Question about Miele Vacuums
Miele salsa upright S7280 makes loud grinding noise when carpet motor engages. If carpet motor is not engaged there is no grinding noise.
  • 43 Answers
SOURCE: LOUD GRINDING NOISE ALL OF A SUDDEN , LOOSE BELT ?
you will probably have a faulty roller bar take of panel on bottom of vaccum. Now remove the roller bar hold the bar by both ends and try spinning. This should be easy and smooth if not pull off the end cap these will be very tight and check the bearings in each end i think you will find a few small metal balls rolling around inside if this is the case you need to replace the bar
Posted on Nov 11, 2008
SOURCE: beater bar not engaging,
The belt is in tact, but the beater bar will not rotate
Posted on Feb 18, 2009
  • 44 Answers
SOURCE: when I tilt back handel and turn dial to carpet It
On a Dyson this engages the brush bar. Two possible faults: Debris (hair etc) caught in brush bar - cut out with knife. Or - damaged drive belt - pieces of belt striking casing. Last, but unlikely cause, debris in bearings of brush bar - replace brush bar.
Posted on Jul 29, 2009
garing
  • 998 Answers
SOURCE: Hoover makes terrible screaching sound when using upright.
install new belt(if still makes noise change bearings)
Posted on Aug 26, 2009
Vac Belts
  • 701 Answers
SOURCE: Dyson Makes a loud noise like something is impeding the
I would try changing the belt. Even though the belt may look fine it can be stretched or worn and that can cause loud noises. You can get dyson belts here:
http://www.vacbelts.com/dyson.htm
Posted on Oct 28, 2009
Why does it have little to no suction power on carpet?
either your hose is stopped up or your motor is going bad and doesn't have enough power, first clean out your vacuum and check belts and make sure they aren't worn out and broken or stretched
Dec 13, 2015 | Miele S7280 Bagged Upright Vacuum
Making a loud sound
could be that the clutch is bad or the brush roll needs to be removed, cleaned, ends removed and lubed. Try to spin the brush roll and see if it moves freely...if not, it needs to be cleaned and lubed at both ends. I fixed mine today by doing this...not an easy task to remove the brush roll, but it can be done:)
Mar 17, 2013 | Miele S7210 S7 Series Twist Upright Vacuum...
I am looking for a parts diagram for a Miele Upright S7280 (Salsa) vacuum
See if there is a manufactures web site and inquire if diagram is available or just Google for info with proper make and model.
Fist just search for vacuum diagrams then refine search for your vacuum but this not always easy can be confusing so might have to take it to vacuum repair business or if you have not dissembled it yet just make notes when you do. Its not as hard as it seems I have done it many times.
Oct 24, 2012 | Miele S7280 Bagged Upright Vacuum
What kind of upright or steam Vac should I buy which can make my carpet clean and SOFT?
I recommend looking at the miele S7280 for an upright vacuum cleaner and the royal RY7910 carpet extractor.
Jan 20, 2010 | Hoover SteamVac F5914-900 SpinScrub...
When I tilt back handel and turn dial to carpet It makes a loud grinding noise
Jul 29, 2009 | Dyson DC14 Animal Bagless Upright Cyclonic...
Beater bar not engaging,
Jan 25, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
Miele Mistral S7280 won't run after changing the bag
The Mistral range is the same as the new S7 that's just hit Europe. Have you made sure that when you turn on the vac on the handle that you've switched the carpet mode on? There's a separate button just under the power on button that activates the Carpet setting. Other than that check the sole plate where the roller brush to check for a blockage.
Jan 20, 2009 | Miele ART S920 Bagged Upright Vacuum
Vacuums Logo
90 people viewed this question
Top Miele Vacuums Experts
Mack Baxter
Colin Stickland
Colin Stickland
Are you a Miele Vacuum Expert? Answer questions, earn points and help others
