Question about Husqvarna Sewing Machines
#1 Husqvarna 1200 sewing machine the Bobbin winder retainer and arm came off. How does it go back on?
textile
  • 10 Answers
SOURCE: Problem with winding thread onto
first you must make sure the winder shaft is turning by moving it to the right a little and see if you can turn it by hand.
If it is turning ok then there is a rubber ring on the other end of the winder shaft and it should come in contact with the drive which turnes it ,if it is worn it might need a new rubber.
Posted on Aug 19, 2008
  • 371 Answers
SOURCE: husqvarna sewing machine - viking 400
Take to authorized Husqvarna Viking dealer for repair. This is not something that can be done by the owner. Check Husqvarna Viking website for dealer closest too you.
Posted on Sep 24, 2009
  • 16 Answers
SOURCE: Bobbin winder will not spin on sewing machine
If you take the top off you will see a tiny rubber tire that engages the winder to the handwheel. Over time they get really soft are really hard and disintgrate. If you have a local sewing shop take the old one in and get a new one to slip on it takes only a few minutes and cost usually less that $2.00
Posted on Jan 22, 2010
caroldon
  • 17130 Answers
SOURCE: bobbin winder won't spin Cannot load bobbin
Can be dirt or particles that have made it stuck with friction and so a resetting /overhauling with good oiling, degresing will resolve the matter, provided there is wearing off in the drive.
First use a degreasing spray before you can disemble.
Posted on Sep 30, 2010
RichSew
  • 194 Answers
SOURCE: The bobbin on my Husqvarna sewing machine (Viking
If your bobbin still has thread on it, remove it by hand and then try to pull the bobbin off the winder.
Posted on Oct 15, 2010
I was given a 6510 still in the box. I have the bobbin in and threaded but the needle will not move.The bobbin winder is moved to the left.The motor runs but no movement. What can I try?
Did you disengage the bobbin winder? That is a safety feature to prevent the machine sewing at the same time as the bobbin is winding.
Nov 15, 2017 | Sewing Machines
Husqvarna viking 300 sewing machine bobbin winder will not stop spinning. machine will not sew when foot pedal depressed. bobbin winder just keeps spinning.
The bobbin winder moves a plate next to the handwheel that disengages the needle from moving If you can't push it back to the left you will have to take the machine apart to fix it.
Jun 10, 2017 | Husqvarna Sewing Machines
Designer 2. Why isn't bobbin winder working?
For ~$25 you can buy a stand-alone bobbin winder from the local fabric store (JoAnns or Hancocks) or even online (Amazon.com).
Oct 24, 2015 | Husqvarna Sewing Machines
The bobbin winder keeps winding
Please take your machine out of bobbin winding mode.
Sep 02, 2012 | Husqvarna Sewing Machines
I have a huskystar E20, husqvarna viking sewing machine. I the bobbin winder is not engaging...any suggestions
To answer the posting of: " By cakes_bynich on Mar 20, 2011
I have a huskystar E20, husqvarna viking sewing machine. I the bobbin winder is not engaging...any suggestions" Are you using the right bobbin - class 15 and not 15J? I am having a similar problem and I believe it's because I'm using a bobbin 15J and not the 15. 15J's are just slightly less tall when lying flat next to a 15, and the edges of the 15J are slightly curved inward toward the thread whereas the 15's edge are completely straight and flat. If I hold a 15J just right on the winder, I can get it to engage sometimes. That slight size difference must be the cause. I'm off to pick up some new 15's and will test it out!
Mar 20, 2011 | Husqvarna Husky 145
Have Viking Husqvarna #1+ sewing machine that when filling a bobbin caused the bobbin to overfill and break. Now when pressing the foot pedal the needle will not move. I can manually turn and get the...
Make sure that the bobbin winder stop is up. That is the little black post below the bobbin winder. If it is pressed down, the machine will not run.
Feb 02, 2010 | Husqvarna Sewing Machines
Can't put a bobbin on the winder Husqvana Viking 6020
Is this a Designer 1 or a #1? There is no moving lever on the pin of a Deigner 1,they are fixed. If it's a #1, use sewing machine oil or Triflow. NEVER use 3 in 1 oil. It will gum up and cause problems later on.
Aug 31, 2009 | Husqvarna Viking 1
Viking Husqvarna #1 + - A bobbin was stuck on the winder and I pulled it off. The black metal clip broke and came flying off. Now the machine thinks it has a bobbin on the winder and won't move the sewing...
The black plastic ring must be put back on with it oriented correctly. It can be a bit tricky, but experiment different ways.
Another small part may have come off too. If you can't get it, a Viking tech can do it for you without much trouble.
Jul 10, 2009 | Husqvarna Viking 1
Bobbin winder is only thing that works
What model are you talking about? For my older Husqvarna machine you had to pull the bobbin winding bit out to wind the bobbin, then push it back in when you were done.
Dec 02, 2007 | Husqvarna Viking 1
Sewing Machines Logo
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Wayne Fellows
Wayne Fellows
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
