Question about Lands Phones
Trying to set up 1 # dial - Lands Phones
Feature Button Not Working
Feature, Redial, press button to program, dial 1, dial the extension number, Feature to write and exit. ONLY IF the buttons are programmed as feature buttons, they may be just dead buttons, useless until they are assigned in system programming as feature buttons.
Nov 22, 2013 | NEC Lands Phones
We lost our manual and I am trying to reload our speed dial numbers. I have tried everything but can't seem to figure it out. Help?
1 Press Menu/Set, 2, 3, 1.
2 Press the One Touch key where you want to store a number.
The LCD shows the location you selected.
3 Enter a number (up to 20 digits), and then press Menu/Set. If you want to enter
a pause in the dialing sequence (for example, to wait for an "outside line"), press
Redial/Pause as you're entering digits. A dash appears on the LCD. Pressing
Redial/Pause enters a 3.5 second pause when the number is dialed.
4 Use the dial pad to then enter the name (up to 15 characters), and then press
Menu/Set. You can use the chart on page 4-2 to help you enter letters-OR-To store the number without a name,
press Menu/Set.
5 Return to Step 2 to store another One Touch number-OR-Press Stop/Exit.
When you dial an auto dial number, the LCD shows the name you've stored, or,
if you haven't stored a name, the number you've stored.
Dec 07, 2010 | Brother IntelliFax-2820 Laser Fax
Trying to connect to internet but screen says internal modem has no driver - it sees no modem
If you're compuer is connected to a router or DSL/Cable modem through Ethernet connection, you don't need to have to use internal modem. Internal modem are just for dial up connection.
If everytime you launch IE browser and it gives you that prompt, your browser may have set up to connect everytime to a dial up connection. Try to check these settings on your IE:
1. Go to Start> Settings> Control Panel> Internet Options
2. On Internet Options, go to Connections tab.
3. Delete everything under Dial Up and Virtual Private Network Settings, Or just set it to 'Never Dial A Connection'.
4. Click on LAN Settings button.
5. On the next window, uncheck everything (particularly the proxy setting).
6. Click OK all the way out.
Oct 23, 2009 | HP Pavilion a1610n PC Desktop
Panasonic KX-T7730 Speed Dials - Please Help!
So I guess that means you're not programming SYSTEM speed dial numbers. Those are programmed from the system manager or operator's station. Personal speed dials are 1-0 and are programmed per set.
Sep 02, 2009 | Panasonic KX-T7730 Corded Phone
If you have a nec electra elite system go to the operators phone and hit feature key then dial 9 #
Feb 03, 2009 | NEC ETW 16DC-1 Corded Phone
Need help changing the speed dial ID numbers
In order to change #01 to #21 its best just to program the number into #21 slot and then clear the memory for #1.
Start by trying to store a number at a location already used Press Menu/Set, 2 (Fax), 3 (Set Quick-Dial), 2 (Speed-Dial).
Use the dial pad to select the three-digit location (001 – 200) in which you want to erase the number and press Menu/Set.
The screen displays the name or number currently stored there, then prompts you to either 1. CHANGE or 2. EXIT.
Press the Stop/Exit key when the cursor is to the left of the digits. Everything above and to the right of the cursor is deleted.
Hit he menu/set key.
This should save the speed dial number as a blank.
Apr 29, 2008 | Brother IntelliFax-2820 Laser Fax
Speed dial
just press and hold any of the keys from 1 - 9 and just assigned them
Apr 08, 2008 | Motorola Mobility RAZR V3
1 touch dialing
Okay hopefully by now you guys have figure it out but for other who haven't yet... in your list of contacts select and edit the contact you want in position #2 scroll down till you see speedial or the lighnting symbol.. thats where it is set up.
Nov 30, 2007 | Motorola Mobility RAZR V3m Cellular Phone
Dial not turning
in process of dial removal, the dial was somehow jarred to cause some disassembly of the dial...look at the dial body clasps carefully
May 22, 2007 | Whirlpool AWM5104/1 Front Load Washer
Lands Phones Logo
32 people viewed this question
Top Lands Phones Experts
Are you a Lands Phone Expert? Answer questions, earn points and help others
