Question about Garmin GPS
How do you unlock Garmin marine plotter touchscreen
2 Suggested Answers
hydetech
  • 113 Answers
SOURCE: Garmine Marine Network Wiring
There is nothing unique to Garmins wiring so an ethernet cable should work. I think it's a crossover but I did it a year ago so I could be mistaken. It's possible that the cable isn't fully connecting because they have added that big knurled screw on part to make it water proof. I had a problem with a Raymarine recently and it turned out to be a defective cable. If you purchase Garmin's connector it comes with instructions on how to assemble. You need a special crimping tool. I bought mine from Radio Shack for @ $40. You could probably save money by buying 2 connectors and cutting the ends off your ethernet cables.
Posted on Feb 15, 2008
I need mother board for GPS Garmin 4008
Direct from Garmin only, especially for a marine plotter. Product is discontinued.
https://my.garmin.com/rma/en-US/repair/repairLanding
Jan 22, 2016 | Garmin Gpsmap 4008
I have problems with my plotter Raymarine Rc 435 chart plotter.This plotter can not location my ship to do.What is problems?
Be sure there isn't any aluminum in close proximity to your GPS antenna, or that your antenna is not to close to other powerful electronics. Aluminium reflects electromagnetic signals and other electronics emit EM fields as well causing disruption of your GPS signal reaching your antenna.
Sep 26, 2014 | Raymarine Rc435 Chartplotter
Hi, my Garmin 3010c is 40m off true position. I hav another plotter (not Garmin) an it't on the spot. It7s not the problem with poor signal. It has signal form 6 or more satelites but it is allways...
There are too many variables that will affect the GPS to determine if the Garmin is off or the other plotter.
The only way to verify the GPS is through controlled simulation or using waypoint averaging and survey benchmarks to confirm the location.
Aug 19, 2011 | Garmin GPSMAP 3010C GPS Receiver
Unlock code
Try this:
Turn off Garmin device. Press down on bottom right corner of the touchscreen, and then power on the GPS unit. You should be prompted whether you really want to erase all user data, or asked if do you really want to start up in maintenance mode. Press “Yes” to reset (warning: all data will be erased and lost, so backup before proceeding) or enter maintenance mode.
Dec 21, 2009 | Garmin nuvi 200W GPS Receiver
My plotter seems not to output NMEA to my DSC radio and auto helm
Your plotter can talk to you Radio and your pilot. It sounds like one of two things.You must go into the system setup menu and turn on the nmea sentances. You will need to turn on RMB, RMC, GGl at least. You can turn on all the sentances if you like it does not matter. If this does not fix, check color of wiring is correct. Remember you have to go from NMEA + out (on plotter) to NMEA + IN on Radio.Then you need NMEA - out(on Plotter) to NMEA - IN on Radio.
You can look at the sentances wirth a multi meter coming out of your plotter. You put meter in DCV and connect across the NMEA out lines. You will see the meter move every second or so as it send a sentance.
Jun 09, 2009 | Raymarine Raychart 435 GPS Receiver
Compatable marine maps Australia for garmin etrex legend
You can purchase the Bluechart Marine maps for your area online at Garmin.com. They will sell you an unlock code for a specific area.
Dec 27, 2008 | Garmin eTrex Legend GPS Receiver
A65 Raymarine combo gps plotter fishfinder
your local marina should be able to tell you and they most likely are a dealer for seadog or diversified which will sell your parts just give them your model or just take the unit in with you
Oct 16, 2008 | Garmin 340c Fish Finder Dual Frequency...
Sounder transducer?
I believe like my own Garmin I have a 178 which is the mono version, same transducer though, you alter the frequencey setting in your main reciever set up program.
Sep 11, 2008 | Garmin 200/50khz, 10/40deg, Plastic,...
Garmin nuvii 350-anyway to install marine charts on this unit?
No. This unit is not designed for marine use, and therefore is not designed to accept marine charts.
May 05, 2008 | Garmin nuvi 350 GPS Receiver
Feb 14, 2008 | GPS
GPS Logo
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
