Question about Sewing Machines
What do i do when it wont make a stitch. I have treaded rite im sure
2 Suggested Answers
  • 109 Answers
SOURCE: Granddaughter has just received Activa from her
It can be a number of things so we'll check them all! First make sure when you re-thread it that your presser foot is up and that the thread goes between the tension discs in the front. (Pretend you are flossing and pull the thread back and forth and then pull it out to hear the click just to be sure you have it snuggly in the tension.) Next make sure your bobbin thread is in its tension slot. (You can do the same test as the top...pull it in the slot and pull it back out to make sure you hear the click.) Put a new needle in and make sure the flat side is to the back of the machine. If you do all of this and it still doesn't pick up the bobbin thread, most likely the machine timing is off and this is a repair to be done by an authorized dealer. It can be a result of: if you hit a pin or two, run over a very thick seam or pulled your fabric too tight because it wasn't moving under your presser foot. Do you remember your needle hitting the needle plate? When this happens because of any of the above examples, it causes the hook in the bobbin case to not line up with the needle when it comes down to pick up the thread so you don't get a stitch. I would call a repair center if none of the above suggestions worked and check and see how much it would cost. It could be anywhere from $50 to $150 depending on where you live or who you go to. I'll try to answer any other questions you have. I'm here until you're satisfied! Please let me know if I can be of any more help to you and let me know how you made out. Thank you for asking for me.
Posted on Sep 19, 2010
Cant fiqure out if we threaded right stiches wont stay in
try adjusting tension control until both threads are equal. zigzag is easiest to see if you have it correct
Aug 23, 2015 | Sewing Machines
Machine is threaded but is not stitching
Check the needle. Make sure it is not bent.
If it is not bent.
Take off the bobbin case "under thread".
Turn the hand wheel, so it stitches. NB. THE ROTATION MUST BE COUNTER CLOCK WISE.
Get the needle to where its the lowest point.
There is a hook behind the needle, that pick up the tread. the tip should be right behind the needle.
If it is not there, you need to call a technician
Jul 16, 2015 | Sewing Machines
Serger won't stitch
Sergers are very interesting and complex machines, and you don't have to have something out of whack very much to upset the operation. Check your treading again - make sure it all the treads match the diagrams. Check your needle(s) for burrs at the tip. If in doubt, replace them. Check the needle plate and foot for burrs. Anytime a needle comes in contact with anything but fabric, there's a fair chance something will get a burr. When that happens, the thread doesn't feed properly.
Jan 16, 2018 | Sewing Machines
Tread bunching up
Well, that is rather vague:
Operator error. 1. ALWAYS, ALWAYS grasp both threads when beginning your stitch line. 2. ALWAYS ALWAYS, make sure your needle is at that full up position before beginning a seam.
Mar 19, 2013 | Brother CS-80
Hyundai 8 stitch sewing machine confused beginner!?????
Not familiar with your machine, but an important suggestion for all sewing machines:
ALWAYS RAISE the presser foot when threading the top thread. If you did not do this, remove the top thread completely from the machine and start over by RAISING the presser foot and following the thread path. (Do NOT miss any thread guides or thread any out of order!)
Lower the presser foot and thread the needle. (The top thread will pull through the needle ONLY if the presser foot is raised!) RAISE the presser foot and pull at least 5 inches of thread through the needle. Insert your fabric. Lower the presser foot. Hold the thread tail gently in your left hand and with the right hand manually turn the handwheel one rotation. The needle should pull the bobbin thread up through the fabric.
While still holding the top thread tail, "sweep" under the presser foot with a stiletto, scissors, a nail file (anything that will fit under the presser foot) to pull the remaining bobbin thread tail above the fabric. Grab both thread tails and pull them under the presser foot toward the back of the machine. Now, you are ready to take your first stitch.
You can gently hold those thread tails while you slowly power the machine to take the first couple of stitches on your fabric.
Jun 27, 2017 | Sewing Machines
I change the presser, for a walking foot, and the nedlee started to stucked, and then I change for the presser again and now doesn't sew at all, now only sew a few stitches and then the tread loses both...
This sounds like you have one of two things going on:
1. the tension, probably upper, is too tight or the thread is looping or catching along the way somewhere...ie threading isn't right
and
2. the needle is bent.
Try rethreading and check the tensions and then also make sure and try a different new needle. Make sure the stitch type is set right for the presser foot too! :)
May 04, 2011 | Brother Sewing Machines
How to thread huckylock 901 serger
The picture diagram works the best for this, it tells you how to tread for every different stitch that you want to perform. You have to thread it in different ways for every stitch so it is difficult to tell you in writing. If you visit your local Viking dealer they would be able to make you a copy and I'm sure show you how right there.
Jul 26, 2010 | Husqvarna Huskylock Computerized 910
Machine is threadedand makes the serger chain for
My janome 634D driving me crazy . I have tread it properly and it wont stitch ?
Nov 06, 2009 | Janome MyLock 634D Mechanical Sewing...
Treading sewing machine
these are the best setting i have found for sewing through thick materials, specifically leather and vinyl:
top tension- between 8 and 9 bottom tension- between 4 and 5 stitch length between 3 and 4 stitch type: 2
that is just what works best for me, i have a brother xl-2600i
Jun 23, 2009 | Brother XL-2600
Sewing Machines Logo
15 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Sewing Machine Expert? Answer questions, earn points and help others
