connects to the fridge. There is a micro switch that the paddle in the door operates when you push a glass against it. Sometimes the plastic locating pin that holds the switch in position breaks and allows the switch to move away from the actuating lever.
Aug 26, 2017 | LG Refrigerators
Why do I have warm water coming out of my new Fridgidaire french door style fridge
Check to see if the supply line coming into the unit from the rear is not near the compressor. The heat from the compressor will make the water hot.
Oct 17, 2012 | Electrolux EI26SS55GS Stainless Steel ...
Electrolux EW28BS71IS French Door Fridge no water and no ice
First check that you have good water pressure to the water valve. If you do, then the problem is in your refrigerator. And the most likely fault is the solenoid controled water valve which is a one in two out valve. Follow the water line from you house input and the first place it connects is that valve.
Jan 10, 2012 | Electrolux Refrigerators
Recently purchyased electrolux 3 door . Had water supply disconnected for approx 8 hrs and now have water back on but ice maker will not make ice
You have to open the water hose let the water drain for at list 2 to3 minute so you can have the water line free with air package, and close backthe water hose
Oct 24, 2010 | Electrolux EI28BS56IS (278 cu ft) Bottom...
I have a brand new French door electrolux refrigerator. It was just delivered today. The water dispenser doesn't give cold water - just room temperature. It's only been plugged in for 8 hrs but I...
We have had two different Electrolux French door refrigerators, over the past 2 years and the water never becomes cold. We were told this is because the the storage tank in this particular refrigerator is so small. You just have to drink your water with ice. Unfortunately, we have had recurrent problems with the ice maker as well! Sorry - but these refrigerators are very problematic and I would not recommend them to anyone!!!!!!
Sep 12, 2010 | Refrigerators
Warm Water out of water dispenser
Usually the coolness comes from a large coil of plastic tubing in the refer compartment that stores the water. Check that the refer compartment is cool enough. Also see if running a large glass or two becomes cool again and stays cool for a while. Usually the very first 1/2 glass may be warm until the "cool" water that is stored in the coil of tubing finally makes its way to the dispensor.
Aug 25, 2006 | LG LRFD21855 Stainless Steel French Door...
Refrigerators Logo
20 people viewed this question
Top Electrolux Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you an Electrolux Refrigerator Expert? Answer questions, earn points and help others
