Question about Baby Gear
Test test 2107 5 - Baby Gear
  • 13,433 Answers
This test is a day old.. i see new tests coming up this must have been forgotten.
2207 16:17 +0300
Posted on Jul 22, 2009
Hi Is there any way to change the external tape drive to flash for backup software.
You always can change from tape to any other system, but a tape can be read in any drive after more than 30 years. using a hard disk, will end its usage when there is only the slightest defect.
Mar 09, 2015 | Sun Microsystems 599-2107-01 Sun Dds3...
Netflix error code m7083-2107 windows vista movies wont load and play
Netflix Playback Error M7083-2107
If you get the error code M7083-2107 while watching on your computer, it's typically due to an extension on your Chrome browser that is preventing Netflix from working properly. Follow the troubleshooting steps below to resolve the issue.
  1. Open Chrome if it's not yet open.
  2. In the URL bar, type chrome://extensions/ and press the Return or Enter key on your keyboard.
  3. Uncheck all Extensions.
  4. Try Netflix again.
This is from the Netflix help page
Dec 22, 2014 | Netflix
I have this Kenwood TK-2107 .... when the ptt button is depressed the transmit led lights up but it does not transmit. Why is that, any good tips?
The output transistor could be bad. the Xmit relay could have burned contacts or is not operating at all.
Oct 28, 2014 | Kenwood Tk 2107
I'm tryin' to programming kenwood tk 2107 by kpg55d, when i press read data from radio gives me check connection error? please give me help
To help you find a solution, you will require the user manual for your radio, if you don't have a copy then try this: join yahoo group SPECIFIC to your radio Make/Model, there is a wealth of info there and you may be able to download manuals, schematics and other stuff for your radio, if available and all this is free.
I hope this helps you to find the solution.
Regards,
Peter
Mar 12, 2013 | Radio Communications
I HAVE LINCOLM LS AND HAVE THIS CODES P2104 2107 2110 2112 SO ITS THE THROTTLE BODY PROBLEM?
Those codes are commonly caused by a faulty ignition coil "spiking" the throttle control circuits. You need to check for cylinder misfires - fix the misfire and you will most likely fix the throttle body codes.
Other than this, all I can say is that these circuits need to be diagnosed using the troubleshooting charts provided by the manufacturer and the proper equipment to perform the required tests.
Nov 10, 2011 | 2004 Lincoln LS
2005 lincoln LS v6 I am getting codes 2107 and 2110. Replaced throttle body and the wrench is still coming up putting the car in safe mode. codes are still the same. Car has only 40, miles
One bad COP Ignition Coil
There was no need to replace a $700 throttle body
One $37.00 coil from Rock Auto online & 20 min of
your time & your done
Not may people can diagnose an L/S for some reason.
That said ,I have no idea how they then could diagnose
any ford product,sad but true.
The coil is spiking the PCM & the signal comes back
on the TPS Sensor & you loose throttle plate % & go into
ETC Failsafe
The TACM Codes (2107 & 2110) and there are others,
are not valid or the problem.
The technology is beyond the pros & dealers as well
Aug 25, 2011 | 2005 Lincoln LS
Trouble codes 2107 and 2110
They are TACM (throttle actuator control motor ) codes
Before you install a $700 throttle body,just for the motor,
you need to check all ignition coils for misfires
A really bad coil will not ground out in the computers
drivers
It will come back on the TPS Sensor,also on the throttle
body, and you loose the TPS Signals & set your 2107
& 2110 codes
V6 or V8
Get the codes if you have more & let me know them
Mar 29, 2011 | 2004 Lincoln LS
The problem code 2107 and 2110
If your vehicle faults in accelerating, you might have a problem with your throttle body. The 2107 code indicates a problem with your throttle actuator control module. The 2110 code indicates a problem with your throttle control system.
Feb 28, 2011 | 2005 Lincoln LS
Iam having trouble with 2 codes 2107 2110
I have a 2003 V6 lincolin LS with codes 2107/2110, I've changed everything but the plugs and the cam postion sensors. make sure you use Iridum spark plugs, with the gap at .051. Once I did this and replaced the cam sensors the car runs great no wench light. At 150 miles and 3 days,so far with no problems.It took me about 6 months to get it right. And I don't want anyone to go through what I did. I hope This helps.
Jul 18, 2010 | 2004 Lincoln LS
Etc fail safe mode codes p2104 2107 2110 2111 2112
P2104 Throttle Actuator Control System - Forced Idle
P2107 Throttle Actuator Control Module Processor
P2110 Throttle Actuator Control System - Forced Limited RPM
P2111 Throttle Actuator Control System - Stuck Open
P2112 Throttle Actuator Control System - Stuck Closed
Seems like Throttle Actuator is the problem.
Good luck on this repair.
Jul 13, 2010 | 2005 Lincoln LS
Baby Gear Logo
46 people viewed this question
Top Baby Gear Experts
Dorel UK
Dorel UK
Jennifer Rock
Jennifer Rock
Are you a Baby Gear Expert? Answer questions, earn points and help others
