Have a Harmon plotter. Can not unlock screen. Tried everything in manual
Harmon nuvi 1300 won't go into preboot. I've tried everything I can imagine (power on touching each corner) none working even center. Tried holding the power button, loads up to garmin then powers off
Pre-boot mode is accessed by powering off the device and touching the left upper corner of the screen, while plugging in the USB cable into the unit with the other end already inserted into the USB port of a PC. Please note that pre-boot mode has a time limit and does not stay on indefinitely.
Jan 22, 2016 | Garmin GPS
Why is the front panel screen HP DesignJet 4020ps plotter show a blank screen with a blinking green light?
According to the manual, a blinking green power light indicates that the unit is transition between off and on.
Dec 30, 2014 | HP DesignJet 4020PS InkJet Plotter Printer
How come my RW-240 Plotbase (Software for the plotter) will not show any files that have been sent to print?
This plotbase is old enough. Try to reinstall everything. Maybe there is a problem with your PC OS. Try to install plotbase on other PC.
Oct 14, 2014 | Ricoh - RW-240 Print Controller - 411737
My plotter seems not to output NMEA to my DSC radio and auto helm
Your plotter can talk to you Radio and your pilot. It sounds like one of two things.You must go into the system setup menu and turn on the nmea sentances. You will need to turn on RMB, RMC, GGl at least. You can turn on all the sentances if you like it does not matter. If this does not fix, check color of wiring is correct. Remember you have to go from NMEA + out (on plotter) to NMEA + IN on Radio.Then you need NMEA - out(on Plotter) to NMEA - IN on Radio.
You can look at the sentances wirth a multi meter coming out of your plotter. You put meter in DCV and connect across the NMEA out lines. You will see the meter move every second or so as it send a sentance.
Jun 09, 2009 | Raymarine Raychart 435 GPS Receiver
Harmon kardon 745 displays "unlock" no sound for tv or movies
I also had this UNLOCK message on my Harman Cardon AVR 130.
The reason for this error was - in a hurry I've plugged the optical input into optical OUT! Double check that your connections in the back are correct and hopefully it fixes your problem.
Jan 11, 2009 | Harman Kardon AVR 130 Receiver
Request for designjet plotter info
my hp 450c plotter works properly in vista. First I' ve tried unsuccesfully to add new printer through windows menu. Then through Autocad menu (plotter manager) I added the specific plotter.
Jul 09, 2008 | HP DesignJet 450c InkJet Printer
Try 2 different signal sources, such as cable and DVD or Dish and DVD or Cable and vcr. If the same problem exists on both sources then the TV needs a circuit board.
I would like a discription of "posterized" to help you more.
Mar 24, 2008 | Panasonic TH-50PHD8UK 50 in. Plasma...
Harmon/ Kardon ST-8
Harmon and check product support or check the website where you got them from, If they still cary them you may be able to find a manual as a pdf or something. Good luck. Bonne chance!
Feb 26, 2008 | Harman Kardon Harmon Kardon SoundStick II...
26 people viewed this question
