Question about Home
The kids played with the program wheel on my 5600 economider water softner , now it seems like it regenerates to often
  • 659 Answers
SOURCE: water softener seems to be draining all the time
http://www.puritecwatersofteners.com/documentation/Hydrotech_5600MI_manual.pdf
I'm pretty sure this is the manual for your unit. It might not be exactly like the one you have but at least could give you info for it. This is something you might have to contact the manufacture for. Hope this helps!!
Posted on Mar 31, 2009
ftw1952
  • 10319 Answers
SOURCE: will not stop regenerating water keeps running
Check the units drain filter. If clogged up it will make this unit run constantly
Posted on Jan 24, 2010
  • 569 Answers
SOURCE: Water Softener won't regenerate
mmmm.
I see they charge for a user manual!
I am not familiar with this controller. Is there a manual overide - a large screwdriver slot on the frint of the main shaft?
If so, you should try turning that (clockwise) to the next position and see if the moter will drive it from there. If not, then take it right through 360 degrees, one step at a time.
If it does not work on the next cycle then you may have to replace the controller.
Posted on Feb 20, 2010
Testimonial: "Very helpful, and was quick getting me a possible solution!"
  • 15 Answers
SOURCE: Have a fleck 5600 water
The 12 day wheel is used primarily so that the unit does NOT regenerate on the same day of the week, every week.
There is a 7 day wheel available for this valve so if you irrigate on specific days, and you need it to cycle on specific days, you have the ability to do it without the softener cycling at the same time as watering schedule.
Posted on Dec 17, 2010
  • 15 Answers
SOURCE: fleck 5600 will not regenerate
Need more info ! Is this a meter control, or day wheel ?
Does the clock keep accurate time?
If you reach around the back of the timer control box, on the left hand side, can you feel heat from the timer motor?..It should feel a bit warm
Fleck 5600 will not regenerate automatically. It will regenerate if manually started
Dec 06, 2010 | NRS Fleck 5600 - 64,000 Grain Timer Water...
Have a fleck 5600 water softener timer (not economider) dont understand the setting of the days of week when there is 12 pointers on the skipper wheel?
Nov 15, 2010 | NRS Fleck 5600 - 64,000 Grain Timer Water...
We hyave a Watco water softener odel 844, we or having a odor problem what does this mean?
if you have a smell like rotten eggs you have a hydrogen sulfide problem which you can treat in two ways you can add on a carbon filter that regenerates with either chlorine recomended or an airator system which you will smell on the side of your house you can have your hydrogen sulfide checked to see how many parts per million yuou have in your water
Sep 14, 2010 | NRS Fleck 5600 - 64,000 Grain Timer Water...
How do I increase or decrease regeneration frequency?
Water filters do not have a regeneration cycle, they filter the water as it passes through. You do have to replace the filter and the frequency of doing that depends on the sediment in your water. If you are talking about a water softner which does regenerate, all the new ones have sensors in them and they regenerate only when needed. This saves tons of salt over the old systems you would set to regenerate every two or three days whether they needed it or not.
Sep 10, 2010 | Culligan Sediment Water Filter
How do i increase softness
A water softener ether softens or it doesn't. If you are getting hardness leak through continually check to make sure that the bypass valve is closed completely. ( the handle where the pipes go into and out of the softener, make sure the pointer is pointing to service). If you are getting soft water most of the time and it goes hard just before regeneration check the incoming water hardness, if it has gone up you will need to adjust the hardness setting on the unit or if it operates on time, set it to regenerate more often.
Mar 20, 2010 | NRS Fleck 5600 - 64,000 Grain Timer Water...
mmmm.
Feb 20, 2010 | NRS Fleck 5600 - 64,000 Grain Timer Water...
Will not stop regenerating water keeps running
Jan 24, 2010 | Culligan Sediment Water Filter Heavy Duty
Have fleck 5600 economider valve and am getting resin in house been in house 5 years
Resin IN the house??? Yikes Scoob! this is a problem, and since the posting date is a year ago, hopefully you managed to get this fixed by now.
This problem is one of several possibilities, one, the main distributor tube is cracked or the lower basket is cracked or broken depending on how long, or I should say, how fast the resin shot through the pipes into the house fixtures. this type of repair should be left to the service folks like myself, this is not a "DIYer" repair.
Oct 12, 2009 | NRS Fleck 5600 - 64,000 Grain Timer Water...
Water softener seems to be draining all the time
Mar 31, 2009 | NRS Fleck 5600 - 64,000 Grain Timer Water...
Home Logo
83 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
