My washer is leaking fro where I put laundry soap in
  • 262 Answers
SOURCE: Fisher and Paykel Washer leaking water
call fisher paykel they will take care of you chances are the diverter valve is bad they have been having problems with them and make sure your repair people are fisher paykel certified VERY IMPORTANT
Posted on Dec 18, 2007
Richie_asg1
  • 1036 Answers
SOURCE: In my Duet Whirlpool washer,
This should be a very simple fix for you.
You can remove the dispensing drawer completely - usually by pushing down on a springy tab. Look along the level of the top for the catch.
When removed, give it a good wash in the sink, as there will be a build up of goo in the little syphon arrangement that dips into the softener area.
If it allows you to unclip it, then do, and rinse it out with running water.
Then dry with kitchen towel. You may need to do this twice.
While the drawer is out, give the hole it goes into a spray with kitchen cleaner, and wipe it clean - don't loose your cloth!
Often this is an area that goes mouldy, leading to a musty smell on the clothes.
Click all together and it should work fine again.
Thanks for using fixya,
If this cures the problem, please rate for others to follow.
Posted on Jul 13, 2008
  • 409 Answers
hi there,
the leak underneath could be from the pump or the drain hose. some washers have a tub to pump boot that sometimes springs a leak.
for a 4-month-old washer, i would certainly hope you pay nothing. F&P appliances come with at least a 2 year warranty. check your user & care guide for warranty information.
Posted on Oct 03, 2008
SOURCE: p801front load washer
P801front load washer, i have E3 error, doesn't want to start spining cycle.
Posted on Nov 23, 2008
buffalonyman
  • 1865 Answers
SOURCE: Cant figure out where to put the laundry detergent in the maytag
This link will take you to the manual for your washer. Page 6 discusses where to add soaps and softners
http://shared.whirlpoolcorp.com/assets/pdfs/literature/6_2727060.PDF
Posted on Jun 02, 2009
How does soap dispenser work? what does up for liquid and down for powder mean?
Liquid laundry soap (comes in plastic liquid container) uses the up. Dry powder laundry soap uses the soap that comes in a box, therefore not liquid. and uses the down switch slider control.
Apr 14, 2015 | Maytag NFW7200TW Front Load Washer
How can I get a laundry cap out of the drain where you put the laundry soap, bleach and softener?
Can you see the cap?
Is the soap tube a separate piece that you can remove?
What's the year, make and model?
A local repairman would be able to solve the problem, as a last resort.
Nov 30, 2014 | Kenmore Washing Machines
My 3 month old washer suddenly started leaking from underneath. There was a code displayed of a 5d, but the washer drains into a laundry sink, there are no kinks in the input line.
The washer is detecting too much soap. Make sure that you are using HE (high efficiency) soap Do a clean washer or hot cycle once a month with bleach or white vinegar with no clothes in it. Your washer only uses half the water that a regular machine does. The HE is specially designed for front loaders and these types of machines
Jul 11, 2011 | Maytag Bravos MTW6600T Top Load Washer
Can you use granular soap and where to apply it? we have a frigidaire washer with a drawer to put liquid soap in.
On our washer there is a little slider in that drawer that allows the opening into the washer to open wider for solid laundry soap. Maybe that's the case in yours. If not then you might be confined to using HE liquid soap.
Mar 05, 2011 | Frigidaire ATF6000ES Front Load Washer
I make homemade liquid laundry saop and when I use
you NEED to buy real washing soap from a store. I recommend Tide because you may be mixing wrong ingredients or not adding something. If buying new/real soap doesnt work i would go to a sears or email sears at their website and tell them.
Feb 17, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
hi there,
Oct 03, 2008 | Washing Machines
Lg wm1812cw front load washer
We had the same problem- for us it was because we were mixing laundry booster (Oxyclean) with liquid soap in the dispenser. It seems the water running through the tray had insufficient pressure to properly flush the tray out, so residue accumulated on the back & underside of the tray. Our water pressure is good here, and we don't use a water softener or filters that can reduce the pressure. Unfortunately it seems to just be a bad design of the soap dispenser tray.
We also had a problem with water/bleach leaking from our soap dispenser- when we used the bleach compartment in the dispenser we got leaks dripping onto the floor from behind the front cover of the washing machine. It was running down the front of the washer behind the front cover & coming out onto the floor. The repair guy said this was because the dispenser tray was pulled out too far, but the reason we were pulling the soap tray out so far was because the bleach compartment was too far back in the tray to use if we didn't. Now we just leave the drawer partially closed & pour the bleach directly into the soap compartment along with the soap.
Jan 16, 2008 | LG WM1814CW Front Load Washer
Dec 18, 2007 | Fisher Paykel EcoSmart GWL15
Washing Machines Logo
Top Washing Machines Experts
