Question about Water Water Heaters
Them hot water tank what size elements do I need to replace? Any help would greatly be appreciated
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 20 Answers
Standard screw in type 240 volt Original is 3500 watt, you could step up to 4500 without an issue.
Posted on Jan 10, 2017
  • 9 Answers
SOURCE: 12-year old Rheem residential single-thermostat
TIME TO REPLACE TODAYS ARE MORE EFFICIENT
Posted on Sep 08, 2009
rick_stokes_
  • 61 Answers
SOURCE: warm water only
You can eliminate the shower control knob possibility by turning on your hot water anywhere else in the house. If you get hot water in other places, then it could be the knob causing it. A substantial lime buildup in the tank can also cause poor heat transfer from the elements to the water.
Posted on Sep 19, 2009
pipesster
  • 20 Answers
SOURCE: Water Too Hot
needs new thermostat(s) If the whole tank is heating( next time it trips, before using any hot water check the lower tank thru the lower element access(breaker off) If the lower tank is hot-you need a new lower thermostat. if just the upper part of the tank is heating -you need an upper thermostat.
Posted on Jan 26, 2010
SOURCE: Thermostat and reset button (GIANT 152ETE) - no hot water
I have the smae problem but my element on top works fine it is the element on the bottem that does not go on so what is it that i have to change the element or the thermostat. on the bottom or the one on top. I have voltage on the top but none on the bottom element and are they suppose to go on the same time.
Posted on Apr 16, 2010
  • 5089 Answers
SOURCE: Reliance 501 Hot Water Heating element for 30 gal tank, where to purchase
You do not need special parts.
Wattage is printed on end of each element.
Buy generic elements at hardware store.
http://waterheatertimer.org/How-to-replace-water-heater-element.html
Posted on May 22, 2012
Tip
Rest Electric Hot Water Tank Thermostat
I understand that you need to reset your hot water tank thermostat. Here are some instructions for you to follow with visual aids on what you are looking for and what you need to rest.
First you must locate the thermostat in order to rest it. There are usually two service panels on a hot water tank. The service panels look similar to the ones in the picture below.
justinbur167.jpg Once you locate the service panel(s) you will need to remove the top on and locate the thermostat the reset should be in the top one. You will be looking for the button that is located in the middle of the thermostat. This button will need to be pushed down firmly. The rest button is often red however; it comes in many different colors, shapes and sizes.
If the thermostat rest automatically pops back up then you will need to replace the thermostat. If you do not hear the heating elements heating up like in your coffee maker her the noise of the elements heating. You may have a bad element or thermostat of even both may be bad. The cost of rebuilding a hot water tank is cheap compared to replacing so I would suggest rebuilding. This is a pretty easy task that you can also receive help from FixYa for.
Hot Water Image: visualdictionaryonline.com: Copyright QA International 2011
http://www.bing.com/images/search?q=electric+hotwater+tank+&view=detail&id=947D2952ACE0C75D1DCEDB6216D99F764F1F2DB1&first=31&FORM=IDFRIR&qpvt=electric+hotwater+tank+
on Apr 09, 2011 | Water Heaters
Got 5 minutes of hot water then cold. replaced both elements and thermos. still 5 minutes of hot water. power bill increased nearly 400% in 30 days. HELP!!! please.
When the top of the tank is hot the upper thermostat removes power from the upper heating element and transfers the power to the lower thermostat and heating element. If the lower thermostat is defective, then the lower portion of the tank will not be heated and the supply will be greatly reduced. You replaced both elements however check that the lower element is coming on after ther upper one cuts out and is acutally working.
Check for power at the upper thermostat terminals where the power is sent to the lower thermostat and heating element. If there is no power then the upper thermostat should be replaced. If there is power then check for power at the lower heating element. If there is no power at the lower heating element then replace the lower thermostat.
If there is power to the lower heating element then it should be getting hot. If it is not, maybe defective. Another possibility is a broken dip tube. Check for a broken dip tube and replace if necessary.
If the dip tube is broken, the incoming cold liquid can mix with the out going hot liquid and cause it to seem as though you are running out.
Nov 04, 2011 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
No hot water, replaced both elements, replaced breaker switch, pressed reset button, fire from breaker to heater, frie to top and bottom unit. still no hot water, is unit itself bad?
I had this same EXACT problem. I replaced both elements, and STILL no hot water. Power to everything, but no hot water. So, I got online, and got educated.
THEN what I did was to replace the Thermostats, both the top (master) and the bottom. Cost was reasonable, I think all told it was 24.00 for both elements, and about 40.00 for both thermos. Got the thermos at the same plumbing supply store where I got the elements.
This fixed my problem, I now have great hot water.
The way the water heater works is that the top thermo is the master, and when the water needs to be heated, it turns on the bottom one first. This is because that when you turn on a tap, the hot water is taken from the TOP of the tank, and the new water coming into the tank comes in to the BOTTOM. This means that during normal operation, the water in the top of the tank will pretty much stay hot, and only the water in the bottom will need to be heated. Your bad Thermostats are not reading the temperature any more, so it isn't sending power, (or rather grounding) the circuit to the elements. Since the entire tank is cold, it is probably the top one that is bad, since it turns on the the lower element (or, I should say, the lower thermostat) FIRST. The elements always have power, the switch in the thermos just works by grounding, and thereby completing, the circuit.
Either one of your thermos could be bad, or both. I thought for myself that if one went bad, then it won't be long till the other goes bad too, so I just replaced them both. On mine, they just snapped out, and snapped back in, they just kind of sit against the tank, and there is only 4 or 5 wires to hook back up.
I am assuming that you are competent to do it, since you already know how to replace the elements, and obviously have a voltage tester to see if you have power everywhere you supposed to have it. One thing, too, make sure that both of the Temperature Stettings on the thermostats are exactly the same. You do not want one to read 125, and the other to read 150, or whatever. Set them both to the same temp.
This should fix ya, and it is a heck of a lot cheaper than a whole new water heater. The only reason to completely replace an electric hot water heater is if the tank has rusted through and is leaking, or if it has filled up with sediment. Or physically damaged in some irrepairable way. Other than that, this cheap repair should do it.
Good Luck To You.
Jun 22, 2011 | Rheem Water Heaters
Water heater supplies about a pint of hot water than turns cold?? what is th eproblem
Hello Rsjohnson164,
I understand that you are having a problem with your hot-water tank not producing any amount of hot-water. I would suggest that you turn off the cold water supply to your hot water tank and drain the tank and see how much water comes out of it.
Flush the tank:
1. Turn off the cold water supply
2. Hook a water hose to the boiler valve (spicket on the bottom of the tank) and turn on the valve
3. Turn on the cold water inlet line and let it run for about 15 minutes or until you get good pressure coming out.
Check the Elements:
1. Turn off the power to the hot-water tank
2. Remove the service panels
3. Remove one wire from the element and use a multi-meter to check continuity
4. If no continuity replace one or both elements
If you do all of this and still have a problem repost to this thread and we will check your thermostats to make sure they are working properly.
Thank you for choosing FIxYa.com
Justin
Apr 21, 2011 | RELIANCE ELECTRIC WATER HEATER
Hi...I have a Whirlpool water heater and the water only stays hot for a few minutes. How do I adjust the temperature or settings so that I can have hot water all the way through the shower instead of...
I am guessing this is an ele water heater and the temp setting are not the problem.
Problem: Not enough hot water or water temperature too low. When the top of the tank is hot the upper thermostat removes power from the upper heating element and transfers the power to the lower thermostat and heating element. If the lower thermostat is defective, then the lower portion of the tank will not be heated and the supply will be greatly reduced.
If there is power to the lower heating element then it should be getting hot. If it is not, replace it. Another possibility is a broken dip tube. Check for a broken dip tube and replace if necessary.
The dip tub is located under the fitting where the hot water comes out.
Feb 03, 2011 | Whirlpool Water Heaters
I'm getting hot water for 2 minutes , then it gets cold
Most electric hot water heaters have two thermostats, one near the top of the tank and one near the bottom, and are covered by removable metal cover plates. The thermostats are pressed firmly against the bare metal wall of the hot water heaters tank.
The top thermostat usually has a high limit switch that will trip if the water gets too hot. When it trips it shuts off the electricity to both the upper and lower heating elements.
To reset the high limit switch there is usually a red button that you must press. When the upper limit switch trips it is often an indication that something else has gone wrong with the heater.
Hope this helps out
Feb 02, 2011 | General Electric GE SmartWater Household...
I have replaced the bottom element,and now i have no hot water. I check with a meter and have power to the top element but not the bottom one.
First of all, you have 240V water heater because tank has two elements.
You have no hot water, and tank has power to upper element.
Lower element has no power.
Something doesn't sound right.
You're not testing correctly.
Before doing anything, test across top two screws of upper element for 240Volts.
This will eliminate electrical problem as suspect.
Breaker must deliver 120V on both legs to complete the 240V circuit.
Every single-phase household circuit takes 2 wires to complete the circuit.
With 120V you need 1 neutral wire and 1 hot wire to complete circuit.
With 240V you need 2 hot wires, one from each hot busbar, to complete circuit.
Your water heater can appear to have electricity if breaker is delivering power on one leg of the 240V circuit.
To check breaker for sure, move wires to another similar size breaker to see if water heater functions properly.
http://waterheatertimer.org/B220C.html
If 240V circuit is good, then next thing is take 30 minutes and do full test of water heater parts.
This will identify exact problem(s) without guessing.
Buy 5$ multimeter from Home Depot. Install battery.
When test calls for continuity, rotate dial to Ohms (upside down horseshoe is ohms).
When test calls for testing voltage, rotate dial to 240-250-277 VAC
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html
Add a comment for more help.
Dec 28, 2010 | Rheem Water Heaters
After connecting a drain line to the pressure relief valve of my MR85245 water heater, I now have water leaking badly out of the heating element door.
Turn off the electricity.
Turn off the water valve going into tank.
Open a bathtub spout to let hot water pressure off the tank.
Check top of tank for any leaks.
Open the top access panel and see if element is leaking.
Open bottom access panel and see if lower element is leaking.
The reduced pressure on the tank will slow the leak.
If element is the problem, you can squeak by for a while by turning on the hot water heater only when you need hot water.
Order the 'Marathon MR85245 replacement element' online
http://www.gpconservation.com/rheem/marathon-sp213670-titanium-4500w-lower-element
These elements may be available locally, but they are not the same as 'ordinary' tank-type electric heater elements that you buy at the hardware store.
Buy more than 1 element because the Marathon elements have problems.
One of the reported problems with marathon elements is the high price of stainless steel replacement elements.
Drain tank.
Replace element.
Another resource for water heater information is:
http://www.thetankatwaterheaterrescue.com/forums/forum3/
Nov 04, 2010 | Water Heater Innovations MR85245 High...
Water Too Hot
Jan 18, 2010 | RELIANCE ELECTRIC WATER HEATER
Water Heaters Logo
77 people viewed this question
Top Water Heaters Experts
freddyfox
Kenneth Walker
Are you a Water Heater Expert? Answer questions, earn points and help others
